Old 01-17-2011, 03:47 PM   #21
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Another good day. I spent the better part of the day at the trailer today and got 3 more segments fit.Im almost out of clecos, time to rivet.
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is online now   Reply With Quote
Old 01-18-2011, 02:54 PM   #22
BradS's Avatar
1957 26' Overlander
Images: 14
Like all good projects, two steps forward and one step back.Instead of putting on segments I finished removing the front window today. My plan is to move the door to the rear of the trailer and put the bed across the front. Because of this I am taking the rear window,the emergency exit, and moving it to the front of the trailer. Sometimes I wonder why I dont just leave things alone. Here is my purposed floor plan.
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-18-2011, 03:38 PM   #23
cosmotini's Avatar
1963 24' Tradewind
Saint Louis , Missouri
Images: 83
Nice layout! Are you going to have to reverse the hinges and door lock mechanisms?
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 01-18-2011, 03:53 PM   #24
BradS's Avatar
1957 26' Overlander
Images: 14
Hi Dennis
Thats the plan. The door is in good shape so I am hoping to remove the skins, reverse the hinges and add a new lockset. The more I look at it the more I think thats the best thing to do. I want to keep my options open for an awning and unless I flip the door I will have problems
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-19-2011, 02:44 PM   #25
BradS's Avatar
1957 26' Overlander
Images: 14
Today I removed the back window and started getting ready to mount it in front. My bed will be in the front of the trailer and I want the exit there.
For some unknown reason I assumed the front and rear window openings were the same. They are close, not the same. So after removing the window from the back, I resized the front to make it larger.I now have an exit out the front of the trailer
While working on that I decided that I should replace the panel below the window before going to the work of mounting the window. Im starting to wonder how much of the original trailer will be left when Im done.
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-20-2011, 08:12 AM   #26
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
The frame.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 01-20-2011, 01:57 PM   #27
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Originally Posted by ts8501 View Post
The frame.
You can probably save the mice,they will like a fresh new place and maybe some window glass!
Brad , The new sections look good, keep the pictures coming, the furnace business isn't isn't letting me go to far from home, at least I can watch your progress online.
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 01-20-2011, 02:20 PM   #28
BradS's Avatar
1957 26' Overlander
Images: 14
Hi Doug
I just finished up for the day, another good one. While moving the emergency exit from the back of the trailer to the front I decided to replace the panel below the front window.This is what I started on today. I now know what happens when you remove this panel.
And tomorrow I will make the new panel and see if I can cleco it in place. I think Tim will be at the trailers this weekend and I would love to rivet
ID:	119719   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-21-2011, 05:53 AM   #29
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Wow, that's a lot of clecos!!!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 01-21-2011, 01:47 PM   #30
BradS's Avatar
1957 26' Overlander
Images: 14
Another great day. My truck says its about 14 below zero outside, oh well!
Having a heated space for the trailer is great. Its nice to be able to get some work done on the trailer.
I got the front panel, all 12' of it, cut and put in place. I took my time and avoided mistakes. I enjoyed today, this is getting to be a lot of fun. Im still hoping to buck a few rivets tomorrow and then I can get back to segment work.
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-21-2011, 01:49 PM   #31
BradS's Avatar
1957 26' Overlander
Images: 14
I forgot pics sorry
ID:	119772   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-21-2011, 02:15 PM   #32
cosmotini's Avatar
1963 24' Tradewind
Images: 83
Thumbs up Nice work!
Please keep posting updates.
Dennis
Air #4056
Old 01-21-2011, 04:44 PM   #33
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Very nice Brad! Maybe I should bring the Cruiser over and you can play with that too! You are going to be done before me!
Doug
Old 01-21-2011, 05:20 PM   #34
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Wow! Good job. I can't wait to work on this with you tomorrow Brad! Looks like we'll be giving the rivet gun and air compressor a work out.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 01-21-2011, 05:28 PM   #35
BradS's Avatar
1957 26' Overlander
Images: 14
I tried to get as much as ready as possible. Im looking forward to tomorrow.
I got the windows I bought on ebay. Ill bring them with, everything is working out real good!
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-22-2011, 07:33 AM   #36
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Today we buck. Hopefully I remember to take the darned camera this time!
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 01-22-2011, 05:37 PM   #37
BradS's Avatar
1957 26' Overlander
Images: 14
Tim remembered the camera today, the battery was dead. Oh well.
We put in enough rivets today that I can spend the next week getting ready again. Its all a puzzle that fits perfectly "if" Im enjoying this .
We also got some work done on Tims trailer, new nameplate
ID:	119879   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-22-2011, 06:00 PM   #38
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Looking saweeeeet!! Wow!
Rae
Sent from my iPhone using AIR Forums
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 01-24-2011, 04:38 PM   #39
BradS's Avatar
1957 26' Overlander
Images: 14
It was warm out today, I was hoping for a little more winter. Having Tims help on Saturday was great. We got several rivets bucked and today I went back to adding segments.
I only got one fit today, although I got the front window fit and in place . I also cut and fit a panel to fill the old bottom ,road side, front window. When the front end was damaged both windows there were as well. Im only able to make one window from the parts.
Tim is encouraging me to get more panels ready for riveting this coming weekend. Thank goodness he enjoys it cause I need the help!
Im starting to look at moving the entry door. I want to put it between the last two ribs, before the back endcap. As well Id like to change it from a right hand swing to a left hand swing. ANY ADVISE?
ID:	120022   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 01-24-2011, 05:39 PM   #40
1957 26' Overlander
Images: 45
Im starting to look at moving the entry door. I want to put it between the last two ribs, before the back endcap. As well Id like to change it from a right hand swing to a left hand swing. ANY ADVISE?[/QUOTE]
Maybe a dumb thought, but if you switch sides, would it matter as much?
Rae
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
1957 overlander, leaks, replace
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
I think I found My TV augier Tow Vehicles 29 02-06-2009 05:52 PM
Finally found the leak! OregonArgy Repairing/Replacing Floor &/or Frame 4 04-04-2008 10:59 PM
'02 Bambi Leak - Found it! RangerJay 1997 - 2004 Bambi 0 03-31-2007 10:53 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
