Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1954 - 1959 Overlander
Old 03-18-2012, 12:08 AM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Nice '59 Overlander
So I found a nice 59 Overlander international close by and I'm thinking about buying it.i have a few questions and was just hoping somebody out there could answer them for me.
It looks all original. Could it be possible that the bathroom is original with the pink tub,toilet and countertop sink? Kinda cool looking!
The floor looks surprisingly good, no soft spots anywhere.
Windows are good and work, front and rear are plexiglas but I'm hoping those are easy to replace. Anyone have any info on window replace? I'm hoping I can just get a glass shop to cut some glass for me.
ID:	153645   Click image for larger version
ID:	153647   Click image for larger version
desertair27 is offline   Reply With Quote
Old 03-18-2012, 12:27 AM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
I think someone here will know but I believe that the bathroom fixtures could be original. Do the windows still have hardware. If so take plexiglas out and have glass shop make you a Heat Tempered window glass with sanded edges and use the plexiglas as a pattern. The front and rear glass should be heat tempered as this will make them less likely to shatter and do other damage. Think of auto side glass... little bits of glass vs. large and tiny shards if broken. Should be $50.00 or so per window. I have done this on my trailer with great result. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-18-2012, 07:09 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
More pictures! How does the outside look?
Old 03-18-2012, 07:28 AM   #4
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
I bet they are original. (It's too cute!)
My toilet looked just like that (in white.)
~Lynnetta
Someday'59 is offline   Reply With Quote
Old 03-18-2012, 08:29 AM   #5
1958 26' Overlander
Lander , Wyoming
Front and rear windows are probably the same as my 58. Relatively easy to replace with 1/8 tempered glass. Can't tell by the photo. Did they cut into the rear window frame with that AC unit? Also you'd have to live with replacing or patching round lights on the endcap panels. Ed
n2batr is offline   Reply With Quote
Old 03-18-2012, 08:35 AM   #6
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks for the info BigEd and Someday59,Tg More pictures coming. The outside looks pretty good,some issues with the door hinges and it looks like the door has flown open and done some damage.
Old 03-18-2012, 08:37 AM   #7
nmbosa's Avatar
Nowhere , Washington
Those bath fixtures look original, but based on the bathroom configuration, I think that's a '61 or later. Did you get any photos of the VIN tag? The windows are not too difficult to replace. I just used 1/8th tempered and supplies from VTS to re-glaze all my windows. Frank posted a great series of instructions on window replacement here: Windows 101
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 03-18-2012, 08:47 AM   #8
Salt Lake City , Utah
The tub, flush and countertop are almost identical albeit in yellow to the 63 Tradewind we bought last week. Congrats. This is a great forum!
63Tradewind is offline   Reply With Quote
Old 03-18-2012, 08:49 AM   #9
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks for the help,I did notice the front window hardware is intact the back window I did not notice but it didn't look like they cut the window frame.
What's up with the round running lights are they not original?
ID:	153670   Click image for larger version
Old 03-18-2012, 08:57 AM   #10
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Norm
I was told the trailer is a California made unit that was actually purchase new here in El Paso which is really cool to hear.Could that have something to do with a different configuration? Here are some pictures of the tag.
Thanks for the info on the windows and link to Franks blog. What a great guy that Frank is.
ID:	153673   Click image for larger version
Old 03-18-2012, 09:02 AM   #11
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
More pictures of the outside.
The vents have to be missing something. Anyone have any pictures of vent covers?
I couldn't get the fresh water cap off by hand, hopefully that will come off with a bit more effort and some lube.
ID:	153679   Click image for larger version
ID:	153681   Click image for larger version
ID:	153685   Click image for larger version
ID:	153687   Click image for larger version
ID:	153689   Click image for larger version
Old 03-18-2012, 09:07 AM   #12
nmbosa's Avatar
The round international tags are from '58 to '61, but the '59 and '60's I've seen were all built with just one wardrobe at the back and the toilet jammed into the corner with a very small vanity in the center under the window. Could be that the California models had a different configuration. Here is an Airstream brochure for the '59 model layout.
ID:	153683   Click image for larger version
Norm and Mary
Old 03-18-2012, 09:21 AM   #13
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Very cool thanks for the info.
Old 03-18-2012, 09:35 AM   #14
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
There are some door issues with this baby. When the door flew open it looks like it ripped the top hinge out of the skin and the lower hinge mount seems really flimsy almost like it's bolted to skin only. That can't be can it? You can see the PO's attempt to fix the top hinge. I'm concerned with the rip in the interior skin above the door, I wonder what's going on there.
ID:	153698   Click image for larger version
ID:	153700   Click image for larger version
ID:	153702   Click image for larger version
ID:	153704   Click image for larger version
Old 03-18-2012, 09:53 AM   #15
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I have a ton of question for all you experts, hope you don't mind.
I have some questions on the water heater cover that seems to be missing. What exactly is missing and is it possible to find one?
ID:	153706   Click image for larger version
Old 03-18-2012, 10:01 AM   #16
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I looked the serial number and it looks like its a 60 after all.
Old 03-18-2012, 10:16 AM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The door handle is up side down compared to others I've seen on '59 & '60 units. Is this typical of an Overlander or is it CA specific?
It looks in pretty good shape on the outside. Nice find.
Old 03-18-2012, 10:34 AM   #18
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The pink bathroom fixtures are original to International models in those years. My 60 Ambassador has the same fixtures.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 03-18-2012, 11:32 AM   #19
65CV's Avatar
Western , Massachusetts
Nice Find
desertair27-
Sweet looking Overlander. Looks like a good find. The one thing that would concern me is the door frame. I don't have our Overlander here yet, but I looked at our Caravel and see a cast frame around the door. There is no chance of a crack in the door frame, is there? I see a number of missing rivets.
Overall, you will have MUCH less work than I will!
John
65CV is offline   Reply With Quote
Old 03-18-2012, 11:52 AM   #20
1958 26' Overlander
Lander , Wyoming
You will be Ok with the window if the framing is intact. I don't think those round running lights are original. Everything I have seen are teardrop shape if present at all. Believe it or not those door hinges are originally attached through only the one layer of 0.032 aluminum sheet. When I redid mine added some thick aluminum behind it and attached that to a nearby rib. Ed
1966 Airstream Overlander nice classic eBay Watch Airstreams on eBay 0 01-30-2012 03:00 PM
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 10:09 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
1966 Airstream Overlander Bob J. Mariano 1965 - 1969 Overlander 1 08-05-2011 03:44 PM
