Old 10-25-2012, 03:02 PM   #15
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks to TOP
Lance dropped a note to me to recheck something on the electrical system. I did and it was a serious error on my part...he caught it. See the discussion here about 50 AMP service. Yay! 50 amp Service upgrade - Done I had connected both the neutral and ground to the common buss in the breaker box. That got fixed fast. Thanks everyone.
Name:	Electrical system.jpg
Old 10-31-2012, 09:13 AM   #16
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
moving along
Part of the belly pan work was the repair of the damage from a blow out on the right tire.
Name:	belly damage behind right wheel.jpg
ID:	171720   Click image for larger version
Name:	belly damage right rear.jpg
Name:	Pan repair.jpg
ID:	171722   Click image for larger version
Name:	Banana repair right rear.jpg
Old 11-11-2012, 09:11 AM   #17
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Anyone really use a Panel Ray
I am down to cleaning up the heater and really want to use it if it is safe and efficient. Any input?
Name:	Gas heater 2.jpg
ID:	172492   Click image for larger version
Name:	heater attach.jpg
Name:	Heater outside.jpg
ID:	172494   Click image for larger version
Name:	gas hook up to heater.jpg
Old 11-11-2012, 09:22 AM   #18
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
next question on Zolatone stains
The previous owner glued an asswarmer pad on the rear wall by the bed. I am having a problem removing the stain. I want to preserve the Zolatone because overall the original elsewhere is perfect.
ID:	172497   Click image for larger version
Name:	wall glue stain 2.jpg
Name:	wall glue stain.jpg
Old 11-11-2012, 09:24 AM   #19
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
"kitchen" area almost done
Got the stainless for the stove installed
Name:	Kitchen stainless.jpg
Old 11-11-2012, 10:03 AM   #20
mapleton , Utah
Looking great Robin. If I remember correctly R.J. Dial rebuilt several of the panel rays in his vintage thread. Good info on controls and operation.
tim
rumrunner is offline   Reply With Quote
Old 11-11-2012, 05:57 PM   #21
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks Tim....I have been looking at that. How's the Cloud? How's "Cleco?"
Old 11-11-2012, 06:12 PM   #22
reinergirl's Avatar
Hollis , New Hampshire
Looking great indeed! Whenever I find myself wanting to remove a serious stain on paint I reach for one of those magic eraser sponges by Mr Clean. It won't remove adhesive but if it's just staining it might help....
reinergirl is offline   Reply With Quote
Old 11-12-2012, 04:29 PM   #23
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
O.K.....ready for a road trip.
Well, that was fun. Got Bub done, and took a trip. It was so nice today I went from Texas, to Oklahoma and over to Arkansas and back home. Bud did well.
Old 11-12-2012, 05:31 PM   #24
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Cool!
Lance
Top is offline   Reply With Quote
Old 11-12-2012, 05:48 PM   #25
mapleton , Utah
Lets see...Texas to Oklahoma to Arkansas & back home, if you start in the right place you could probably do it in about an hour and a half-right?
That combo is just too cool for words Robin, anybody here who isn't jealous died yesterday and hasn't noticed yet
Cleco and I are doing well and the cloud is coming along, albeit slowly since we got 8" of snow saturday. Keep in touch
tim
Old 11-12-2012, 06:37 PM   #26
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I cheat
I live 16 miles from Oklahoma and in the area of the Arklatex. Hell, I could have thrown in a BBQ in Louisiana in another couple miles.
Old 11-13-2012, 10:35 PM   #27
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Beautiful work! Looking at your underside and the great improvement you made in the bottom of the wood subflooring, the frame and the insulation makes me realize that I really need to do the same thing on my 66 Tradewind.
So I have a few questions. What did you use to cut the aluminum pan with? What do you recommend using for the pan material and where can it be purchased? Where did you get your insulation? What rivets did you use?
Your bubble is really beautiful. I really like the look without an ugly A/C unit on top. Are you going to add A/C? I mount a small 5k unit in my side window when I need it and it works just fine.
Thanks for sharing all the photos and showing us also how it should be done.
Dan
Old 11-14-2012, 06:48 AM   #28
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks...
I cut the old belly pan off with both hand shears and an air hand shear. The insulation was from that supplier of exotic materials...Home Depot. I just stacked and glued to get the three inch thickness. I used regular old belly pan rivets that I got from Vintage Trailer Supply...but went to my local FASTENAL store for enough to finish and get 1/8 th in rivets for the interior. I always use my local sheet metal shop or my local trailer....mostly horse trailer...shops for metal. Around here they have a good supply at hand or get deliveries within three days. I even had them run my new extensive 12v wiring so I have nicely installed 12v everywhere and I did not have the haste. An AC install is a definite for me around here. I am still looking close at a "thru the wall", sleeved unit.....Not to be confused with a window wall unit.
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
