04-16-2006, 09:32 PM
#141
Putnam
, Connecticut
Status Report
We are nearly functional. All windows are back in, bathroom is online, beds done, mattresses arrived, fridge and stove are at the office, AC panel is in, waterheater works on AC, Tri Metric is working but not programed, two full awnings, rebuilt door with new lockset which will require some mod so we don't get locked in, and some of the lights are in. Lots to do before Region One.
04-16-2006, 11:47 PM
#142
1992 34' Limited
Falls Church
, Virginia
Tri Matic?
Is that Tri Matic that you referenced the battery monitor system?
If so, do you have experience with this system, or heard from others about its performance?
Curious!
Peace
Axel
04-17-2006, 07:55 AM
#143
Putnam
, Connecticut
It is. Easy to install if you read the directions carefully. They could be written better. Seems to work but needs to be setup for each system to have accurant battery status. Factory install gives 100 amp reading for 10 amp load ect. Volts is correct out of the box. Charging info requires programming the unit. Instructions are like those you see in mil tech manuals.
I expect it will be very useful. What it cannot do on it's own is tell you if the batteries are bad.
04-26-2006, 07:47 PM
#144
Putnam
, Connecticut
04-26-2006, 10:33 PM
#145
Lowell
, Massachusetts
THat's awesome! I seriously cannot wait for my maiden voyage! With any luck I may just be able to make it after 12 months of work... but then, it gets very very hot here in the summer and that might stop me in my tracks for a few months.
06-16-2006, 07:57 PM
#146
Putnam
, Connecticut
The Bat Cave Express progress report.
Two more panels and the interior will be reskinned with the additional layer.
Today I connected the LPG to the water heater and it worked. The kitchen counter is in, the sink is in and completely hooked up to supply and drain. The stove is in. Waiting for some doors and drawers I ordered for the galley. Tomorrow is a day off. By Sunday night only fine details and the dinette should remain. The only hard part left is building the cabinet for the fridge and the vents. And of course the dinette.
07-23-2006, 10:07 AM
#147
Lowell
, Massachusetts
Originally Posted by markdoane
The front plate should look like this:
someone please remind me... this steel plate goes in front of, or behind the body when I put the body back on?
Thanks!
07-23-2006, 11:49 AM
#148
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
The steel plate in front goes on the inside of the trailer.
Chris
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
07-23-2006, 12:24 PM
#149
Lowell
, Massachusetts
Chris
Cool, I couldn't remember and I can't seem to find any pictures of that area before I took it apart.
09-12-2006, 09:45 PM
#150
Putnam
, Connecticut
Two brand new Aluminum 30 tanks on the Bat Cave. Still some finish work but we have been using it heavily the season and mostly very thing works well. A busy winter of finish work and trim and a sping polishing.
09-13-2006, 03:48 AM
#151
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Those tanks will look Sweet on there!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
01-11-2007, 03:28 PM
#152
dallas
Hi there,
I am a newbie here that is very excited about the 59 overlander I am about to get into. I thought there may be a chance someone here actually knows this trailer and would like to share. any thoughts?
Thanks, Branden
02-09-2007, 11:57 AM
#153
Putnam
, Connecticut
Originally Posted by branden
Hi there,
Thanks, Branden
I sent you an email
02-09-2007, 12:05 PM
#154
Putnam
, Connecticut
I am redesigning. The Kitchen sink gravity drained into the black tank with a trap in between. Problem 1) When the chief of the boat lets the water run the tank fills too quickly. 2) When the black tank was 2/3 full and the electric head flushed it pushed air into the cabin, I think through the sink. 3) Transferring the wash water to the empty black tank to rise also put smell into the cabin. Not much but enough to smell it.
Solution 1) Rerouted sink drain to a "shower" pump with an automatic pump which sent it to the wash water tank. 2) Rerouted the Bathroom drain to the same pump. 3) Seal the inlet to the black tank.
On the list. A gravity backup drain from both tanks. This will be a simple by pass.
03-15-2007, 12:01 PM
#155
1965 20' Globetrotter
1956 22' Caravanner
Mendon
, Massachusetts
interior panels
Hey Paul,
What did you use for your interior panels? How are the polished panels holding up?
D
56' Caravanner 'The Broomstick'
03-15-2007, 12:45 PM
#156
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Originally Posted by muddy_hollow
Hey Paul,
D
Hey Muddy, where ya been????
www.balrgn.com
03-25-2007, 11:34 AM
#157
Putnam
, Connecticut
Polished panels show every place you touch them. Give's the first mate something to do. Put the last piece of interior skin on and did not polish this. I think it would have been too much shine. Finished fabing the fridge enclosure today. The Zebra wood panel is very nice. I think I'll post a pictures.
The fridge fan system has two layers of fans. At temp 1 the exhaust fans come on, at temp 2 the fans on the coils come on. Four of those little computer fans in total.
03-25-2007, 11:37 AM
#158
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Yes, indeed, post some pictures.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
04-01-2007, 09:47 PM
#159
Putnam
, Connecticut
New cabinet for fridge and a TV.
04-01-2007, 10:29 PM
#160
1959 24' Tradewind
Phoenix
Very nice. Now we just want to see some more. What else you got in that camera of yours?
FF
