Old 07-16-2013, 11:08 AM   #141
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Robin
What size Mach 8 did you install and how is the noise with the various fan levels. Is it controlled by a wall digital thermostat?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-16-2013, 02:34 PM   #142
1999 25' Safari
Somewhere , Ohio
Can't wait to see the pics!!
Deb
Air Cruiser is offline   Reply With Quote
Old 07-19-2013, 09:47 AM   #143
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Test flight complete
Got the electrical system in and operational ....The Mach 8 is in and operational. The new axle and brakes are in and operational. New step is on and operational. Propane tanks and regulator on....awaiting line installation. Battery box installed and new battery installed at same time. Took her out for a short tow and hit a mud hole....I need mud flaps.
ID:	191161   Click image for larger version
Name:	progress test flight.JPG
Name:	progress skins electricalPG.JPG
ID:	191163   Click image for larger version
Old 07-19-2013, 09:52 AM   #144
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
interior new skins
5052 alum with the protective coating still in place.
Name:	progress skins left.JPG
ID:	191165   Click image for larger version
Name:	progress skins rear.JPG
Name:	progress skins top.JPG
ID:	191167   Click image for larger version
Name:	progress tront door.JPG
Old 07-19-2013, 09:57 AM   #145
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Mach 8
OK....side by side with a Carrier low profile 15,000 BTU....the Mach 8 is as quiet...slightly quieter than the Carrier....outside. Inside the \Carrier is quieter but this may be because of the superior insulation all around. This was on low fan
When the fan cycled to high there was a slight increase in noise but not to the extremes mentioned elsewhere.
I like. It was 920$ including tax and shipping....the best price I could find without going berserk.
Name:	progress Mach 8 AC.JPG
ID:	191169   Click image for larger version
Name:	progress Mach 8.JPG
Old 07-19-2013, 12:36 PM   #146
Central , Mississippi
Do you have a local supplier for the 5052 with the plastic on it? I forgot to ask my local folks about that option.
I'm still a few months away from needed some but it never hurts to start looking.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-19-2013, 02:15 PM   #147
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes on the supplier. He is in Fort Worth and at 30$ for a 4 x 8 with the coating .....I like it.
Old 07-19-2013, 02:25 PM   #148
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Do you know what he gets for Al-Clad. Or can you PM who he is and I'll call.
Bruce
Old 07-21-2013, 08:47 PM   #149
1999 25' Safari
Somewhere , Ohio
How nice! Everything looks so neat, clean, smooth.............really nice! Glad to hear that the Mach 8 is functioning as you'd like; I imagine that is the one we'll get too.
I can't tell from your pics, but are your exterior end cap skins rounded seams? If so, did you seal them? I guess I'm really asking if there's a need to seal them. I was told those type would never leak due to the fact that they are interlocking seams, sort of like the way the windos fit together -- if our windows are the same, I know you'l understand what I'm trying to say. Thanks.
I really like the work you've been doing.
Deb
Old 07-22-2013, 08:15 AM   #150
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hi Deb....Those end caps were sealed from the inside with a rubberized pray coating....like bed liner. I use it in the wheel wells too. On the outside I use Par Bond after polishing. Those beads on the panel are not seals and probably will leak some if not sealed again from the outside.
Today I go inside and do the riveting of the panels...lots and lots of rivets. I may do some light installs too. I got puck type lights (LED) with individual switches....I still need to find lights for under the cabinets, shelves and the reading type bunk light in the rear corner wall.
Old 07-22-2013, 07:37 PM   #151
1999 25' Safari
Somewhere , Ohio
Thanks, Robin, for that information, now I just need to find out the name of that spray coating. In case you'd like to compare skins or windows, I was finally able to download two pics of the outside of our endcaps, a portion of each, so a front and a rear. You can see that we're still trying to cut through all that oxidation, and then we'll get serious about polishing -- from the top down as you suggested.
I have really messed up -- I should have started a file with suggestions; hints; whatever, I did print off some, but some I thought, "Oh, I'll remember that and where I read that", but, as you might have guessed, I now can't remember it all. Lesson learned.
Hope you were able to get a lot of riveting accomplished today.
Thanks again.
Deb
Old 07-22-2013, 08:38 PM   #152
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
I too put on pray coating. Put it on and pray it doesn't leak.
FC7039 is offline   Reply With Quote
Old 07-23-2013, 08:28 AM   #153
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
one thing I do
On all my Airstreams I am sure to have electrical access outside on the curb side. I even put a 12v plug in on BUB.
Can't see much, but the new axle/brakes/wheels and tires are on too.
Name:	outside electricity.JPG
Old 07-24-2013, 07:16 AM   #154
1999 25' Safari
Somewhere , Ohio
Those electrical outlets on the curb side come in handy. We like to put the picnic table's end close to the trailer under the open awning, so the outlet is used for whatever we have sitting there to be plugged in -- radio, toaster, coffee pot, etc. Especially nice to sit there early in the morning when it's a little cool, a gentle breeze with a nice warm cup of coffee, breakfast, and good conversation with DH.
Couldn't see the axle/brakes, but the wheels and tires look good!
Deb
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
