Old 03-03-2014, 07:12 PM   #267
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Are those cushions the ones you are going to use? Also you shoulder sleep with your boots on.
FC7039 is offline   Reply With Quote
Old 03-05-2014, 09:21 AM   #268
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
more work
Hi...Yes...why go to expensive new stuff. I can get at least 10 more years out of those cushions...if I don't put my boots on them while I sleep.
Working the sliding door today...the last big project. Then it is the counter top and the table. I got an adjustable Garlick yacht type table stand....it will be here Friday.
Also got some Formica, old style boomerang design. Now I have to find upholstery and curtains/shades to match. I find that decorating stuff/co-ordinating difficult.
ID:	206851   Click image for larger version
Name:	Bath walls fit.JPG
Name:	bath rear wall.JPG
ID:	206853   Click image for larger version
Name:	bath sliding door.JPG
Name:	bath floor and utility access.JPG
ID:	206855   Click image for larger version
Name:	rear area reading light.JPG
Old 03-06-2014, 08:21 AM   #269
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Air Conditioning solved
Finally! An air conditioner for thew masses.https://www.facebook.com/photo.php?v=10202253025101231
Old 03-07-2014, 08:18 AM   #270
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Sliding door is now in.
The door is now ready for staining along with all of the interior wood. Late today I will disassemble it all, pull it out for final check and staining/finish. Some tweaking inside along with the new laminate floor....probably in two days when the temps are forecast to be warmer.
ID:	206935   Click image for larger version
Name:	bath and bed.jpg
ID:	206937   Click image for larger version
Old 03-07-2014, 09:17 AM   #271
1999 25' Safari
Somewhere , Ohio
I really like what you've done, great job! This last set of pics cleared up your layout for me, very visual here. I'm still a little iffy on how the bed works, but I'm going to ask my DH to look your pics over and read the posts -- he's very mechanically oriented, so I think he'l "get it".
I have a question for you, is there room from the front of your bathroom (the wall) to the wheel well for a larger frig? That's about the area we're thinking we'd like to place our frig since we want a larger one and there just aren't that many places in a Bubble to put a taller-than-normal frig.
Thanks.
Deb
Air Cruiser is offline   Reply With Quote
Old 03-07-2014, 06:32 PM   #272
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
pulled the entire interior
Finished the cabinetry. So....I pulled it all out so can install the floor and stain the wood cabinetry.
I have a first major problem....I do not like ho low the Valtera dump valve sets behind the wheel... I may have to move the axle below the springs.
I have decided to use extra formica and install on the contort below the bath sink and the floor under the toilet. I had just enough to do that and I like the color tie in into the toilet "room."
Started to fit the piano finish flooring. And, YES, I am putting it on the entire floor. I like the finished look it gives to the floors in the closet and cabinets.
Rain and cold tomorrow....will wait a few days to continue.
Name:	interior sink back side.JPG
ID:	206985   Click image for larger version
Name:	closet aND BED.JPG
Name:	interior seating.JPG
Old 03-07-2014, 06:43 PM   #273
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
more optics of interior work
having trouble posting...here we go...
Name:	Interior misc. partsc.JPG
ID:	206988   Click image for larger version
Name:	piano finish flooring.JPG
Name:	Interior seating #2.JPG
Old 03-07-2014, 08:02 PM   #274
redondo beach , California
Where did you source the formica?
PLVMB is online now   Reply With Quote
Old 03-07-2014, 09:43 PM   #275
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Formica Boomerang sheets are Wilsonart from an old kitchen remodel. Not available anymore. Wilsonart does have a Boomerang pattern available now, but it is only in one color choice...black and grey.
Old 03-08-2014, 07:54 AM   #276
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Built like Airstream would do it (almost)
I forgot to mention....all the interior was built with the premis...it will all fit through the door.
Old 03-08-2014, 10:06 AM   #277
1999 25' Safari
Somewhere , Ohio
Looking good!
I remember my parents had that same Boomerang pattern in their kitchen many years ago -- brings back memories.
Deb
Old 03-09-2014, 08:23 PM   #278
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Wow, Robin! You're really quick with your woodworking! It looks great. Your sliding door is really a nice touch.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-10-2014, 08:53 PM   #279
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Something worse than polishing
Never thought there would be something worse than polishing...there is (for me.) now. Staining and finish painting all the interior. All hand work and rubbing the stain in twice...then paint and sand and finish paint with a satin clear coat. It will never end.
The wood floor is in also. DO NOT ever try to use a click type flooring which has the foam type insulation barrier bonded to it. A PAIN! The insulation stretches into the grooves and the boards will not join. I had to hand trim every board once I figured out the problem.
Pictures tomorrow. I am all stove up from that bending over all day staining.
Old 03-10-2014, 09:07 PM   #280
Becky B.'s Avatar
1964 17' Bambi II
4 ibuprofen & a hot shower is in order! (I was just there about a week ago!) :-)
Becky
1964 Bambi II
1988 Avion 32S
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
