Old 10-06-2018, 08:22 AM   #141
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Originally Posted by 57Vintage View Post
I may be mistaken, but I don't think the door stop you replicated was original. These are identical to the ones I took off my rig.
Attachment 324479
The small one hold the inner door. The large one is a door stop and holder combined. VTS sells both.
That is interesting...my rig never had a stop...just the catch. Maybe these were aftermarket items.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 10-08-2018, 04:16 PM   #142
1956 22' Safari
Williston , Vermont
Door Stops
I bet you are right. I know exactly the VTS stop 57Vintage is talking about, I bought one and decided not to install it. It looks like it would install in the top two rivet holes of my original stop. But then I would have had to plug the holes from the original catch plus the lower two from stop. Decided to just rebuild what was there.
Hard to believe they wouldn't put anything to keep the door from banging.
Mark
Our restoration Blog
steinVT is offline   Reply With Quote
Old 10-09-2018, 03:55 AM   #143
1956 22' Safari
Williston , Vermont
Fantastic Fan Installation Upgrade
After listening to countless VAP podcasts, one of the first things we purchased after we got the trailer was a fantastic fan. The old exhaust fan was bent and 115v and one of the lifters was broken. I got the light grey one from Vintage Trailer Supply so I thought it would blend in well enough.
Researching installation tips on these forums, I came to the conclusion that they seem to work great for about two years and then a lot of them start to leak. I am guessing a combination of the supplied wedge shaped screws and UV degradation.
So here is what I am proposing to do, looking for any reasons its a bad idea:
1) Cut a flange out of aluminum that will cover the plastic flange that is screwed to the roof. Maybe an 1/8" oversize
2) Add a second layer of the gasket material under the outer edges between the roof and the flange to account for the roof curvature.
3) Bed everything in Sikaflex; roof, gasket, gasket add-on, plastic flange and aluminum flange.
4) Screw to the roof with SS pan head screws with SS fender washers.
I also discovered my original Airstream aluminum vent fits over the plastic Fantastic Vent cover like a glove. I didn't think I would get the test fit apart. I am thinking to buck rivet the holes closed, polish it and then bed it in with some Sikaflex.
And then finally I believe with some slight modification, I can use the original inside trim ring and not the big plastic thing.
Whatya think?
Old 10-09-2018, 06:19 PM   #144
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I think it sounds like a great idea. The fantastic fan runs quieter and moves much more air. Incorporating some of the original trim pieces will help disguise the new fan some. I'm confident your installation will not leak.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 11-11-2018, 08:00 PM   #145
1956 22' Safari
Williston , Vermont
It's been a while since I have posted. It's because most all work on the Safari has ceased. Last fall was amazing with clear sky's and warm temps. Not so this year, currently is 38 degrees and raining. I had hoped to have painted the Zolatone and installed the floor before we put it down for the winter, but gave up on that a couple of weeks ago. The good news is it is ready for both but I needed warmer temps, especially for the Marmoleum. I have painted cars when it is freezing out side and I really don't want or need to do that again.
In order to get back some use of my basement, I have been fitting all of the interior back into the trailer. I would have done a test fit anyway and it's probably better to do it without the paint and floor. When it's all installed (temporarily screwed in place), I am going to park it in my barn for the winter.
Seeing the refinished furniture in place, even without the floor and wall paint makes me excited for next spring. Projects over the winter include laminating new counter tops and polishing the new Aluminum propane tanks.
Old 11-11-2018, 08:24 PM   #146
1966 22' Safari
Fredericksburg , Texas
Great job on the gauchos Mark. Looks like amber shellac. I donít know if Iím capable of building the stuff in the shop and transferring it to the trailer and it fit. Iím starting in the morning on the plumbing rough-in and electrical trim out. Next week will be the gaucho rough in. I understand the temperature requirements for the Zolatone and Marmoleum. Good luck and hope you get a break in the weather. Great progress. Bubba
Bubba L is online now   Reply With Quote
Old 11-12-2018, 05:50 PM   #147
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Always great fun to put things back together and start seeing the fruits of all your hard work.
We had 12" of famous Colorado powder snow yesterday and last night. Very pretty and easy to deal with. Winter and the cold temps certainly shuts down the Airstream projects. I'm very fortunate to have a building where I can continue on working. Actually I get more done in the winter than the summer.
David
WBCCI #8607
VAC Region 11
Old 11-13-2018, 05:42 AM   #148
1956 22' Caravanner
Just think now you have time and can read everyones else's blogs and get new ideas and change everything that you have done..LOL
Old 11-15-2018, 04:49 AM   #149
1956 22' Safari
Williston , Vermont
Last Monday started sunny but cold so I decided this would be the day to move the Safari to the barn.
I must say in it's maiden voyage, the trailer tracked beautifully. Must be that balanced running gear.
Once to the barn, we had to figure out the last 50 feet. Mower to the rescue. It even was a slight incline. Glad vintage is so light.
Because of other projects, the only way to get it to fit was to remove the screw jack and slide the tongue under the rear end of the MB.
Glad I did it when I did because this is what I awoke to on Tuesday morning. And more is on the way.
Old 05-29-2019, 07:58 PM   #150
1956 22' Safari
Williston , Vermont
I'm Back.......
After a long winter and a very wet spring, my Airstream restoration season has officially started back up. I still have a couple of weeks of full time employment before I start my summer half time schedule, so only little projects at first.
My next big projects will be spraying the Zolatone and then installing the Marmoleum. Looking forward to installing all of the furniture and getting my basement back.
I have registered to the North East Regional Rally of the Tin Can Tourists that takes place on on September 12th. So I have an end date. Better get to work, I have a lot to do.
Old 05-29-2019, 08:17 PM   #151
1956 22' Safari
Williston , Vermont
Replacing a section of the NEW floor
There was one section of floor that I was never quite happy with. Because of the line up of the 4x8' plywood sheets, there was an unsupported joint right at the entry way. It was braced underneath with an aluminum sheet and I had fabricated an riveted end cap. It felt plenty strong, but I can imagine it starting to show though the marmoleum after a couple of years of traffic.
As painful as it was, I cut out a section and replaced it with a single plywood piece is supported by the frame and two outriggers. Sealed all the edges and glued and screwed. Seems very solid.
Still debating whether I want to put 1/4" underlayment over all of my 3/4" plywood base. This was suggested by an marmoleum installer. By staggering the joints, I think it would make a great base even in a flexing trailer.
What do you guys think? I am not a fan of the extra cost and weight. I would have to cut 1/4" off of all the partitions, not a big deal, but one more thing to do.
Old 05-29-2019, 08:38 PM   #152
1966 22' Safari
We installed Marmoleum in both our trailers. I was apprehensive about their recommendations to install the 1/4Ē plywood. We did install the plywood per their installation directions. Glad we did. Marmoleum seems to be pretty thick but imperfects seem to telegraph through to the surface. We stapeled per directions and hammered the staples to make sure they were flush. It wasnít a problem adjusting the height of the bulkheads. Thatís my thoughts. Good luck
Old 05-30-2019, 06:18 AM   #153
1956 22' Caravanner
That is so different than here in FL. I am thinking OK 1 more month before we pull the plug and head north to get out of this blistering heat
Good thing to have light at the end of the tunnel...I am still lost haha!
Old 05-30-2019, 07:02 PM   #154
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi stienVT: Glad you made it through the winter. We had snow last week, but warmer today. It has been a long winter.
Good call on the entryway. Your extra inlay there does look very solid.
I too went through the time and expense to put down a 1/4" underlayment in our 86 Limited. Then I laid a cork engineered click type floor down on top of that. This was ten years ago and so far it has all stayed together nicely.
I vote for more work for you.
David
WBCCI #8607
VAC Region 11
« It's a girl!!! | Top | - »
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
Airstreamer Matthew McConaughey named hottest bachelor. Sean Michael Airstream "In the News" 1 06-15-2007 08:43 PM
What is this material named? Sanders General Interior Topics 2 09-27-2004 03:51 PM
"Streetcar Named Desire" movie coach??? fangthorpe Airstream Motorhome Forums 1 05-13-2003 06:27 PM
