Old 06-01-2014, 06:36 PM   #379
1956 16' Bubble
Landrum , South Carolina
Images: 20
Bubble 1
Robin
It looks like your make good head way on Bubble 2 and I like all the colors. Beth is working on getting throw pillows and a rug for Bubble 1 to add color. We are enjoying Bubble 1 out here in Huntington Beach. I have had to work for the last 2 weeks and now will have some time off -- I hate it when work gets in the way. We hare taking Bubble 1 down to the beach this week and have dinner. Will send picture.
Carl and Beth
OkieHB is offline   Reply With Quote
Old 06-02-2014, 08:34 AM   #380
1999 25' Safari
Somewhere , Ohio
Robin, I'm not certain what you mean by a double pleat, to me that would be a pair of pleats then a space, another pair of pleats, then space, etc. I think you may be speaking of "fingers" in the pleats, is that right? For instance, the most common of pleats are called pinch pleats and they normally have three fingers and are called "three finger pinch pleats" (this is getting a little technical, I know), but there are also "two finger pinch pleats". (By the way, I call my pinch pleats "French pleats", just a little nicer name for high-end work.)
I'm going with talking about the number of fingers in your pleats: a part of this discussion would cover fullness of your draperies; you can add fullness by having a little larger pleat (meaning more fabric in each pleat), but also having another finger in them allows more fabric without having the bulk of a larger pleat which would stick out into the room further, thus fullness too. Considering this is a Bubble and tight spaces, I'm wondering if you want to keep fullness to a minimum and are really having the fabric to add color and texture/warmth. I'd probably go with a two-finger pleat.
In our Bubble I've been thinking of fabricating Roman shades which have a clutch system of components and are raised/lowered by a continuous bead chain -- no cords/cleat. We'll have the fabric for added color/texture/light blockage (I'll use blackout lining), and they will stay flush with the wall; I may have to use a small bracket on the bottom to keep against the walls if necessary.
Deb
Air Cruiser is offline   Reply With Quote
Old 06-02-2014, 08:48 AM   #381
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
it's a foreign language
All these sewing terms are new to me. The double pleat I was trying to describe is the type used in Airstream of the past...present too. The drapes with pleats at top and bottom. It gives a more formal appearance I think. I agree...keep the billows out. The drapes have to be close to the walls/windows. I am waiting now for the right color to materialize. Going with that teal on the seats.
Old 06-02-2014, 09:00 AM   #382
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
California transplant
Thanks for the update Carl and Beth. I was beginning to worry about not hearing from you after your "learning curve" first trip. There will always be something to work out with both yourselves and the Bubble. It will all settle in. I am glad you like #309. I got the Texas plate..THANK YOU! Now I may just have to put it to a good use...NO! NO! NO! I will finish up this one here and come visit...a family photo at the Beach.
Name:	Carl leaving with Bubble 2.jpg
ID:	213334   Click image for larger version
Name:	Carl leaving with Bubble.jpg
Name:	Carl leaving for California.jpg
Old 06-02-2014, 09:05 AM   #383
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by Melody Ranch View Post
Sold to a great Family in California. Keep your eyes open for it on the road.
What a combo, I see fins on the tow vehicle!
Old 06-03-2014, 07:40 PM   #384
1999 25' Safari
Somewhere , Ohio
I know I probably gave you too much info, but it's just normal for me. In my work, I must get to the bottom of what the client is picturing/wanting to make certain I am envisioning the same end result. Most clients don't know the correct terminology, and if I assume they know, I could end up delivering something completely different than what they had wanted. If that happens, I am the one who has to reorder fabric and refabricate the job, all on my dime, so I've learned to provide plenty of pictures as well as explanations.
In seeing what you've selected already, you have good taste and I'm certain whatever you choose will look great. (In my opinion tho (and strictly my opinion), as we've both already said, I'd go with less fullness on the window treats due to the small interior.) Are you going to allow the bottom of the window treats to hang loose, or are you planning to attach them as AS does?
Again, I'd probably do the two-finger pleat.
I was briefly a little caught up on the red in your countertop, but then when I looked back I realized you have that tied in with the upholstery fabric, that's good. That teal is a really relaxing, calming color, and I think that will work well in there.
Deb
Old 06-05-2014, 01:35 PM   #385
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Interior update...
Getting closer.
Name:	Bed and seat.JPG
ID:	213599   Click image for larger version
Name:	Bed and seat 2.JPG
Name:	Bed extended.JPG
ID:	213601   Click image for larger version
Name:	Bed looking forward.JPG
Name:	Table at front.JPG
ID:	213603   Click image for larger version
Name:	seats and table.JPG
Old 06-05-2014, 01:39 PM   #386
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
That is looking great. Like that you used the same material for the bed/mattress. That way it can be used for extra seating if needed and still match the interior.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 06-05-2014, 01:57 PM   #387
whitsend's Avatar
1954 25' Cruiser
Kyle , The Republic of Texas
RC - This is looking SO COOL. But . . . why can't I win a Lotto so I could start a collection & have a choice of which to use? I really like it all & do wanna see it before it gets sold & moves away ;-(
I love that old time rock & roll.
whitsend is offline   Reply With Quote
Old 06-09-2014, 06:07 PM   #388
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
clean up work
While I wait for the curtains/drapes I changed out the screen door locks. I use Perko stainless where I can. These look good to me and work GREAT!
Old 06-09-2014, 06:13 PM   #389
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
barrel latch
poor photo, but you get the idea.
Name:	ballel latch.JPG
Old 06-09-2014, 06:15 PM   #390
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
barrel lach, better photo
Latch
Name:	barrel lock dimensions.jpg
Old 06-09-2014, 06:21 PM   #391
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I am sick and tired of seeing these gate type latches on Airstreams.
Tired of the ugliness...I am trying this...I use Perko marine stainless and stainless hardware.
Name:	door lock .JPG
ID:	213933   Click image for larger version
Name:	new door barrel lock.JPG
Name:	DSCN2903_2003.JPGnew barrel lock  3.JPG
Old 06-09-2014, 06:47 PM   #392
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
perfect radius on the table--looks like someone else's bubble! good work sir! ted
the544man is offline   Reply With Quote
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
