Old 02-20-2019, 05:56 PM   #1
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
Window hardware
Does anyone know where to find a window, or window hardware for a 58 Globetrotter?
Seth
badpaddler is offline   Reply With Quote
Old 02-21-2019, 04:21 PM   #2
Central , Mississippi
Was '58 a transition year going from the bent sheet metal windows to the extruded/welded frame version? Several folks (myself included) have built the old style, some parts are available from Vintage Trailer Supply. The extrusions for the newer style, hummm, seems I saw those also there. Either way it's probably a diy kinda situation.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-27-2019, 09:33 AM   #3
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
They completely removed the window and put in a vent for a dometic fridge. I am hoping to put in a force air vent system for the fridge, and vent it out the bottom, so that I can do away with the vent on the outside, and bring back the window. I have use the extrusions to make hatches on the 67 before, but the 58 is a new critter to me.
Old 03-05-2019, 10:07 PM   #4
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
It looks like 58 was the last year for the Hehr windows.hey left the frame in, and just went over with a piece of Aluminum on the outside.
Old 03-06-2019, 04:47 PM   #5
Yeah, it was a transition from the folded sheet metal Hehr design to an extruded rim Hehr, called a Clearview if I recall. The folded version can be built from sheet metal and the parts from VTS. I've made a few. The first attached photo is the later Clearview Hehr. The second is a built version I never cut out the glass hole.
ID:	335080   Click image for larger version
Old 03-07-2019, 09:05 AM   #6
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
The ones on the other side are not extruded. You had to use a brake for folding yes? Click image for larger version
Old 03-07-2019, 09:26 AM   #7
Window hardware
Perfect photo. Your front and rear windows are new style and the sides are old from what I can see. The opening portion of the side ones can be recreated by a folding break and flat sheets and using an extrusions from VTS, the only unavailable and terrible to recreate part is the rolled hinge. I've seen folks use piano hinge in its place.
Old 03-07-2019, 09:06 PM   #8
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
That is what I like to hear! Which extrusion do you use? Do you by chance know of a step by step pictorial for making the side ones? I can always make a break if needed.
Old 03-09-2019, 12:03 PM   #9
This is the one piece made by vintage that makes it possible.
https://www.vintagetrailersupply.com...-p/vts-878.htm
If you remove a side window, it's possible to see how the folds are made from flat stock. You will need a finger style pan brake and the bending sequence is very specific, certain bends can't be done in the wrong order or you back yourself into a corner. An experienced sheet metal fabricator is a good buddy to know!
Also, you can't use 2024T3 alclad, the folds are too tight and it will crack. I used 3003.
I was able to build one section of the rolled hinge but it took some specialized dies for the brake and a huge number of trial and failure hours. I'd just use a piano hinge and hide it below the drip cap.
Old 03-14-2019, 07:50 PM   #10
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
Any interest in possibly making a window for me (or know someone that can do the sheet metal portion)?
Old 03-20-2019, 04:50 PM   #11
Check with Islandtrader, he had one made and might be able to point you to his supplier
http://www.airforums.com/forums/f115...ml#post2211166
« Tank location | Top | - »
window hardware question 2007 Classic side window PatandLane Windows & Screens 0 10-28-2018 07:34 AM
Phillips window hardware IndyAnne Windows & Screens 39 10-16-2013 07:25 PM
Window Hardware on '69 Sovereign ??? tdoescher Windows & Screens 1 08-03-2009 02:57 PM
Window Hardware Removal Question hockeyrink Windows & Screens 1 06-15-2008 02:46 PM
1959 Window Hardware Over59 Windows & Screens 5 05-27-2004 04:08 PM
