Old 02-14-2014, 10:22 AM   #239
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
[QUOTE=Melody Ranch;1415650]67 inches long? Never happen here. I need 74 minimum and go for 78 in the Bubble.
I have measured and measured what our sleeping requirements are and neither of us are sprawled out sleepers. I could see a bigger bed if we were 'tall' folks but we aren't. Also our bed is for sleeping not 'gymnastics'
goshawks00 is offline   Reply With Quote
Old 02-14-2014, 06:44 PM   #240
1999 25' Safari
Somewhere , Ohio
goshawks00, I know, but it's looking really good starting this coming Wed. on!
I'm about to burst trying to wait to find out about this linear actuator! I searched this thread, but can't find anything to describe what it is, although I imagine I know roughly the resulting outcome. I'm thinking that perhaps this is something that we, too, could use. I'm guessing it uses a hydraulic pump to push out/pull in a portion of the bed to make floor space when not needed for a bed, but also needs to lift up to make it level with the fixed portion of the bed? Thinking of this brings up many ideas -- can't wait!
We, too, aren't tall -- DH 5'8" and I used to be 5'4", although I suspect I may have shrunk a tiny bit. Wanting to save all valuable floor space.
Deb
Air Cruiser is offline   Reply With Quote
Old 02-14-2014, 07:01 PM   #241
reinergirl's Avatar
Hollis , New Hampshire
Deb, I posted in Becky's thread below about a guy that used a linear actuator in a van. Post 12. Interesting reading, can't wait to see what Melody Ranch does.
http://www.airforums.com/forums/f7/h...-114058-2.html
reinergirl is offline   Reply With Quote
Old 02-14-2014, 07:45 PM   #242
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Every time I see the words " linear actuator slide out", I get almost giddy!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-14-2014, 07:48 PM   #243
1999 25' Safari
Somewhere , Ohio
Thanks, Shelly, for posting that link, I wasn't aware of that thread.
That is so cool! As someone else said, there would have to be a way of having an override or something so that if it stopped working, you could still manually pull out/push back the bed, so as not to ruin a camping trip.
I, too, am anxious to see how Robin works this out.
Deb
Old 02-14-2014, 08:29 PM   #244
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
try this for a reference
Heavy Duty 18" Linear Actuator Stroke 12 Volt DC 200 Pound Max Lift | eBay
Old 02-15-2014, 06:28 AM   #245
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Someone is giving away a motorized seat/bed from a conversion van, on the Atlanta Craigslist today just in case anyone is looking for those motors!
Skatiero is offline   Reply With Quote
Old 02-15-2014, 08:04 AM   #246
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I should be camping
Weather changed here in Texas. (Is that news?) 70 degrees plus all week. I am locked into getting the Bubble back in one big pile so I elected to work it instead. I am seeing things come together.
Name:	bedside cabinet wall.JPG
ID:	205625   Click image for larger version
Name:	bedside cabimet shelf.JPG
ID:	205627   Click image for larger version
Name:	bed slide.JPG
Old 02-15-2014, 08:54 AM   #247
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You're raising the bar somewhat here, as I was just going to use gas struts. I guess its going to cost a little more cash to "keep up with the Jones". You going to use one or two?
Old 02-15-2014, 09:20 AM   #248
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hi Kip....going to use three heavy duty ball bearing drawer slides (overkill) and the 22inch actuator. The bed will never have to be moved out or in with any significant weight on the platform so it all should work well. My project today will be to figure out a "pull pin" so I have an emergency release in case of power or mechanical failures.
Old 02-15-2014, 09:41 AM   #249
Aerowood's Avatar
Arvada , Colorado
I understand now, you are moving horizontally not vertically. I'm planning on the bed frame lifting with gas struts, maybe if I used both I could get by with a smaller actuator. Something to think about.
Old 02-16-2014, 03:07 PM   #250
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
renewed respect for propane bottles
I have heard many stories of propane bottles falling out of the mount, then being dragged on the pavement. We should avoid that....You won't believe the damage this tiny fender bender causes | The best damn Funny Videos, and Crazy Pictures online!
Old 02-16-2014, 07:23 PM   #251
Becky B.'s Avatar
1964 17' Bambi II
wowza! I have a great respect for those tanks.....a guy across the street from our business got his head blown off while filling one up....I stand REALLY far away when I get them filled!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-16-2014, 08:10 PM   #252
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
How many PSI are in a filled tank? Dang that's something....
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
