Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1954 - 1959 Overlander
Old 02-25-2014, 02:24 PM   #21
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
I think Lauren's got it right here. In all the residential applications I've seen, regardless of what's inside it, radiant barrier is used to improve the performance of existing insulation, not replace it completely. I think we all want the most out of our insulation--I know I debated myself 'batt'y over it (rimshot!). At the end of the day tho all that matters is it keeps you warm when it's cold out and vice versa. Not worth losing sleep over 1 or 2 R values.
But it's looking good and a little familiar to boot
calais66 is offline   Reply With Quote
Old 02-26-2014, 08:06 AM   #22
asbury park , New Jersey
It does appear EZcool and prodex are similar products. However, EZ cool is being applied directly to the exterior walls of cars and tested without the airgap. But it also isn't claiming R16.
Calis, yes - looks familiar!
I had been trying to upload a photo of my door area. lets see if this works:
NJtoNC is offline   Reply With Quote
Old 02-26-2014, 09:10 AM   #23
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
We definitely plan to beef up our step area too. Looks good!!
Airstreamin' dreamin'.
Follow our blog! https://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 03-04-2014, 07:18 PM   #24
a little late on friday update. i've been sick. strep. ugh...
First I sprayed the interior walls with truck bed liner. Then I cut spacers out of three-quarter inch foam insulation. On top of that is the ezcool.
I got 3 rolls at a cost of $555 delivered. where did my calculations go wrong? I worked friday sat and sunday and hubby worked today on it, and we have both sides done but neither end cap. we haven't even gotten through 1 roll.
I sealed the top of each section w metal tape.
This pic was from friday.
Old 03-04-2014, 09:18 PM   #25
Sphere Guy's Avatar
Livingston , Texas
NJtoNC, how did you attach the spacers to the interior of the outside skin, or spray liner, and how did you attach the EZ cool to the spacers?
What prep did you use to assure the spray liner would bond to the skin?
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 03-05-2014, 06:36 AM   #26
we used construction adhesive to glue the spacers on, then more adhesive to glue the ezcool to the spacers.
prep? I don't need no stinkin prep! this is the kid of truck bed liner from a spray can at lowes. IT's not really something id use on a truck bed BTW... it DOES have some good texture to it, its a heavy spray, but not like 'real' truck bed liners. this stuff is designed to be sprayed onto bare metal though. The interior of the shell was very clean, the TBL adhered to the aluminum well, and it also adheres to the old tar-like stuff used over the seams in some places.
Old 05-15-2014, 09:57 AM   #27
Fort Lauderdale , Florida
Im on the edge on my seat... Where are we at now?
jschiegner is offline   Reply With Quote
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
Frame repair advice/opinions? hartlander8 Repairing/Replacing Floor &/or Frame 2 08-03-2011 10:40 AM
'69 Overlander frame repair colin57 Repairing/Replacing Floor &/or Frame 6 04-25-2011 10:45 AM
