Old 05-26-2013, 12:32 PM   #127
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Interior skins
Initial fit. Sure enough, just duplicating the originals did not go smoothly. Just enough difference from the new floor and other work requires a lot of hand trimming.
Name:	interior skins 2.JPG
ID:	186564   Click image for larger version
Name:	interior skins.JPG
Old 05-26-2013, 01:26 PM   #128
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Originally Posted by Melody Ranch View Post
Ted, the insulation is one layer of Prodex. Hoping not to become embroiled in the insulation arguments....you know, like tires, axles and batteries....I am now going with 2 inches of pink type modern insulation before the new skins and wiring.
What do you mean retired....under employed? I still do a full Citrus Grove operation in the Rio Grande Valley and a full Horse hay operation up here. Then there is the house stuff, the old car stuff, old airplane stuff, Typical paperwork stuff, maintenance of the place here (dumb, dumb dumb.....I have planted over 600 trees in the past three years during this draught and I have to hand water all survivors on a regular basis. I should retire!
So, did you put the Prodex against the outside wall and the the 2" of pink to the inside and then the skins?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 05-26-2013, 04:05 PM   #129
Central , Mississippi
Those same panels gave me some trouble on my '63. I ended up setting against the wall and on the floor, then ran a sharpie 1/4" off the floor to mark the bottom edge. I finally got a good fit even though they are hidden behind the wrap around dinette.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 05-26-2013, 09:57 PM   #130
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
More tomorrow
Yes Bruce. Prodex on outer wall, then fiberglass then prodex again.
I am doing the same lean into the wall then mark 1/4 off the floor and trim. I am overly cautious of not cutting to much off, so I am in and out of the interior a lot. Time consuming.
Am trying to figure the wiring layout now.
Old 06-08-2013, 07:35 PM   #131
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
wiring
I find it very hard to lay out the wiring when the interior plan is entirely in my head. I have roughed out the dimensions...just that. So now as I put in the wiring, AC and DC, I don't have a warm fuzzy feeling about it all. I continue.....
Name:	Wiring aft rt corner.JPG
ID:	187753   Click image for larger version
Name:	wiring front street side.JPG
Name:	wiring street side low.JPG
ID:	187755   Click image for larger version
Name:	wiring street side high.JPG
Old 06-11-2013, 07:59 AM   #132
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
First interior panels back in.
Got the first roof panel back in. Thanks for Clecos.
Old 06-14-2013, 02:28 PM   #133
1999 25' Safari
Somewhere , Ohio
Hey Robin!
I realize your polishing is done, but you might be interested in reading about a product I tried out today, I posted on our Bubble thread about it. It's "Wizard's Metal Polish" in a tin can. It worked fast and pretty well on the built-up corrosion on our '56.
If you have any info on this product, please share it with me, but so far, it has worked the best for me. I don't know if I have enough strength in my arms to get the polishers to work with the rouge bars, etc.
How are things going on yours?
Deb
Air Cruiser is offline   Reply With Quote
Old 06-16-2013, 09:45 AM   #134
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Deb....I am up for trying anything. I'll let you know.
Old 06-16-2013, 09:50 AM   #135
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
panels and wiring and lights
Been busy with Ranch work. Hay is in....now back to the Bubble. Only one picture and its poor, but you can get an idea.
Name:	panels new aft.JPG
ID:	188375   Click image for larger version
Name:	panels new and electric.JPG
Old 06-17-2013, 11:20 AM   #136
1999 25' Safari
Somewhere , Ohio
Well, I haven't been able to find a way to get this product to stay on a polisher disc, so I'm back to using the rouge bars. DH has a black bar he picked up at a car show a few years ago (also a white bar........I didn't even know he had these), so today I'm going to do the black, grey, see how that looks. If the black doesn't cut the corrosion, I'll go back to the 1500 grit wet sanding, then the grey, pink and white. DH thinks I need to save the "new" product for smaller things, but I still stand by what I said before -- you don't have to rub hard at all, just circular motion until it turns black, wipe off and buff with a clean cloth.
I am envious of the progress you are making, but so glad that you are ahead of us in that we can see the proper steps to take. I really am concerned that we'll skip something important and realize it too late. Your Bubble is looking so good!
Deb
Old 06-24-2013, 08:02 AM   #137
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Texas heat slowing me up
The Mach 8 is here and going in today. I had a mess under the old AC which dictated some work and creativity....Cleaned , corrosion control, etc.
Then I had to work around the hole in the roof where the previous owner had a residential type stack placed above the toilet he had installed. I hate it...but, thats the way it goes. I have a great story about the solar panel/low profile /stainless fan I bought and planned for.....later.
Name:	Air conditioner prep.JPG
ID:	189176   Click image for larger version
Name:	AC drain hose.JPG
Name:	Fan exhaust inside.JPG
ID:	189178   Click image for larger version
Name:	fan exhust outside .JPG
Old 06-25-2013, 09:24 AM   #138
1999 25' Safari
Somewhere , Ohio
We love stories, can't wait to hear about the solar panel/low profile/SS fan.
I see in your one photo that you didn't paint an extended length of white on top, did you only paint the area where your ac will be mounted? (Trying to get tips for our use.) Also, saw your clear hose for the condensation on the ac, but it looks rather short. Does it attach up to another hose line which is mounted behind the insulation? (Needing tips here too.) You should know me by now -- always full of questions, trying to learn.
Also can't wait to hear what you think of the Mach 8's ability to keep up with the outside heat and noise level.
Thanks so much for sharing.
Deb
Old 06-27-2013, 06:13 AM   #139
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
progress
Mach 8 is installed. fishing the wires thru the new panel so I can install light fixtures and get ready for the re-rivet job.
Old 07-16-2013, 07:40 AM   #140
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
lots done
There has been a lot of progress...not that you could tell....Today the original axle has to go. Not because it's old....I like the spring types. It is the spindles. They are way to small for newer type brakes and hubs. So, like I did on Bub the Bubble....a new straight axle goes in today. I actually like the lift I now get from it. Pictures tonight.
Bought some Worthingtons from a Forum member and they, with the propane set up, are installed too.
Polished aluminum Battery box from Summit Racing also in place.
The new Mach 8 makes it a pleasure to work inside....beat the Texas heat.
[IMG] code is Off
Land Yacht MH Special or Limited Editions Road Dawg 36 Land Yacht/Legacy Motorhomes 2 01-21-2012 07:16 AM
Bambi 19 Special Edition :: 2006 Airstream Bambi mocus Airstream Registry Discussions 1 01-18-2012 09:22 PM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
