Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1954 - 1959 Overlander
Old 10-09-2012, 02:58 PM   #61
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by marzboy View Post
I had to fabricate mine. The newer ones are too long. Why dont you replace the steps with newer ones that you screw in from the bottom?
Looks like i'll have to fabricate some after all. What gauge steel did you use?
I'm not aware of the steps you are talking about?
Mike
desertair27 is offline   Reply With Quote
Old 10-09-2012, 09:14 PM   #62
Tool Hoarder
West , California
Mike
Hey Mike
I used 12 Ga cold roll steel. I had some c channel fabricated and just used some of that. Go to any rv store and look at steps. I believe you can get replacement steps that can bolt on. If not You can rebuild the step area like I did.......
ID:	169962   Click image for larger version
marzboy is offline   Reply With Quote
Old 10-12-2012, 06:49 AM   #63
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Hey Mike
Thanks Javier,
I picked up some 12ga cold rolled steel sheet now I have to figure out how cut and bend it. How did you do yours?
I'll go by my local RV Place and check them out. What do you think about an aluminum double step off a 70's Airstream? I can pick one up at a great price.
Appreciate all your help and advice.
Old 10-12-2012, 08:12 AM   #64
Tool Hoarder
West , California
Thanks Javier,
I had mine bent to spec at a local metal yard. Since it was left over chanel I just traced the shape of the outrigger and cut it myself. As for the step outrigger I took the new outriggers and cut them to size then welded them on.
Old 11-29-2012, 08:42 PM   #65
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks for the advice Javier
Finally got my outrigger bent and welded up,next I'll tackle the step outriggers.
Mike
Old 11-30-2012, 01:06 PM   #66
Tool Hoarder
West , California
Mike
Looking good Mike!!
If you can get that step it will pobablly work with the new step outrigger. I tried to get a step from a salvaged trailer but the owner kept screwing around.
Old 11-30-2012, 03:44 PM   #67
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
Thanks Javier,
If you can get the double step at a great price grab it. If you don't need it I will gladly pick it up and compensate you for your efforts.
DGJackson is offline   Reply With Quote
Old 11-30-2012, 10:03 PM   #68
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I got the double step and I just started cutting the old step out today.not sure if its going to work for me but if it doesn't I'll let you know.
Mike
Old 12-01-2012, 02:31 AM   #69
Baltimore , Maryland
Mike, a word of advice.. make sure the new step is in the correct spot. Often modern steps are not the same dimension as the older ones and since the outriggers are gone your reference is also. I have seen it done a few times where the step does not center on the door opening. Fortunately, I have not made this error because I picked up on others doing it. The tendency seems to be to have more step on the hinge side of the door. Not sure why it is toward the hinge, but I have seen this a couple of time.
Old 12-01-2012, 06:48 AM   #70
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks Frank,I will be replacing both step outriggers and I can see how that could happen.
Mike
Old 12-01-2012, 09:11 AM   #71
Tool Hoarder
West , California
Mike
Mike you can re build that step quite easily, I did with no problem. I only had to cut two notches in the new outriggers to lock the step when it was in the open position.
Old 12-01-2012, 04:33 PM   #72
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I may end up using the old step but I sure thought it'd be cool to have the aluminum double step installed. I'm short some parts for the newer steps anyways.
I think the old step mounted in the new outriggers will be good.
Mike
Old 12-01-2012, 06:22 PM   #73
Mike
My man, you own a 1959. There is very little "cooler". You have stepped into, what is in my PROFESSIONAL OPINION, the best era of Airstreams.
Old 12-01-2012, 07:39 PM   #74
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Very nice to hear from such a professional as your self, especially since my first Airstream was a 77 Sovereign. I dig the 70's era trailers but not to crazy about the windows and frame issues.
Anyways very cool to hear I have a keeper and I think I'll keep the original step.
Thanks!
Mike.
Old 12-07-2012, 06:13 PM   #75
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Hey Mike
Hey Javier
How did you go about cutting out the slot in each outrigger that the step retracts into?
Yours looks factory.
Mike
Old 12-07-2012, 06:59 PM   #76
Mike, a down and dirty way... buy the later ones and cut them down to size.
Old 12-07-2012, 07:09 PM   #77
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
That sounds easier than trying to cut the slots.
Thanks Frank
Old 12-07-2012, 08:18 PM   #78
Do you weld? It is an easy transformation. A cut off wheel and a welder is all it takes. Out of Doors mart has them.
I know you can handle it...
BTW Tio Frank's green chile sauce was great, but the red is even better! Thank you so much for sending it to me. I will now be mail ordering it!
I spend a ton of money importing stuff from New Mexico. It might just be time to move there.
Old 12-07-2012, 08:42 PM   #79
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I just started welding so I'm going to give it my best shot. Thanks for the info.
I noticed on your blog how much you liked the Hatch chiles,figured you'd like Tio Franks sauces as well.
New Mexico's winters sure aren't as harsh as Maryland's.
We love New Mexico and Hatch is only 100 miles away. You need to eat at Sparky's the next time you're in Hatch.
Old 12-07-2012, 09:58 PM   #80
195Pilot's Avatar
1975 31' Sovereign
Pierre , South Dakota
desertair,
After I made my outriggers I cut out the slots with a jig saw with a 32 teeth per inch bi-metal blade. Drilled out the top and bottom position with a 3/8 hole saw.
After the cut was made clean up with a die grinder or a file. You can knock that slot out quicker than I can type how to do it.
Good luck
Jack
195Pilot is offline   Reply With Quote
1966 Airstream Overlander nice classic eBay Watch Airstreams on eBay 0 01-30-2012 03:00 PM
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 10:09 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
1966 Airstream Overlander Bob J. Mariano 1965 - 1969 Overlander 1 08-05-2011 03:44 PM
