Old 02-14-2012, 03:47 PM   #155
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I got to spend a little time today with Holly. I have spent the last couple of weeks working on resizing a jalousie window and I got it back together and test fit today. To resize it I ended up taking it completely apart , cutting down the sides and putting everything back together.Along the way I lost count of the hours I spent cleaning. I have one more window to do this to and then its time to think about lifting the body
ID:	151130   Click image for larger version
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-14-2012, 04:18 PM   #156
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You shortened it by 2 glass panes, right? Looks great, but why did you shorten it? Just wondering.
Chris
Old 02-14-2012, 04:40 PM   #157
BradS's Avatar
1957 26' Overlander
Images: 14
That window will be over the dinette table, it didnt make sense to me to have the glass below the table. The next window will be in the front curb side location, at the foot of the bed. Ill also shorten that one and as well make it narrower, only 24" wide. The 57 has short windows and I didnt want to alter it too much
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-05-2012, 04:58 PM   #158
BradS's Avatar
1957 26' Overlander
Images: 14
I got down to Holly today and resized the next jalousie window. At the last minute I decided to leave it full height and just narrowed the width. I purchased a new profile gauge last week to help with the floor template and doing the cabinets if I ever get that far.It opens to 106" in length and will do inside and outside curves
ID:	152629   Click image for larger version
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-05-2012, 05:15 PM   #159
TAC AB-2
truckasaurus's Avatar
1960 33' Custom
Airdrie , Alberta
That's a very unusual looking tool; do you mind if I ask where you found it?
truckasaurus is offline   Reply With Quote
Old 03-05-2012, 05:31 PM   #160
BradS's Avatar
1957 26' Overlander
Images: 14
Woodworkers supply. A friend of mine that does timber work purchased one and as soon as I saw it I knew I would have to get one. I do a lot of decks and gates and pergolas and it will sure make doing curves easier. It should save time scribing cabinets to fit in the Airstream as well
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-05-2012, 05:47 PM   #161
TAC AB-2
1960 33' Custom
Airdrie , Alberta
Thanks, I'll hunt one down. (maybe two)
Old 03-05-2012, 05:49 PM   #162
Splitrock's Avatar
1976 31' Sovereign
Sioux Falls , South Dakota
"profile gauge" I like it. Do you have a link for buying one?
Thanks!
http://img.photobucket.com/albums/v1...g?t=1278182564
Old 03-05-2012, 05:52 PM   #163
BradS's Avatar
1957 26' Overlander
Images: 14
yes , Woodworker.com: Eliminate Shop Made Templates With The Sidewinder Reshapeable Template, Sidewinder 37, this should get you there
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-05-2012, 06:04 PM   #164
Splitrock's Avatar
1976 31' Sovereign
Found it. Called Curve Template.
Amazon.com: WoodRiver Curve Template 37": Home Improvement
Old 03-05-2012, 10:07 PM   #165
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Originally Posted by Splitrock View Post
Hi, this is a great idea. It would have saved me a lot of time when I did my remodel, making the new credenza fit the curve of my trailer. I think I could afford the one from Amazon.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 04-23-2012, 02:30 PM   #166
Hopelessly Addicted
whitsend's Avatar
2003 30' Classic
1954 25' Cruiser
Wimberley , The Republic of Texas
I can't find where this thread has gone?? As fast as Brad works, I KNOW there are more helpful posts made since Bob's post on 3/5/12!! Have just re-read this very helpful thread yet again (the 3rd!!) and really don't want to loose track of Brad's progress!! HELP!!
Whitsend - Central Texas
I didn't say our divorce was all your fault.
I just said I was going to blame it all on you.
The Ex
whitsend is offline   Reply With Quote
Old 04-23-2012, 04:15 PM   #167
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
I know he's still around, I talked to him 2hrs. ago, I think he needs a little more pressure from everyone to get back to working on Holly! He made up some reason about having to work for a living We all need that aluminum pot full of cash and time to keep our hobbies going! I am not helping his efforts much though because he is going on a recovery mission with me this weekend.
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
1957 overlander, leaks, move door, replace end cap
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
I think I found My TV augier Tow Vehicles 29 02-06-2009 05:52 PM
Finally found the leak! OregonArgy Repairing/Replacing Floor &/or Frame 4 04-04-2008 10:59 PM
'02 Bambi Leak - Found it! RangerJay 1999 - 2004 Bambi 0 03-31-2007 10:53 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
