View Poll Results: What do you think the bubble "dry" and tongue weight results were on 2/18/11?
2,054 lbs total 253 lbs tongue 4 33.33%
2,332 lbs total 312 lbs tongue 5 41.67%
2,560 lbs total 386 lbs tongue 2 16.67%
2,745 lbs total 390 lbs tongue 1 8.33%
Voters: 12. You may not vote on this poll
Old 06-23-2013, 12:25 PM   #351
1999 25' Safari
Somewhere , Ohio
Hi Ted.
I have a question regarding the Marmoleum flooring in your Bubble. Do you recall being told to not put sealant on your subfloor because of the installers needing to put down luan sheeting for the Marmoleum? And with this I mean I thought I'd been told or read somewhere that they like to use adhesive to put that luan down with and of course it wouldn't adhere to the subfloor if a heavy sealant had been used.
I liked what Shelly did in her Overlander with the epoxy sealant on her subfloor and the thought of not having to worry about floor rot in the future due to leaks, but that could be a problem with luan not adhering. Although, I was wondering why couldn't they use heavy-duty staples or, I guess, some sort of screws to put the luan down with?
Do you have any advice or thoughts on all of this? (Trying to get it right the first time.) Thanks so much.
Deb
Air Cruiser is offline   Reply With Quote
Old 07-01-2013, 03:23 PM   #352
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
as I did all the prep for the marmoleum. the installer asked me to leave bare plywood sanded smooth with a radial sander. he did the rest with the glue and such. I'd suggest ask the company you're working with first. cheers. Ted
the544man is offline   Reply With Quote
Old 07-01-2013, 03:25 PM   #353
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
just back from a trip to central Oregon with the boys. we camped at coldwater cove on clear lake, canoed, fished, hiked on the pacific crest trail, and did a few things In between. love the area next door to us. cheers. Ted
Old 07-02-2013, 07:29 AM   #354
1999 25' Safari
Somewhere , Ohio
Thanks, Ted, for the information on the marmoleum installation.
It looks as though your boys, as well as yourself, really enjoy being out with "mother nature", how nice! As I'm certain you've heard before, enjoy your boys now as they grow up so quickly.
As you've been using your Bubble, is there anything you now wish you'd done differently?
Deb
Old 07-06-2013, 09:24 AM   #355
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
lets see. what would I have done different after the fact? only a few things come to mind.
1. maybe install the water pump switch all the way over next to the sink (it's right next to the dinette close to the breaker box now)
2. buy a Dremel tool earlier
3. I really only need one propane tank but two brand new aluminum ones with double mounting hardware were included when I bought it
4. I may have tried installing another overhead cab instead of building a countertop cab for more open feel
5. I could have buried the water pump under my rear fixed bed but its nice being able to see it knowing there's no leaks in all the connections
6. a clothes hamper? but where?
7. door latches on the big heavy cabinet drawers. they usually stay shut but a couple have slid open on a wicked unexpected mtn curve
8. build some cabinet dividers for storing stuff ( I can do this now that I know what I take and don't need when camping)
9. I haven't used my propane catalytic heater yet. could have skipped perhaps
10. I still might build a rear spare tire carrier? I designed the rear hatch to hold it currently
11. install the same blinds earlier
12. install a pullout cutting board ( then you not have to store one in a drawer)
13. install a wine celler
cheers. Ted
Old 06-11-2014, 05:58 PM   #356
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
Name:	ImageUploadedByAirstream Forums1402530672.862179.jpg
ID:	214060Click image for larger version
Name:	ImageUploadedByAirstream Forums1402530692.486663.jpg
ID:	214061Click image for larger version
Name:	ImageUploadedByAirstream Forums1402530714.277109.jpg
ID:	214062Click image for larger version
Name:	ImageUploadedByAirstream Forums1402530735.036284.jpg
I just installed 5 more restoration hardware latches on my drawers today. Every once in a while, even though the drawers have a friction/RV stop on them when closed, over certain off camber curves I would find one extend open during the ride. Now they're secured for serious dips and bumps in the road! The annual boys trip to Clear Lake in Central Oregon is in a week and a half! Cheers ted
Old 06-11-2014, 06:01 PM   #357
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
Name:	ImageUploadedByAirstream Forums1402531183.798881.jpg
ID:	214064 I installed them on the fridge side cabinet too. I still haven't build my Bubble--bubbly wine cellar yet though. Anyone have an idea of what i should put in the lower left hatch where 4 bottles will fit? I have to deal with the wheel well so I've got to creat something for vertical storage. There's not a lot of wiggle room but something has gotta work--i just havn't nailed it yet in my brain. stay thirsty my friends--ted
Old 06-13-2014, 11:26 PM   #358
ASTailgate's Avatar
1981 28' Airstream 280
I like!!!
ASTailgate is offline   Reply With Quote
Old 06-17-2014, 03:52 PM   #359
1956 16' Bubble
Landrum , South Carolina
Images: 20
That looks really good.
OkieHB is offline   Reply With Quote
Old 06-17-2014, 04:42 PM   #360
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
more shiny stuff usually looks cool in airstreams!--cheers--ted
Old 11-02-2014, 05:49 PM   #361
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
You should consider a felt wine rack/holder. Google them. They might be perfect for that spot.
http://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 04-13-2018, 06:47 PM   #362
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
Deb—sorry I havn’t been on the forum for a long time since i finished the bubble. I’m sure you have your answer by now though. I prepped the floor by getting a nice sanded and firm plywood finishe and hired out the marmoleum install so I really don’t remeber what they did . Cheers!
1956, bambi, bubble, craftsman, custom, mission, rebuild, restoration
[IMG] code is Off
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
The start of '73 Overlander restoration Lothlorian Repairing/Replacing Floor &/or Frame 134 10-24-2011 08:23 PM
1956 Airstream Bubble Restored [Nice] eBay Watch Airstreams on eBay 0 07-07-2009 07:50 PM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
New tires for my 1956 Bubble.... kzener40 Tires 8 07-27-2002 12:41 PM
