Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1956 Safari
Old 09-04-2007, 12:01 PM   #113
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
A picture is worth a thousand words....
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 09-04-2007, 12:27 PM   #114
47WeeWind's Avatar
Profile:  1948 16' Wee Wind
Denver , Colorado
Images: 13
Originally Posted by InsideOut
A picture is worth a thousand words....Shari
Nice '56 Framestream!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
47WeeWind is offline   Reply With Quote
Old 09-05-2007, 05:38 AM   #115
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Shari
Oooooooooooooh the possibilities!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 09-05-2007, 06:03 AM   #116
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
You are making great progress so far!
Good find on the vintage awning! Have you finalized your plans for the interior layout yet? My '54 Flying Cloud has the same interior layout (with kitchen in the front and side dinette) except we have twin beds in the rear instead of the double bed.
WBCCI Region One
Attitude is the only difference between ordeal and adventure.
yukionna is offline   Reply With Quote
Old 09-05-2007, 07:57 AM   #117
Addicted to Aluminum
A-Merry-Can's Avatar
Profile:  1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i love the flying cloud! beautiful. ONE of these days i'll get my 4th... convincing the misses on a second trailer was easy, the third took some work... i haven't figured out my approach for the 4th request yet... maybe if i move into it? ha!
seriously, though 13 panels have always been my fav! good progress on a great trailer!
jp
8576 • • • • • • • •
there's always room for one more!
• • www.toolbox-design.com • •
A-Merry-Can is offline   Reply With Quote
Old 09-05-2007, 09:56 AM   #118
InsideOut's Avatar
1956 22' Safari
Images: 87
Thanks!
While peeling back the layers of the onion, we discovered that Birdy originally did have twins. The double layout she had when we got her was obviously retrofit. We found attchement holes and marks on the floor from twins. So we will be restoring to the original twins configuration.
We feel we are very close to the end of the destruction stage...just about ready to start moving forward instead of backwards.
The only remaining demo is to strip the paint from the upper half of the interior. Then we start reassembling from the floor up and other ammenities can be addressed.
Shari
Old 09-05-2007, 10:25 AM   #119
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Do you plan on doing anything with the "beauty mark" on the aft street side lower panel while you have everything opened up?
Kip
Old 09-05-2007, 10:40 AM   #120
InsideOut's Avatar
1956 22' Safari
Images: 87
Beauty Mark...
Yes, we are going to try and work it out from the inside. We have some auto body forms that should work being we can get to both sides.
Also, we will most likely be replacing the entire 3'x12' streetside panel - both inside (post #108) & out. Why? Outside there are several rough holes that were cut for water, electrical, antennas, ??? that we don't need or want, as well as a couple of scratches that will be difficult to buff out. If we replace the panel they will be gone and polishing will be much easier and no fake "access panels" or patches will be required - if not, they will "bug us" - so, if not now...when? While the interior is out, we will be able to use bucked rivets if we were to do it later, they will have to be olympics. The cost of the aluminum is not an issue - it's <$250. It's just that everything is apart and accessible - now, so with all we are doing I think we will regret not doing this if we don't.
Shari
ID:	44440   Click image for larger version
Old 09-05-2007, 10:45 AM   #121
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
That's what I said with my 18 footer... ended up replacing every single panel except the end caps! ha!
jp
Old 09-05-2007, 10:49 AM   #122
InsideOut's Avatar
1956 22' Safari
Images: 87
jp
It's a slippery slope isn't it!
Shari
Old 09-05-2007, 11:59 AM   #123
InsideOut's Avatar
1956 22' Safari
Images: 87
Okay, back to the fun stuff!
I got these on ebay...
Shari
Old 09-21-2007, 04:20 PM   #124
InsideOut's Avatar
1956 22' Safari
Images: 87
Updates:
Last weekend we put in a second sewer line so both Birdy & Maxwell will have their own - one on the front portion of the slab (for Birdy) one in back (for Maxwell - existing). Also cut out the step so we can have new side brackets made. One is broken, which is why it was loose. We're also replacing the mangled back cross member on the frame and adding an outrigger to the front for added support where the new black tank is going. All these steel pieces are being made by Timeless Travel here in Arvada since we don't have the "big tools" to break metal. Then we need to line up a mobile welder to come by...those guys are SO flakey!!! Can't get them to even return calls....
We also ordered our black & two grey tanks this week - all are custom sizes/shapes to maximize their capacities. The black will be above the floor and the two greys below the floor within the frame - not much except the fittings will be below the belly when we are through.
This weekend we are removing an old tree stump in preparation for the new 30'x22' slab we have planned. And will also meet with the concrete guy to get a final quote. Hope to have the slab done in 2-3 weeks. Once it is - we should be able to bring Maxwell home. If we time this right, it will be about the same time we will need to winterize him - no need to winterize Birdy this year, that's for sure!
This weekend we also plan on getting started (& finished - I hope) stripping the upper half of the interior walls. All the lower panels were removed (to get the floor out) and they are already stripped. I have two gallons of Napier, since everything is out of the trailer, we are going to brush it on and (hopefully?) hose it off - may rent a power washer because our water pressure is pretty low - we'll see how that goes. I really don't want to have to get into scraping every little square inch like I have been doing with the cabinets - which are coming out GREAT! The birch is really pretty.
If we have time leftover (haha!) we will start working on smoothing out the banana wrap dents...so once the tanks come in we can get the floor in and close things up again.
Busy weekend...oh joy! I'll post pics...should be interesting.
Shari
Old 09-21-2007, 05:33 PM   #125
Aerowood's Avatar
Arvada , Colorado
Where are you getting the tanks made at?
Kip
Old 09-21-2007, 05:54 PM   #126
47WeeWind's Avatar
Denver , Colorado
Images: 13
Okay, back to the fun stuff! I got these on ebay... Shari
I really like the beauty rings on your cookware. Greetings from the gang at Zion NP! Miss you guys, so we'll have to drink your share of the Margs. What are friends for, eh? Work hard this weekend; we'll be thinking of you!
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 22 09-28-2006 03:38 PM
Its a Girl! smily Our Community 27 07-25-2004 01:15 PM
It's a Girl!! Towhead Our Community 9 05-16-2004 03:19 PM
past history of an old girl flamingo-kid1 Our Community 1 07-17-2003 10:13 PM
How much invested? Safari Tim Our Community 28 06-24-2003 12:47 PM
