Old 07-30-2013, 06:36 AM   #169
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Originally Posted by Melody Ranch View Post
I have standardized....all my Airstreams are 6 on 5 1/2.
in 1950 they used a 5 bolt pattern. These seem harder to find.
FC7039 is offline   Reply With Quote
Old 07-30-2013, 07:45 AM   #170
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It is just a matter of ordering. They have your choice.
Old 07-30-2013, 07:47 AM   #171
1999 25' Safari
Somewhere , Ohio
Wow, thank you Robin! I've printed that off and will sit down to give it a read.
Since I haven't read the entire file yet, only bits and pieces, I can only assume the duplicator is for the marking of the new sheet/skin? OMG, what a useful tool.............and I love tools and gadgets! I imagine the file will explain the various sizes of the duplicators, hopefully.
Deb
Air Cruiser is offline   Reply With Quote
Old 07-30-2013, 08:20 AM   #172
1999 25' Safari
Somewhere , Ohio
From the details on the website, I can't tell how you know which strap duplicator you need; I don't see how you can tell what diameter rivet hole the tool fits. I do see they are numbered, but it's like: 51 #40; 52 #30; 53 #21; and 55 #12. I'm also assuming the 6" length is the one we'd use and not the 12", and not the inverted.
Maybe the numbering/sizes has to do with the distance the two ends are apart? That it would accomodate the various thickness of layers.
That last falls into another question I have...........When we ordered our riveting equipment from VTS, I stated that I thought we were going to install some plywood over top of aluminum skins for the interior (in places), and was told that we'd need to use Olympic rivets for that. Do the Olympic rivets have a longer shank on them to go through the thickness of the plywood, aluminum and on into the rib? Or perhaps a larger rivet head to have more "holding" ability so as not to pull through, or perhaps both?
Sorry for asking you all these questions, you seem so knowledgeable about all of this, but I realize it takes up your time to respond and I do greatly appreciate your help.
I guess I can call them and ask all this when I'm ready to order.
Thanks again, Robin as I'd have had no idea that something like this was available.
Deb
Old 07-30-2013, 08:51 AM   #173
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I am guessing that the Olympic rivets were recommended because of the larger bearing surface....required to keep the rivet from pulling thru the wood. Many times a washer is placed under the head to expand that surface.
The hole finder is used by slipping it over the sheet metal The little titty is inserted into the hole to be duplicated. The top of the finder has a fitting on it with a matching hole, aligned with the arm below. You now drill thru that hole , remove the finder, and voila.....a matched, aligned hole for the new rivet.
Old 07-30-2013, 09:14 AM   #174
1999 25' Safari
Somewhere , Ohio
This seems like it would really simplify the process! I am so glad you mentioned these. I can see, tho, that it will not be something to expect to go out and get accomplished in a day, very time consuming.
Deb
Old 07-30-2013, 04:24 PM   #175
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I finally hit a bump
Bump meaning a problem. I spent all day installing the main door seal. I used the original style...rivet it between skins. It looks great. It does not let the door close. It really forces the door alignment..???? I can drill out all those rivets again, pull the seal, re rivet and use an edge cover and a new seal on the door. A definite pain in the derrier. After that I still have to rebuild the main door assembly and a new bronze screen for the door..
Old 07-30-2013, 07:23 PM   #176
mapleton , Utah
Air Cruiser, if you haven't figured it out by now the #40, #30, #21 and #10 refer to the drill sizes for the standard airstream rivets. Read a few of Aerowoods rivet threads and you will soon be less confused (I hope).
Robin, say it aint so on the door seals. I am coming up on that job soon so PLEASE keep us all posted. Hopefully a couple of days on that bright Texas sunshine will soften them enough to fit better. Dont forget a little silicone spray to keep them from sticking too.
Still jealous of you "pod" of whale tails
tim
rumrunner is offline   Reply With Quote
Old 07-30-2013, 07:39 PM   #177
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Door seal update
I got cleaned up, cold shower, a Wild Turkey and went back to the Red Barn to look at the door seal again. It just won't work. Nothing wrong with the installation that I can see. When I force the door closed it warps so much as to strike the body door frame. That wont do. Tomorrow AM back at it.
Name:	door seal 1.JPG
ID:	192090   Click image for larger version
Name:	door seal 2.JPG
Name:	door seal 3.JPG
Old 07-31-2013, 08:32 AM   #178
1999 25' Safari
Somewhere , Ohio
Oh, that's really not good; and now there are those holes. That must have been a sinking feeling. I worry about things like this. We will be coming up onto getting our door sealed sometime in the Fall or before (hopefully), but we also have some work to do on our door, it looks as tho it was bent on the bottom.
And Rumrunner, thanks for the information on what the numbering is concerning, I thought it was probably something like that.
Deb
Old 07-31-2013, 11:56 AM   #179
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
More door
I moved over to the other side of the door. Pulled the skin so I could clean (OCD) and re insulate it. This also gave me a lot of visual time to agonize on the seal problem.
Two things of interest maybe...?
Do you have ANY idea on how much, and what type of, crud is inside that door. You will be surprised.
This is the week where you DO NOT want to have the Airstream anywhere near a Pecan tree. They are showering with that sticky sap. It is particularly bad on polish jobs.
Name:	Door Babs 5.JPG
ID:	192131   Click image for larger version
Name:	door Babs 4.JPG
ID:	192133   Click image for larger version
Name:	door Babs 3.JPG
Old 08-05-2013, 06:11 PM   #180
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
More oor work
Working the door hinge is a real lesson when tweaking both the inner and main doors. Still a work in progress.
ID:	192520   Click image for larger version
Name:	Door rebuilt #2.JPG
Name:	Door rebuilt.JPG
Old 08-06-2013, 11:44 AM   #181
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
meanwhile...
got side tracked with Jims' Caravanner.
Name:	Barn cleaning 2.JPG
ID:	192555   Click image for larger version
Name:	1956 Bubble Babs.JPG
Old 08-06-2013, 03:34 PM   #182
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Lookit all them purty traylahs!!! NICE
Carravanner?????? Did Francisco polish of 4 feet of trailer and make it shorter or wash glare from the shine in your eyes
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
