Old 08-19-2019, 05:47 PM   #1
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
Wiring question......
SO I opened the covered access in the front of the 58. I have a total of 4 small blue wires. I have traced 3 of em to running, left, and right lights. There is a red sheathed 2 conductor which goes to the brakes, and a 12ga 2 conductor that I believe goes to the 12VDC light on the ceiling.
My question is what that last small blue wire goes to. Anybody have a thought? There are no backup lights.
badpaddler is offline   Reply With Quote
Old 08-19-2019, 05:58 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Tag light?
Airstream Ambassador
Instagram @Airstream_Nuts_And_Bolts
Airstreamnutsandbolts@gmail.com
Dept of “Overkill”
Old 08-19-2019, 07:38 PM   #3
1966 22' Safari
Fredericksburg , Texas
Originally Posted by GMFL View Post
Tag light?
That would also be my guess. It has to get 12vdc from somewhere to illuminate the license bulb. Mine does and it’s the same configuration.
Bubba L is online now   Reply With Quote
Old 08-19-2019, 08:49 PM   #4
Images: 59
It is a separate wire which powers the brake lights.
In 1958 there were separate circuits for the right turn signal, running lights, left turn light, and a separate wire for the brake light filament.
Name:	59TW Connector.jpg
« Window hardware | Top | - »
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
hitch wiring question Craig Lights - Interior & Exterior 4 07-18-2004 06:09 AM
Brake/Turn Light Wiring Question (late 70's) DPeakMD Electrical - Systems, Generators, Batteries & Solar 3 07-14-2004 12:46 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 02:08 PM
