Old 10-03-2013, 10:43 AM   #197
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What went wrong
Well, here are some pics I took of the damage to the polished Bubble. Still amazed.
Name:	what happened 2.JPG
ID:	196974   Click image for larger version
Name:	What happened.JPG
Old 12-19-2013, 12:11 PM   #198
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
anther problem
As I just looked at the last posting….I was having problems. So be it……again
Here are the pics of the coating process for the new interior aluminum panels. I used KBS Diamond finish.
A high quality, self leveling, coating. I did OK until I saw some thin areas and went to re roll them with a thin coat to finish. The result was a pocking which the Company Tech rep is working on with me. I hope it is solvable.
Name:	panel finish.JPG
ID:	202041   Click image for larger version
Name:	panel finish cover removal.JPG
Name:	panel refinish after Diamond Brite.jpg
ID:	202043   Click image for larger version
Name:	Panel refinish Diamond Brite problem.JPG
Old 12-19-2013, 12:37 PM   #199
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
It will be a pain, and take a lot of time, but it can be fixed.
Lance
Top is offline   Reply With Quote
Old 12-19-2013, 02:27 PM   #200
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It is a PAIN
Right! A PAIN!
The Tech rep said that the MEK leaves a residue which will cause the problem Why then, did their instructions tell me to use it? So I am now where I have to strip the panels with aircraft type stripper, re
clean the surface and re apply the clear coating. It is only money, and time, etc.
Old 12-20-2013, 08:25 AM   #201
1999 25' Safari
Somewhere , Ohio
That would be so disappointing. But, on the flip side, from my point of view (which is much behind you on working on our Bubble at this point), overall, your new interior skins look good.
I didn't realize there is a coating available for the aluminum. Is there a solution to this problem for someone who hasn't applied any of it yet? (Trying to avoid future problems.)
We haven't been able to do any work on ours since the weather turned. We were able to get her into the shop, but just. Of course the area that has the large overhead door is the same place we have the auto lift, which takes up quite a bit of space. There's not enough room on either side of her to get in there and do anything. I was hoping to be able to get the polishing and sealing completed this winter.
Deb
Air Cruiser is offline   Reply With Quote
Old 12-30-2013, 10:24 PM   #202
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
and it continues
Well, I had to remove the entire ceiling, which includes all the AC stuff, and replaced the aluminum sheet with new. Had to buy another quart of Diamond Brite and a can of their cleaner/prep. And the story goes on…..when I applied and washed the new polished aluminum in went dull. Seems as though the prep is a mild solution of aluminum prep for painting……an acid etch. So contrary to the company tech rep instructions and guidance….I was stuck with a shiny matt aluminum. I will have to stay with it for now and will con side Zolatone in future if I can't stand the new look. I am awaiting the new custom black tank and misc trim parts before I start the floor install and woodwork.
Name:	Bubble new interior skins 2.JPG
ID:	202636   Click image for larger version
Name:	Bubble new interior skins.JPG
Name:	Bubble ready for wood work and floor.JPG
Old 01-17-2014, 08:37 AM   #203
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
interior work
I decided to try cabinet work myself. Never have done that, even though I have built my Timberframe home. So, here goes.
I am using maple as my wood of choice and planning on staining it a dark honey color. Jeeze! Maple is expensive!
Name:	Bubble floor plan.jpg
ID:	203771   Click image for larger version
Name:	Seats in Bubble progress.JPG
Name:	seats in Bubble progress 2.jpg
ID:	203773   Click image for larger version
Name:	seat stick frame.JPG
Old 01-17-2014, 01:45 PM   #204
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I used maple for my cabinetry too. If you have a Menards nearby, they have pieces that are square on three edges only. It's a little less expensive than the completely square lumber. They have frequent sales too. After making my cabinets, cutting pine is like cutting soft butter! I'm keeping a close eye on your progress & electric gaucho!!! :-D. Dinette looks great!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 01-17-2014, 04:08 PM   #205
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
to late on the maple
Darn...I already bought and cut the maple. You watching me closely makes me nervous...your such a perfectionist. I had not planned a 12v access down low where I need it for the linear actuator....so, opening up a wall and getting that wired is my project next week. Camping this weekend and road repairing from the ice storms, as I can, in the interim.
Old 01-17-2014, 04:40 PM   #206
reinergirl's Avatar
Hollis , New Hampshire
I think your benches look great! And I think the shiny matte might be great at concealing fingerprints and smudges.....
reinergirl is offline   Reply With Quote
Old 01-17-2014, 05:35 PM   #207
Becky B.'s Avatar
1964 17' Bambi II
Don't be nervous.......plenty of my expensive maple is being used as starter wood in the fireplace this year.....I just try not to talk about my screw-ups!
Becky
1964 Bambi II
1988 Avion 32S
Old 01-17-2014, 11:21 PM   #208
1956 16' Bubble
San Luis Obispo , California
Bubble catching up
I am fascinated with this forum - so much new information and nicely compartmentalized to model and year so I am reimmersing myself in Bubble lore! I started at the beginning but when I got to the part about the trailer coming uncoupled - well that got my attention! I'd probably have hit the brakes and put both rigs in a ditch at best.
When the rig is hitched and the coupler is down in place, one should not put a long hasp lock in the holes? Why not - is the metal hasp not strong enough? What should one use? Guess I've just been lucky so far but at least my safety chains were new.
After all the work on my Bubble, just this past summer I was towing it home from a local lake with my little fiberglass boat atop the truck shell when the boat loader parted company with the shell, sending the heavy aluminum loader and the boat flying into the front of the trailer. LOUD - I asked husband, "What was THAT?". He looked out and said, "We no longer have a boat". Front panels of trailer all dented in, boat & loader about a mile behind us in the ditch. Wow - went home, dropped the poor Bubble and went back to recover the flying boat (we loaded it into truck) but the loader was so heavy had to hid it under a willow tree until we could get more muscle the following day.
Eventually got the dents rolled out (after removing inside panels) but every time I look up there I swear they're coming back. Jw
JoansMom is offline   Reply With Quote
Old 01-18-2014, 09:54 PM   #209
Central , Mississippi
That is awesome looking work, not a single 2x4 or piece of 3/4" ply to be seen...
I'm serious.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-19-2014, 03:19 PM   #210
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Grasslands Rally....
I needed a break....went to the Grasslands which is remote, however, near to where I live.
Directions were go South and turn at the Bethel Baptist Church sign. Do you have ANY CLUE as to how many signs they put up for the Bethel Baptist Church...? Someday I have to go there...
Name:	Bethel Baptist Church.JPG
ID:	203947   Click image for larger version
Name:	Bethel Baptist Church again.jpg
Name:	Bethel Baptist Chrurch again...again.JPG
ID:	203949   Click image for larger version
Name:	Bethel Baptist Church again...again...again..jpg
Name:	Bethel Baptist Church turn here.JPG
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
