Old 07-26-2013, 05:34 PM   #155
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
There are days like that
Gripe
and grumble. I had purchased a set of interior lights which I like. Got them and one turned up with a broken lens. The dealer was great and got me a free replacement. What did I do....? Got the new replacement and mixed it with old packing materials.....Yes! I threw it all away. Today as I installed lighting I discovered the stupidity of my actions.
On the brighter side, I am sure there is a brighter side.
Old 07-26-2013, 06:05 PM   #156
mapleton , Utah
Little mistakes like that just remind us that we are human
keep up the good work
tim
rumrunner is offline   Reply With Quote
Old 07-26-2013, 06:57 PM   #157
reinergirl's Avatar
Hollis , New Hampshire
The fact that you are putting in lights is the bright side! Can't wait til I get to that point
reinergirl is offline   Reply With Quote
Old 07-26-2013, 07:15 PM   #158
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Test fit...
Here are some test fit photos. I use this to see that the elec. outlets are, in fact, where I wanted them. It also gives me an idea as to my positioning of the lights....the ones I did not throw away.
I find that installing an outlet, narrow type for the Airstream walls, is not an easy or fun job. It is the old putting 10 lbs in a five lb bag.
Name:	Test fit 1.JPG
ID:	191788   Click image for larger version
Name:	Test fit 2.JPG
Name:	Test fit 3.JPG
Old 07-26-2013, 07:58 PM   #159
1999 25' Safari
Somewhere , Ohio
Hi Robin.
You are doing another fun thing, test fitting! When you had your interior skins off, did you find any of your ribs loose, or not even connected to the one above or below it? We have found that, and we don't even have all of the interior skins off yet.
What made me ask that is I see you are reinstalling overhead cabinets. We've been thinking we probably won't be doing that. Will probably only have upper cabinets where we can have them go down to the floor too.
We are so concerned that we are planning to reinforce the ceiling ribs to make certain they can hold the weight of the ac.
Deb
Air Cruiser is offline   Reply With Quote
Old 07-26-2013, 09:45 PM   #160
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
no loose ribs here.
Other than a "normal" framing (with Aluminum C channels)
the roof is strong enough for your AC.
Some info. Define monocoque | Dictionary and Thesaurus
Old 07-28-2013, 12:19 PM   #161
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
This morning
Fit the lights, riveting in the wall panels, working around to the door where the gasket will happen.
Name:	Led ceiling.JPG
ID:	191922   Click image for larger version
Name:	Led ceiling 2.jpg
Name:	Led ceiling 3.JPG
Old 07-28-2013, 05:02 PM   #162
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
same project later in the day
riveting the panels is a bit more time intensive than I planned. Tweaking the fit so the rivet holes line up is the bad part. The LED lighting works fine with the new Optima battery and I put the beauty rings on the wheels.
Name:	rivet line and zolatone 2.JPG
ID:	191952   Click image for larger version
Name:	Led front side.JPG
Name:	Led test 2.JPG
ID:	191954   Click image for larger version
Name:	tires and caps.JPG
Old 07-29-2013, 08:02 AM   #163
RankAm's Avatar
Dallas , Texas
Robin, what can you tell us about your wheels, rings, and caps? They look very nice, and they look close to vintage. I have the original baby moons from my 56 FC, but I am not sure they are salvageable or will fit on a new wheel. Hank.
RankAm is offline   Reply With Quote
Old 07-29-2013, 08:41 AM   #164
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
The wheels are 15inch, Dexters, from Redneck RV Supply in Dallas. I get my local horse trailer guy to order them for me. I think they are 30 or 35 dollars and come in grey or black. The caps are from the same trailer guy. 10 dollars each. They come in different diameters so make sure they are the ones for the wheel. These caps also have enough "cone" to clear the axle hub. The beauty rings are stainless generic hot rod rings....
Old 07-29-2013, 09:02 AM   #165
1999 25' Safari
Somewhere , Ohio
About the rivet holes................you know so much about all of this, I feel silly trying to come up with a solution, but here goes. How about if you had another pair of hands to help hold the skin and you could either: 1) Hold the new one up beside the rib and place a mark where the hole should be and later decide how far in to drill (say, 1/2" to 3/4" overlap). Thinking about it, if you already had a chalk line on it for the inset for the overlap, you could even just use a punch or awl to mark for your rivet. 2) This one would be really tricky, but if you had something "smeared" around each rivet hole and you could place the new skin right in place over top to mark where the hole should be drilled. I've had to do this in my work before for two or three holes, but haven't tried dozens. As I said, this one could be tricky if you let it slip.
Deb
Old 07-30-2013, 06:20 AM   #166
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Are they 5 on 5 1/2 bolt pattern?
FC7039 is offline   Reply With Quote
Old 07-30-2013, 06:29 AM   #167
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have standardized....all my Airstreams are 6 on 5 1/2.
Old 07-30-2013, 06:33 AM   #168
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Everything you need to know about riveting
Here you go Deb.DRILLING AND HOLE PREPARATION
http://www.skygeek.com/strap-duplicator.html
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
