Old 08-06-2013, 03:36 PM   #183
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Originally Posted by bwoodtx View Post
Lookit all them purty traylahs!!! NICE
Carravanner?????? Did Francisco polish of 4 feet of trailer and make it shorter or wash glare from the shine in your eyes
That should be "polish off 4 feet of trailer"
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-08-2013, 07:22 PM   #184
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Door seals
An abbreviated work day. I got the main and inner main door seals on. I do use 8008 3M adhesive an addition to the sticky back on the seal. I used the same seal for the rear hatch as the main door. It looks tight. The piano finish floor is next.
Old 08-08-2013, 09:26 PM   #185
mapleton , Utah
So.. did you break down and drill out the riveted seal you installed a few days ago?
tim
rumrunner is offline   Reply With Quote
Old 08-11-2013, 06:25 AM   #186
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
door and seals
Hi Tim! Damnest thing. My expert friend and I brainstormed the problem...and it looked like the hinge had been "tweaked" somehow. I am guessing it was me pushing the door closed in an attempt to compress the new seals. So we went at the hinges. I could see where both the inner door and outer had rub marks on their frames. Now, if you have not looked at the fabrication and geometry of the hinge....do so. I am trying to find some more info....GOT ANY? The best I can find on my own trials is using a C clamp to get at the inner door adjustments. The good old hardwood/hammer on the outer. Then just work it a little at a time. I cannot , at all, figure out why Airstream used both rivets AND screws for the hinges. That may be the adjustment answer.
Old 08-17-2013, 10:58 PM   #187
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
be sure to just check the lock mechanism itself--i had to take mine apart, lube, and adjust. for the longest time i thought i needed to tweak the hinges too. they ended up being fine-- i was tweaking all kinds of stuff till i found the obvious. it's easy to be fooled when you can't see through aluminum and the inner and outer door gasket from VTS works great once everything's lined up well. these doors can shut like a european car door if you're patient... and get lucky.
the544man is offline   Reply With Quote
Old 08-18-2013, 06:23 PM   #188
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks for the tweak info.
Tweaking in progress. Lock has been apart and cleaned/greased. Tomorrow.....?
Old 09-25-2013, 08:30 PM   #189
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Unbelievable
Well, it is something I don't want to believe. The pecan tree sap residue that covered my freshly polished Bubble apparently is quite acidic. All those tiny flecks have etches all the skin, my polished Worthingtons and my new polished battery box. Bonnet with G6 and my usual mashed up green bar hardly touches the damage. It will require compounding and polish all over again.
Old 09-25-2013, 08:39 PM   #190
reinergirl's Avatar
Hollis , New Hampshire
Holey moley man, that's awful
reinergirl is offline   Reply With Quote
Old 09-25-2013, 08:46 PM   #191
Central , Mississippi
Oh dear. I usually park under my parents pecan trees when we tow over to visit. So far we have not used our polished '63 and now I know not to park there.
THANKS!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-25-2013, 08:49 PM   #192
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Angry
Now that's a HUGE bummer!!! Sorry for you......
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-25-2013, 08:50 PM   #193
Streamline Owner
Nolavalkyrie's Avatar
Indianapolis , Indiana
So sorry to hear the news.
Nolavalkyrie is offline   Reply With Quote
Old 09-25-2013, 11:21 PM   #194
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Was it waxed after polish or is that not done?
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-26-2013, 09:41 AM   #195
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
ruined polish job
No! I don't use wax on a polished one. I do use Turtle wash/wax for the up keep during the year or two befor next polish. The sap damage is akin to bird poop staining.
Old 09-26-2013, 02:34 PM   #196
Becky B.'s Avatar
1964 17' Bambi II
Just curious as to why you don't wax? Obviously you don't store it inside.....
Becky
1964 Bambi II
1988 Avion 32S
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
