08-06-2013, 11:44 AM
#181
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
meanwhile...
got side tracked with Jims' Caravanner.
08-06-2013, 03:34 PM
#182
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Lookit all them purty traylahs!!! NICE
Carravanner?????? Did Francisco polish of 4 feet of trailer and make it shorter or wash glare from the shine in your eyes
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
08-06-2013, 03:36 PM
#183
1997 30' Excella
San Antonio
That should be "polish off 4 feet of trailer"
Bruce
08-08-2013, 07:22 PM
#184
1953 32' Liner
1955 22' Safari
Valley View
Door seals
An abbreviated work day. I got the main and inner main door seals on. I do use 8008 3M adhesive an addition to the sticky back on the seal. I used the same seal for the rear hatch as the main door. It looks tight. The piano finish floor is next.
08-08-2013, 09:26 PM
#185
mapleton
, Utah
So.. did you break down and drill out the riveted seal you installed a few days ago?
tim
08-11-2013, 06:25 AM
#186
1953 32' Liner
1955 22' Safari
Valley View
door and seals
Hi Tim! Damnest thing. My expert friend and I brainstormed the problem...and it looked like the hinge had been "tweaked" somehow. I am guessing it was me pushing the door closed in an attempt to compress the new seals. So we went at the hinges. I could see where both the inner door and outer had rub marks on their frames. Now, if you have not looked at the fabrication and geometry of the hinge....do so. I am trying to find some more info....GOT ANY? The best I can find on my own trials is using a C clamp to get at the inner door adjustments. The good old hardwood/hammer on the outer. Then just work it a little at a time. I cannot , at all, figure out why Airstream used both rivets AND screws for the hinges. That may be the adjustment answer.
08-17-2013, 10:58 PM
#187
1956 16' Bubble
Dallas
, Oregon
be sure to just check the lock mechanism itself--i had to take mine apart, lube, and adjust. for the longest time i thought i needed to tweak the hinges too. they ended up being fine-- i was tweaking all kinds of stuff till i found the obvious. it's easy to be fooled when you can't see through aluminum and the inner and outer door gasket from VTS works great once everything's lined up well. these doors can shut like a european car door if you're patient... and get lucky.
08-18-2013, 06:23 PM
#188
1953 32' Liner
1955 22' Safari
Valley View
Thanks for the tweak info.
Tweaking in progress. Lock has been apart and cleaned/greased. Tomorrow.....?
09-25-2013, 08:30 PM
#189
1953 32' Liner
1955 22' Safari
Valley View
Unbelievable
Well, it is something I don't want to believe. The pecan tree sap residue that covered my freshly polished Bubble apparently is quite acidic. All those tiny flecks have etches all the skin, my polished Worthingtons and my new polished battery box. Bonnet with G6 and my usual mashed up green bar hardly touches the damage. It will require compounding and polish all over again.
09-25-2013, 08:39 PM
#190
Hollis
, New Hampshire
Holey moley man, that's awful
09-25-2013, 08:46 PM
#191
Central
, Mississippi
Oh dear. I usually park under my parents pecan trees when we tow over to visit. So far we have not used our polished '63 and now I know not to park there.
THANKS!
09-25-2013, 08:49 PM
#192
1964 17' Bambi II
Schererville
, Indiana
Now that's a HUGE bummer!!! Sorry for you......
Becky
1964 Bambi II
1988 Avion 32S
09-25-2013, 08:50 PM
#193
Streamline Owner
Indianapolis
, Indiana
So sorry to hear the news.
09-25-2013, 11:21 PM
#194
1999 34' Excella
Hillsboro
Was it waxed after polish or is that not done?
Peace and Blessings..
Channing
WBCCI# 30676
09-26-2013, 09:41 AM
#195
1953 32' Liner
1955 22' Safari
Valley View
ruined polish job
No! I don't use wax on a polished one. I do use Turtle wash/wax for the up keep during the year or two befor next polish. The sap damage is akin to bird poop staining.
09-26-2013, 02:34 PM
#196
1964 17' Bambi II
Schererville
, Indiana
Just curious as to why you don't wax? Obviously you don't store it inside.....
Becky
1964 Bambi II
1988 Avion 32S
10-03-2013, 10:43 AM
#197
1953 32' Liner
1955 22' Safari
Valley View
What went wrong
Well, here are some pics I took of the damage to the polished Bubble. Still amazed.
12-19-2013, 12:11 PM
#198
1953 32' Liner
1955 22' Safari
Valley View
anther problem
As I just looked at the last posting….I was having problems. So be it……again
Here are the pics of the coating process for the new interior aluminum panels. I used KBS Diamond finish.
A high quality, self leveling, coating. I did OK until I saw some thin areas and went to re roll them with a thin coat to finish. The result was a pocking which the Company Tech rep is working on with me. I hope it is solvable.
12-19-2013, 12:37 PM
#199
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
It will be a pain, and take a lot of time, but it can be fixed.
Lance
12-19-2013, 02:27 PM
#200
1953 32' Liner
1955 22' Safari
Valley View
It is a PAIN
Right! A PAIN!
The Tech rep said that the MEK leaves a residue which will cause the problem Why then, did their instructions tell me to use it? So I am now where I have to strip the panels with aircraft type stripper, re
clean the surface and re apply the clear coating. It is only money, and time, etc.
