Old 10-21-2013, 02:39 PM   #121
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by 65CV View Post
So nice to see some Airstream pics without cuts and bruises! Love the rows of clecos.
thanks John
Appreciate the tip on the cleco's.
On the cuts and bruises, I did did manage to avoid smacking my head but I was able to grind thru a work glove and into a knuckle pretty good and of course I'll be wearing some POR15 on my hands,elbow and legs for a while.
desertair27 is offline   Reply With Quote
Old 10-21-2013, 03:43 PM   #122
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
Think that was for the original hydraulic brakes. We have one on our '51 as well.
calais66 is offline   Reply With Quote
Old 10-21-2013, 04:11 PM   #123
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Are you able to use it? I heard there was some kind of crazy system that had to tapped into the TV brakes system.
I thought about leaving it on for originality sake but the grinder was out so off it came.
Mike
Old 10-21-2013, 04:24 PM   #124
calais66's Avatar
I'm just getting started no my refit, but I'm planning on going electric. From what I gather it would hook directly into the car's brake system, something that's not compatible with today's cars (anti-lock brakes). Even with a vintage TV I hear they're hard to maintain and have a habit of braking (and not in the way they're intended--rim shot!).
Old 10-21-2013, 10:43 PM   #125
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Good one!
Mike
Old 10-22-2013, 08:14 AM   #126
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I was posting some questions on another thread about shock locations and mounts etc found here http://www.airforums.com/forums/f109...ock-93923.html decided to post pictures of what I have and was hoping to get some forums members pictures of how the shocks are mounted on leaf spring equipped trailers. For whatever reason my trailer has no shocks or mounts,must have been built Friday afternoon and mounts were forgotten.i can't imagine they were left off on purpose.
Thanks for any help or advice.
Mike
ID:	198508   Click image for larger version
Old 10-22-2013, 02:17 PM   #127
65CV's Avatar
Western , Massachusetts
I found a couple of pics of my old leaf springs, taken at Colin's shop. Don't know if they'll help, but here they are.
ID:	198528   Click image for larger version
65CV is offline   Reply With Quote
Old 10-22-2013, 03:10 PM   #128
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks John
I see where the shock mounts on the axle/leaf spring area.
Old 10-24-2013, 01:47 PM   #129
nmbosa's Avatar
Nowhere , Washington
Not sure if you still need these, but here is a photo of the original axles on my 59 Overlander.
Norm
Name:	1959 Overlander Original Axles.JPG
ID:	198662   Click image for larger version
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 10-24-2013, 07:03 PM   #130
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by nmbosa View Post
Not sure if you still need these, but here is a photo of the original axles on my 59 Overlander. Norm
i need them for sure. Looks like upper shock mount is basically a stud welded to the frame, is that correct?
Thanks Norm
Old 10-25-2013, 12:15 AM   #131
nmbosa's Avatar
Thanks Norm
Yes it is. You can get nice ones made to be used as a shock mount from Inland RV. I replaced my originals when I converted to torsion axles. They were relatively cheap.
Norm and Mary
Old 10-25-2013, 08:03 AM   #132
65CV's Avatar
Mike,
Need any pics of my finished setup on the shocks? I did switch to torsion also, but it might help.
John
Old 10-25-2013, 08:40 AM   #133
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Mike, Need any pics of my finished setup on the shocks? I did switch to torsion also, but it might help. John
John
I'd like to see what your trailer looks like now if you have some pictures handy.
Mike
Old 10-25-2013, 02:15 PM   #134
65CV's Avatar
Mike,
The first one was taken today to show the plate, stud and fully mounted shock up close. My tires and wheels are off for the winter, so you're looking at tape and plastic over the hub. The second shows the mount point for the shock on the new axle. Look carefully behind the hub. The third -- which is really upside down -- shows the axles in place during the rebuild.
Hope it helps.
John
Old 10-25-2013, 02:17 PM   #135
65CV's Avatar
Strange -- I edited the last post and the pics disappeared.
John
ID:	198709   Click image for larger version
Old 10-27-2013, 06:18 PM   #136
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks guys, the pictures really help a lot! I'm going to stay with the leaf spring and dropped axles and I'll have to add shocks. I think I have the shock dilemma figured out. I still can't believe it didn't have them.
Mike
Old 10-27-2013, 09:41 PM   #137
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Not a lot of work to speak of lately but I did get a solid 10 hour day in today. More working on my back rolling around on a creeper for hours on end. This time I'm double checking all my elevator nuts and on to installing insulation.I'm insulating with 2" foam board with a half inch air gap. I have about a 1/3 of the insulation board installed and 2/3 of the frame POR15. My plan is to get the front 2/3rds POR15 and insulated then install the new front belly pan wraps and buck rivet it back together. I plan to start on the rear once the front is done. I've been removing C channel as I go to remove old tile and epoxy sub floor edge.
During this fun time I keep thinking how nice it must be for the ones doing a shell off to be able to flip the frame over to do all this work. Man is my neck wrecked from this undercarriage work. Click image for larger version
ID:	198837 It's funny the pictures don't show how much time and effort goes into this or how many times I'm rolling under this thing . No wounds today, God knows I've given enough blood already.
Old 10-27-2013, 09:50 PM   #138
nmbosa's Avatar
Time well spent. The floors in these things can be really cold in the morning. Wish I'd put a little more effort into our belly insulation.
Norm and Mary
Old 10-27-2013, 11:02 PM   #139
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Hey Norm
How did you attach your belly wraps/ pan? Rivets would be the norm, I'm thinking about attaching the main flat sheets with rivnuts for easier removal.
I just stared reading your thread on Capt Wilson Overlander,very good read.
Mike
Old 10-27-2013, 11:10 PM   #140
nmbosa's Avatar
Hey Norm
Mike
I used 5/8 pop rivets. I have a couple small service sections that are screwed in so I can access plumbing.
Norm and Mary
1966 Airstream Overlander nice classic eBay Watch Airstreams on eBay 0 01-30-2012 04:00 PM
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 11:09 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 09:31 AM
1966 Airstream Overlander Bob J. Mariano 1965 - 1969 Overlander 1 08-05-2011 04:44 PM
