Old 01-24-2011, 05:44 PM   #41
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Maybe a dumb thought, but if you switch sides, would it matter as much?
Rae
Im not sure what your question is?
The door will stay on the curb side. It will be relocated to the back of the trailer,just forward of the rear endcap. I plan to rehinge the door so it swings toward the front of the trailer .
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 01-24-2011, 05:45 PM   #42
cosmotini's Avatar
1963 24' Tradewind
Saint Louis , Missouri
Images: 83
That might be great for selling to UK.
I'd be leary of using a door on the road-side - especially when you pull over on the shoulder for whatever reason.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 01-24-2011, 06:10 PM   #43
pbearsailor's Avatar
Port Hadlock , Washington
Originally Posted by BradS View Post
Im starting to look at moving the entry door. I want to put it between the last two ribs, before the back endcap. As well Id like to change it from a right hand swing to a left hand swing. ANY ADVISE?
Looking really good, Brad! Hard to do better than a 13 panel '57, but I am biased.
I'm sure you know Frank's Trailer Works Blog but just in case you don't, he's making a double door out of a single door and there are likely some good ideas there for you.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 01-25-2011, 04:22 PM   #44
BradS's Avatar
1957 26' Overlander
Images: 14
Thanks Steve, I do look at Franks blog from time to time.And yes there are many good ideas there. I like the framework he built to lift the shell. It gives me ideas.
I spent another day at the trailer today.Two more segments went on the endcap and I started removing the last of the damaged metal on the road side. Put a couple pieces on and take a couple off. I look forward to not taking anymore panels off.
I looked at the entry door today. After looking at it Im less concerned about moving it. Maybe Ill be able to get to it in a couple of weeks
ID:	120069   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-26-2011, 08:09 AM   #45
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I see much bucking in my weekend future! Brad's metal work is a work of art. Wish I could take some time off work to buck, but alas, this cannot be done. See you on Saturday Brad!
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 01-26-2011, 12:28 PM   #46
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Looking good, Brad. You're making excellent progress. There's something exhilarating about bucking rivets. It's an Airstream thing.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 01-27-2011, 06:43 AM   #47
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Excellent work, I have also changed alot of skin. I am going to be making aluminum segmented interior endcaps this summer.
http://www.airforums.com/forums/f416...nte-26902.html
Old 01-27-2011, 06:56 AM   #48
BradS's Avatar
1957 26' Overlander
Images: 14
My front endcap was in pieces when I got the trailer. I will end up making an aluminum interior endcap as well. Working with the segments has been challenging. It sure is great to be this far along in the project. When I finish the front I will start on the rear endcap. It too was hit by a tree.
The photos are of yesterdays progress
ID:	120178   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-27-2011, 06:57 AM   #49
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Kip:
Were you involved in training skin replacement at the Vintage Resto. Rally in Alburqurque in April '09?
-Tim
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 01-27-2011, 09:07 AM   #50
Aerowood's Avatar
Arvada , Colorado
Originally Posted by ts8501 View Post
Kip:
Were you involved in training skin replacement at the Vintage Resto. Rally in Albuquerque in April '09?
-Tim
Yes, and I will be doing it again this year, although I plan on doing a poll to see what the attendees want to see this year and plan my presentation around the requests, along with the standard riveting classes etc. Uwe and I changed both lower side skins that year at the rally.
Old 01-27-2011, 09:31 AM   #51
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Yes, and on the lower skins, I helped (well, actually learned more than helped). BradS has you to partially thank for the progress he is making on "Holly". After attending the Rally, I found myself saying "I can do that!". Even though it has been 1 1/2 years since the '09 Resto Rally, the buck riveting training came to play in our work on his "Holly" and my "May". He keeps blaming me for getting him in to this restoration thing, so now he can partially blame you for being a good trainer. I can't say that our bucking looks as good as yours, but it does look pretty darned good. More practice on Saturday.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 01-27-2011, 09:43 AM   #52
AirEPotter's Avatar
2011 27 FB International
Lubbock , Texas
Wow some really nice work. I'm enjoying watching your progress.
AirEPotter is offline   Reply With Quote
Old 01-27-2011, 03:53 PM   #53
BradS's Avatar
1957 26' Overlander
Images: 14
Today I cut and fit the last piece on the road side. The damage to the endcap went back 4 ribs. Now all the rippled, stretched and torn aluminum is gone!
I took the last three segments into the metal shop today. I cut out an oversized blank, the shop puts on the edge detail, and I cut, fit, curse, clamp and alter it to be part of my first endcap. There are only 2 original segments left.
Tim, a great friend indeed, wants to buck more rivets on Saturday and I refuse to let him down. Im looking forward to recovering many clecos. The trailer is starting to look like a pin cushion
ID:	120236   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-27-2011, 04:02 PM   #54
Aerowood's Avatar
Arvada , Colorado
....... so now he can partially blame you .......
Always ready to lend a hand, and stir the pot
Old 01-27-2011, 04:23 PM   #55
BradS's Avatar
1957 26' Overlander
Images: 14
Thanks alot.
Ive told Tim this vintage trailer was so much easier when I just talked about it. I would tell anyone what a nice trailer it would be. How big, how small, whatever fit the mood. It was great, perfect lust, no pain
We went to look at an old trailer. Tim said, just look at it. It turns out Im lucky enough to be spending about 40 hours a week working on it
Thank you every one, its because of you!
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-29-2011, 07:03 PM   #56
BradS's Avatar
1957 26' Overlander
Images: 14
Today Tim and I bucked some rivets. By the time he got to the shop in the morning I was set up and ready to go. The morning went great and we got a lot of work done.
We stopped for lunch and while we were out we got a call from Doug. Doug is the one who I bought the Overlander (Holly) from. He was on his way out to see us. I think he wanted to make sure we are really working on the trailer not just talking about it.
We had a wonderful visit and discussed some of what he is doing to his trailer , a 1954 Crusier, as well as showing him what we have been doing. I enjoy talking to others and hearing about what they are doing. There are so many good ideas out there.
All in all it was another great day. Its nice to have more riveting done and the time spent with friends is always enjoyed.
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-01-2011, 03:19 PM   #57
BradS's Avatar
1957 26' Overlander
Images: 14
Yesterday, Monday , Tim let me know he would be stopping by the shop after work. Tim's help has made this project possible. Regardless of how insane his work life or his personal life gets, he is always available to worship aluminum.
Thank you Tim!!!!!!!!
Tim and I bucked the last of the rivets I had ready! The forest of clecos was gone!
I also got a call from the sheet metal place. My segments were ready. Today a small forest of clecos reappeared on the nose of the trailer. The front endcap is finally back together. One more round of bucking rivets and than I will start the back endcap. Im only replacing 6 segments on that one.
WBCCI 10289
TAC MN-69
AIR 11240
Old 02-02-2011, 09:13 AM   #58
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Wow Brad, you have just about replaced the entire front end cap, and it looks great! Glad too see we'll have some rivets to buck. Not sure if I can break away before Saturday, but it looks like we have a good day of work planned. I am looking forward to the back end cap repair next. "Holly" will soon be fully enclosed again!
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 02-02-2011, 09:59 AM   #59
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
WOw wow WOW - very nice!
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 02-03-2011, 06:50 AM   #60
BradS's Avatar
1957 26' Overlander
Images: 14
Thank you Ken.
I think you have a beautiful trailer . Someday I would enjoy having one that looks so nice, thats why Im doing this.
WBCCI 10289
TAC MN-69
AIR 11240
1957 overlander, leaks, replace
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
I think I found My TV augier Tow Vehicles 29 02-06-2009 05:52 PM
Finally found the leak! OregonArgy Repairing/Replacing Floor &/or Frame 4 04-04-2008 10:59 PM
'02 Bambi Leak - Found it! RangerJay 1997 - 2004 Bambi 0 03-31-2007 10:53 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
