07-14-2017, 09:46 PM
#221
On adventure with H&G
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Curbside window installation
It continues to seem very odd to me that windows and panels never really line up as before. “How did you spend 60 years like this and not line up? Nothing has changed, only less dirt.” Once I did get it pretty close, I finished cleaning up the original sealant in order to put in new Trempro and butyl tape inside and outside respectively.
First one and then the other window is riveted through the back frame seal. One of the problems with the windows in this configuration is that the frame and sill are very close to the vertical rib and prevent the bucking bar from fitting in far enough to touch the rivet for bucking. My son, bucking for me, used the enclosed end of a 1-1/4” wrench to buck the vertical line of rivets between the window and rib. Easy enough once we figured what was big and heavy enough to work, but small enough to fit.
The finished windows work great.
07-14-2017, 10:24 PM
#222
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Remembering some of the reasons for this project:
07-14-2017, 10:29 PM
#223
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
07-16-2017, 09:15 AM
#224
Centrally Located
, Wish you were here!
Originally Posted by Colin H
Hey Matt,
Cool trailer! As you've been listening to The Vintage Airstream Podcast | Vintage Trailer Restoration , you know that I have a 55 whale tail FC in the shop that we are doing a complete restoration on. You can follow the blog that's attached to my website. We have done some creative things to allow 30 gallons of grey tanks & 30 gallons of fresh water tanks in the bellypan cavities without having anything hang below the bellypan. The layout in this trailer is pretty unique & may appeal to you.
Good luck with your project, it'll be lots of fun!
Colin
My trailer!
07-16-2017, 09:34 AM
#225
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Originally Posted by Byams55FlyCl
My trailer!
Speaking of which, I can't find any updates on your trailer. How does it look now?
We keep trying to get up your way for a rally but haven't been able to work it out yet. Hopefully soon.
--Matt
Too many trailers, not enough time.
07-16-2017, 09:34 PM
#226
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Removing the forward curbside panel
Time for the forward panel to come off. Too many holes in in from the PO and their deadbolts. Creases from collisions.
First the number plate--carefully stowed. Then mark the position of the door frame on the floor. It will be loose as soon as the panel will come out.
The same glue is between the panels, but with the heat gun and a little goof off it is taken care of easily enough.
Soon the panel is out. Time for a quick vacuum to clean things up.
07-18-2017, 08:01 AM
#227
Centrally Located
We've been rallying with the VACmidwest a couple times a year! I think we are doing more rallies than other regions...hope they catch up when we are rolling again.
Updating the blog is on my to do list. Right now I'm reading yours again. My current task is the couple rebuild, so I'm back to page 2!
:-D
07-24-2017, 07:40 PM
#228
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Proper running light color
Previously, I purchased amber running lights from another vendor that not named Vintage Trailer Supply. The aluminum backing is flimsy, and I am not enthused about the color or the apparent lack of weather resistance. Fortunately, I got what I paid for, and they weren't very expensive either.
I notice that Vintage Trailer Supply now seems to offer a better quality LED version in both red and amber.
I have never conclusively figured whether the originals (as mine did not have them when purchased) and whether they were amber or red. I seem to remember seeing other threads such that there was some debate. The few photos that I have see of contemporary trailer seem to indicate that the trailer originally came with amber.
I am not so secretly hoping that it is actually red. I think it looks better, and I regard yellow as a bad luck color.
Does it matter? Can I use my 2012 as a guide? Can I just use what I am inclined to?
07-24-2017, 08:40 PM
#229
Central
, Mississippi
Dunno why but I've always used yellow on the front and red on the rear, sides and endcaps.
07-24-2017, 09:11 PM
#230
1966 22' Safari
Fredericksburg
I've always placed amber forward and red aft. After reading the DOT trailer light regulations, it's confusing. I've often wondered why some vintage Airstreams have three lights on the high front and center, and some don't. On the federal lighting equipment location requirements, the center marker lights are discussed. Good question, but not sure what is legal or required on a sixty two year old Airstream. I have the side marker lights from VTS but a ways off from installing. Hope to hear more. Thanks
07-24-2017, 09:17 PM
#231
Central
, Mississippi
The Double Nickel Project - 1955 Flying Cloud
My '63 was wired for the overhead lights but didn't have them. I guess it was an option. I added them 'cause they look cool
Edit. We didn't install them on a '55 whale tail 'cause they didn't look cool.
My opinion, your milage may vary
07-24-2017, 09:29 PM
#232
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Yes, KDOT is not helping. From the Kansas state patrol website:
OK, this would not seem to be the case based upon what I have seen in practice.
07-24-2017, 09:36 PM
#233
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Removing a little sap
10-11-2017, 09:23 PM
#234
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Roof and panel
10-11-2017, 09:28 PM
#235
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Front panels and covers
10-12-2017, 05:06 AM
#236
1966 22' Safari
Fredericksburg
Matt, on your front panel that you replaced, there are two holes on the curb side of the
panel. One is the fresh water fill. I assume the other is for the air jet to pressurize the tank? Thanks, Bubba
10-12-2017, 09:29 AM
#237
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Bubba, I was unable to determine what that second hole was for. I had thought that the air fixture was inside the trailer. The only element of the interior that my trailer came with was the flush valve for the commode. All of my vintage trailers have been rescue situations keeping them from the scrapper essentially.
Someone with a more original trailer could provide a better answer than I can.
--Matt
10-26-2017, 08:47 PM
#238
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Front curbside corner panel
10-31-2017, 09:46 PM
#239
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
More front curbside panel
11-06-2017, 09:31 PM
#240
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
More front panels
1955, air conditioning, axle, door, flying cloud, frame, holding tanks, polish, restoration, shell off, tank heater, window |
