Old 11-19-2012, 08:09 AM   #29
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Another experiment
Entry door leaks at the floor are a problem With the added depth of the flooring and the close tolerance door fit I was having trouble working with a standard threshold. So I made this up...lets see how it works.
Name:	door threshold 2.jpg
ID:	172952   Click image for larger version
Name:	door threshold 3.jpg
Name:	door threshold 4.jpg
ID:	172954   Click image for larger version
Name:	door threshold.jpg
Old 11-19-2012, 08:15 AM   #30
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
battery box
I ran out of room inside for battery placement. So I used to old surge brake mechanicals position and mounted a battery box there.
ID:	172956   Click image for larger version
Name:	Tanks and battery box.jpg
Old 11-19-2012, 08:21 AM   #31
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Just to keep busy
Had to clean up the mess of a typical upper vet and prep for future. I will install a Fantastic Fan here this week. Note the drain line and electrical pre positioned.
ID:	172958   Click image for larger version
Name:	drain line and 110 power preplan.jpg
Name:	ceiling vent and furnace chimney.jpg
Old 12-02-2012, 03:55 PM   #32
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
picture test
Lets see if my new computer and picture site works together.
Old 12-02-2012, 03:59 PM   #33
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Looks like it does....eventhough I can't change the size like I did with Infanview. Can't seem to get that to work with MAC. Well, this is the redone interior. Remember....my dictum was use all the original stuff as possible...clean it up. I did get new high quality foam and ultra leather material. Scanner is for Texas weather checking.
Old 12-02-2012, 05:50 PM   #34
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Looks very nice Rob.
Lance
Top is offline   Reply With Quote
Old 12-02-2012, 08:47 PM   #35
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
out of focus
....but you get the idea.
Old 12-12-2012, 12:27 PM   #36
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
update for anyone interested
Worked on the window treatments today. Blinds.
ID:	174507   Click image for larger version
ID:	174509   Click image for larger version
Old 12-12-2012, 04:55 PM   #37
VIKING's Avatar
Boulder Creek , California
Looking great, Robin.
Cheers,
Rich the Viking
VIKING is offline   Reply With Quote
Old 01-13-2013, 01:21 PM   #38
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Things to do when bored with bad weather
Could not get out so I did nick knack things. Replaced the front cone light with a dual cone fixture...same era.....and look.
Opened up the baggage door and insulated it. Makes it solid and I replaced the lock at the same time. Insulation is covered with the inside aluminum cover so you can't see the foil.
Name:	baggage door insulation.JPG
ID:	176610   Click image for larger version
Name:	baggage door #2.JPG
Old 02-18-2013, 05:37 PM   #39
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
I like what you did with your entry door sill. good job. what's next on your agenda? Ted
the544man is offline   Reply With Quote
Old 03-11-2013, 09:15 PM   #40
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What do you call a bunch of Whales
A Pod. I guess I have a Pod being established here. Work begins today on Babs,,,#3. Work ahead...
Name:	pair progress 5.jpg
ID:	180870   Click image for larger version
Name:	Bub and Babs 4.jpg
ID:	180872   Click image for larger version
Name:	next in line...jpg
Old 03-11-2013, 11:15 PM   #41
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Save the Whales !!
. . . and you're doing your part, Robin. Congratulations on your Life of Riley daughter.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 03-12-2013, 09:36 AM   #42
1999 25' Safari
Somewhere , Ohio
Robin, thanks so much for posting those pics of your new baby. She must be a CA built, right? (I think the shape of the wheel wells are that, and then I thought the CA built ones weren't 13-panel in the rear, but I could be wrong on that too.)
When I look at your pics, I immediately see how much better condition your exterior skins are than ours were. For one thing, no buckshot marks! And I don't think I saw any dents on your exterior. Also, it looks as though yours must have been used more recently than ours had been, it looks as though there is carpeting in there or something red anyway. From the looks of ours when we bought her, the interior looked as though she hadn't been used for a couple decades, at least.
I can't wait to see what you do with her.
Deb
Air Cruiser is offline   Reply With Quote
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
