Old 01-01-2012, 04:25 PM   #141
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Looks great, thanks for taking the time to post your work.
Did you fabricate a new "drip" above the door?
Can you share any detail about it?
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 01-01-2012, 05:47 PM   #142
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Hi Mark
Thank you. I didnt fabricate the drip above the door. A friend , tinman54, did.
He is also the one that gave me the opportunity to try my hand at metal work. I bought Holly from him almost two years ago and I will always be grateful that he say her potential.
Today I fit the new outside handle into Holly's door. I am really enjoying putting together some of the parts that I have been accumulating . I started with making a template of the hole I needed to cut and when it was right I transferred it to the door.After I finish mounting everything Ill cut the hole for the door in the door
ID:	148018   Click image for larger version
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 01-06-2012, 04:56 PM   #143
BradS's Avatar
1957 26' Overlander
Images: 14
Today I finished fitting the door in the door on my trailer. I started with a good door, moved it from the front to the rear of the trailer, changed the swing from a right hand to a left hand and located and installed a Bargman lockset with a H20-2 Handle. My hat goes off to the gentlemen that built these things. I have about 30 hours into the door move and Im not done yet. I know it will work but there is a lot to do still.
Having the trailer indoors with room to work makes all the difference in world.Tomorrow Tim will be at the shop cutting a new lower segment for his trailer.
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-06-2012, 09:37 PM   #144
Central , Mississippi
Great looking sheet metal work. Keep posting the details!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-19-2012, 07:03 PM   #145
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
The new door looks great Brad! Looks like you and Tim are having a good time. You must be getting close to lift off. I have been getting lots of walking in between the barn and warm garage.
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 01-19-2012, 09:00 PM   #146
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Don't take offense Brad, but I don't like reading your thread because your works makes mine look like crap...
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-19-2012, 09:13 PM   #147
Same here...
how about we make a link in our theads that says 'don't look here...' and point to Brads thread
awesum work....
Old 01-20-2012, 06:41 AM   #148
BradS's Avatar
1957 26' Overlander
Images: 14
Thank you Scott. Your trailer seems to be much further along then mine and your work looks very nice.
I have the advantage of time on my hands. We bought our first Airstream new and its always ready to go. If Holly takes forever to finish we wont miss out on any camping.
I dont know if I would have tried this rebuild without this forum. I spend a lot of evenings reading, becoming inspired and gaining confidence. I owe a lot of thanks to everyone here that shares what they are doing.
It also helps that I share a shop with a very good friend, Tim. He is working on a 1964 Safari. He started his rebuild before I even thought about doing one. I think he will be ready to lift the body off his frame real soon. After helping him with his trailer I will be able to approach mine with more confidence and a lot less concerns.
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-20-2012, 08:32 AM   #149
Absolutely the right approach-- make all the mistakes on his trailer so that yours is perfect.
Wait, what I meant to say was, it's so much easier to get the work done when you have someone to share the load.
The sheet metal work is amazing, I can't believe the difference you've made in the endcaps on a trailer that most would probably have left for dead. Just awesome, thanks so much for sharing.
Old 01-21-2012, 05:29 PM   #150
BradS's Avatar
1957 26' Overlander
Images: 14
Hi Marcus
You got that right!
Thanks for your comments about my endcaps. When I started I had no idea about what I was getting into. I have enjoyed it so far although it has been a challenge
Today I mounted my new assist handle.
Last time I worked on the trailer my bezel for the Bargman H-20-2 handle fell out of the door and hit the floor. It broke! I was able to find the pieces and I glued them back together. Not much broke off the casting but it did break. I felt sick about it,very sick
When I got home I got on the computer to see what parts were up for sale on e-bay. I found an old Bargman assist handle. I guess it was meant to be. Now I wont focus on my cracked bezel.
As well today Tim started mounting a new panel on the front of his Safari. I think he is getting close to seperating the shell from the frame. We are planning on lifting it off the roof trusses, Im looking forward to it.
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-22-2012, 04:12 PM   #151
BradS's Avatar
1957 26' Overlander
Images: 14
Today I got a chance to start on the window that will be just forward of the door. On the inside our dinette will go against this window so we wanted it to be large. I came across a couple of jalousie windows that were 36" square each. I like the width but to fit the look of our trailer better I am cutting them down to 24" tall. I got one frame taken apart and cut down to a better size today. The way its built it turned out to be easier than expected.
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-23-2012, 10:41 AM   #152
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
The door handles look great Brad, nice find! I have looked a few times but haven't found the right one yet, maybe I will end up using a deer antler for a grab bar:-)
Old 01-27-2012, 05:51 PM   #153
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Before Picture
Found an old picture of Brads Overlander before the front was repaired by his fine metal working skills!
Old 01-27-2012, 05:59 PM   #154
BradS's Avatar
1957 26' Overlander
Images: 14
Thank you Doug. I have enjoyed working on it. Its nice to see where it started
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-14-2012, 03:47 PM   #155
BradS's Avatar
1957 26' Overlander
Images: 14
I got to spend a little time today with Holly. I have spent the last couple of weeks working on resizing a jalousie window and I got it back together and test fit today. To resize it I ended up taking it completely apart , cutting down the sides and putting everything back together.Along the way I lost count of the hours I spent cleaning. I have one more window to do this to and then its time to think about lifting the body
ID:	151130   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-14-2012, 04:18 PM   #156
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You shortened it by 2 glass panes, right? Looks great, but why did you shorten it? Just wondering.
Chris
Old 02-14-2012, 04:40 PM   #157
BradS's Avatar
1957 26' Overlander
Images: 14
That window will be over the dinette table, it didnt make sense to me to have the glass below the table. The next window will be in the front curb side location, at the foot of the bed. Ill also shorten that one and as well make it narrower, only 24" wide. The 57 has short windows and I didnt want to alter it too much
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-05-2012, 04:58 PM   #158
BradS's Avatar
1957 26' Overlander
Images: 14
I got down to Holly today and resized the next jalousie window. At the last minute I decided to leave it full height and just narrowed the width. I purchased a new profile gauge last week to help with the floor template and doing the cabinets if I ever get that far.It opens to 106" in length and will do inside and outside curves
ID:	152629   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-05-2012, 05:15 PM   #159
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
That's a very unusual looking tool; do you mind if I ask where you found it?
truckasaurus is offline   Reply With Quote
Old 03-05-2012, 05:31 PM   #160
BradS's Avatar
1957 26' Overlander
Images: 14
Woodworkers supply. A friend of mine that does timber work purchased one and as soon as I saw it I knew I would have to get one. I do a lot of decks and gates and pergolas and it will sure make doing curves easier. It should save time scribing cabinets to fit in the Airstream as well
WBCCI 10289
TAC MN-69
AIR 11240
1957 overlander, leaks, replace
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
I think I found My TV augier Tow Vehicles 29 02-06-2009 05:52 PM
Finally found the leak! OregonArgy Repairing/Replacing Floor &/or Frame 4 04-04-2008 10:59 PM
'02 Bambi Leak - Found it! RangerJay 1997 - 2004 Bambi 0 03-31-2007 10:53 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
