Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1956 Safari
Old 03-16-2008, 08:21 PM   #169
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We had hoped to get the frame welded sooner, so we could paint it before winter hit...thus be able to get the floor in and work throughout the winter. Didn't happen. So we had to wait for a day on a weekend to hit 50+ degrees so we could paint the frame. Finally, the end of February - even though there was snow still on the ground, we had a weekend of nice weather where we could but a propane heater inside the trailer and bring the tempurature up high enough to paint...which we did. Two coats of POR-15...did I mention we are doing a shell on floor replacement? Once the floor is in place and the shell re-attached, we will be dropping the belly pan to paint the underside of the frame.
ID:	56370   Click image for larger version
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 03-16-2008, 08:28 PM   #170
drag'nwagon's Avatar
Profile:  1974 31' Sovereign
1956 26' Cruiser Overlander
Lambertville , Michigan
Shari,
It is a great day when you get to work on vintage units. Glad your back posting again, we will be following your thread.
Dave
Operation "Save Rudy" Strike Team (charter member)
You mess with the Strike Team,... you mess with the whole trailer park!!
drag'nwagon is offline   Reply With Quote
Old 03-16-2008, 11:22 PM   #171
InsideOut's Avatar
1956 22' Safari
Images: 87
In the meantime, we have totally dismantled the door (found more resident yellow jacket nests) to replace the screen and fix the lock. We picked up several broken locks through ebay and ended up with enough pieces to have a working set and a back-up set and a few spare pieces. They are all out at the chrome shop...should get them back this week.
Shari
ID:	56385   Click image for larger version
ID:	56387   Click image for larger version
ID:	56389   Click image for larger version
Old 03-16-2008, 11:34 PM   #172
InsideOut's Avatar
1956 22' Safari
Images: 87
We re-screened the door with galvanized screen, fit the new insulation and then put our newly learned rivet bucking skills to the test. The door went back together rather easilt...no extra parts! Clecos are an amazing tool...nothing would substitute! The copper ones are smaller and those are where the pulled rivets go...the black are for the bucked rivets.
Oh yeah, once we got done putting everything back togehter - we polished the inner door a "first pass"...it'll be the only thing polished for quite some time ~ now we're just waiting on the hardware to come back ~ then we can seal her up!
Shari
ID:	56396   Click image for larger version
ID:	56398   Click image for larger version
ID:	56400   Click image for larger version
ID:	56402   Click image for larger version
Old 03-16-2008, 11:54 PM   #173
InsideOut's Avatar
1956 22' Safari
Images: 87
This weekend, we finally got two sheets of the floor in! We used 3/4" marine grade A/B plywood. First we cut sheets (measure twice - cut once...especially @ $75 per sheet) then painted the edges with oil-based paint. The front and back curves are each one piece - no seams. It was no easy task, but do-able...each were eased (sloooowly) into place with a hammer. The shell & belly are loose from the frame so the skin is pretty flexible - enough that they could be inched in a little at a time. We used elevator bolts to attach the plywood to the frame where we could access it and get to the back side and self-drilling floor repair screws where we couldn't. Then hammered over the elevator bolts just like the originals were.
Shari
ID:	56404   Click image for larger version
ID:	56406   Click image for larger version
ID:	56408   Click image for larger version
Old 03-16-2008, 11:58 PM   #174
InsideOut's Avatar
1956 22' Safari
Images: 87
I didn't take any pictures with all the bolts in place...I will post them later.
We also got the three remaining floor pieces cut and painted ready to be installed next weekend...or maybe after work this week...but we are supposed to get 6-10" of snow tonite & tomorrow, so we'll see ~
Enough for now...glad things are finally moving along again!
Shari
Old 03-17-2008, 12:05 AM   #175
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Congratulations to the both of you. Getting that much of the floor in is a milestone and to be doing it in the chilly temps you guys must be having makes it all that much more rewarding. One question - what's holding the shell to the frame? You guys must be having a few winter winds up that way.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 03-17-2008, 12:17 AM   #176
InsideOut's Avatar
1956 22' Safari
Images: 87
It does...and now with Daylight Savings Time and warmer weather on the way (not tonite!) we will be able to work in the after work soon!
Nothing really...the belly pan, c-channel and body are all attached. The belly is attached to the underside of the frame and the c-channel/shell is held up with 3/4" blocks of wood and c-clamps at each outrigger and the front & back of the frame. The ribs come down and rest on the wood blocks which are kinda wedged in there. We took them out a couple at a time to paint. Now that the front and back are in, the blocks have been removed.
Here's an older picture that shows the wood & clamps in place. It's been like that thoughout the winter...no problems, but it certainly couldn't be moved!
Shari
Old 03-17-2008, 06:32 AM   #177
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Originally Posted by InsideOut
...Once the floor is in place and the shell re-attached, we will be dropping the belly pan to paint the underside of the frame.
Looking good! How do you keep all the insulation from dropping out of the floor when you drop the belly pan?
WBCCI Region One
Attitude is the only difference between ordeal and adventure.
yukionna is offline   Reply With Quote
Old 03-17-2008, 08:06 AM   #178
InsideOut's Avatar
1956 22' Safari
Images: 87
Right now it's placed there temporarily with tape holding it up...when we drop the belly we will attach it to the plywood from underneath.
Shari
Old 03-17-2008, 08:15 AM   #179
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Shari
Shari,
I was able to slide whole floor pieces into place last week, while replacing the flor on a client project. The shell is flexible enough to over-extend enough to where the sheet slides in towards teh street side, then past ( slight stretch of the shell outwards) and then back under the curbside c-channel. That way the sheets retain their integrity and strength. No center seams necessary.
Congrats on the great progress.
Uwe
www.area63productions.com
Old 03-17-2008, 09:04 AM   #180
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Thats the same same way that I did it too.
Aerowood is online now   Reply With Quote
Old 03-17-2008, 09:19 AM   #181
InsideOut's Avatar
1956 22' Safari
Images: 87
Originally Posted by Uwe
I was able to slide whole floor pieces into place last week, while replacing the floor on a client project.
Nice to hear we are in good company! We didn't want seams down the middle and for our own reasons, chose not to do it shell off. So far it's working out fine...
Shari
Old 03-17-2008, 09:29 AM   #182
Ken J's Avatar
Profile:  1958 26' Overlander
Tijeras , New Mexico
I did the seam down the middle - you learn things after you do it - if I did it all over again, I would do it as you have done and I would have used 3/4" plywood.....
No need to take the shell completely off - I did mine with just a few rivets holding in the front - scary, but it worked well.
Ken
1958 Overlander
Ken J is offline   Reply With Quote
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 22 09-28-2006 03:38 PM
Its a Girl! smily Our Community 27 07-25-2004 01:15 PM
It's a Girl!! Towhead Our Community 9 05-16-2004 03:19 PM
past history of an old girl flamingo-kid1 Our Community 1 07-17-2003 10:13 PM
How much invested? Safari Tim Our Community 28 06-24-2003 12:47 PM
