Old 10-28-2008, 10:57 PM   #1
1954 18' Wanderer
Thousand Oaks , California
1954 18 footer
Can anyone tell me the overall height of a 1954 18 footer? I am considering transporting one from out of state and I need to know if it will fit in my carport. I would very much appreciate it if someone can measure, or happens to know, the height from ground (tires inflated) to the top of the roof vents. Unfortunately I cannot access the trailer until I will be moving it. Many thanks.
lunartic is offline   Reply With Quote
Old 10-30-2008, 12:04 PM   #2
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
My 1951 Flying Cloud is 7'11" with 215 x 15 tires on it.
Mine does not have A/C
That height does not cover the two vents on top which are about 6" to 9" each in height (guessing on that)
If yours has the original split rims the wheel size is 16.5 so you can count on more height there and it also depends on how sagged your springs are.
My best guess is that you should allow for up to 10'.
I hope that gives you some idea, but again, slightly different model and a couple of years older.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 11-01-2008, 04:34 PM   #3
1954 18' Wanderer
Many thanks, Barry, for the information. In addition to your reply I also found a posting with a copy of a 1954 brochure which specs the overall height as 8'-4". So, I'm hoping that I can squeeze the trailer underneath an 8'-6" clearance. Perhaps I'll need to deflate the tires a bit to make it!
I really appreciate your reply, along with the wealth of info shared by other kind members.
Thank you.
Old 11-04-2008, 01:12 PM   #4
safari57's Avatar
1960 24' Tradewind
West Coast , BC
If you find you need to deflate the tires by a lot a consideration would be to pick up an extra set of rims with very low tires on the (in height terms) that you use just for when it is stored. Extra work of course to change them but just as a thought.
Glad to have been able to help out. Let us know how things go for you.
Take care,
Barry
Barry & Donna
« - | Top | - »
1954 Wally Byams Holiday rickdb1 Airstream History 34 07-06-2008 06:08 PM
New (to us) 1954 Safari yukionna 1954 Safari 20 03-27-2008 06:26 PM
1954 Airstream Flying Cloud baxscott Member Introductions 5 06-26-2006 11:40 PM
Ad for 1954 Airstream Safari yukionna 1954 Safari 6 08-21-2005 04:42 PM
1954 Safari floorplan yukionna 1954 Safari 2 08-12-2005 09:40 PM
