Old 07-16-2017, 09:34 AM   #225
On adventure with H&G
MattB's Avatar
2012 30' Flying Cloud
1966 28' Ambassador
Lansing , Kansas
Originally Posted by Byams55FlyCl View Post
My trailer!
Speaking of which, I can't find any updates on your trailer. How does it look now?
We keep trying to get up your way for a rally but haven't been able to work it out yet. Hopefully soon.
MattB is offline   Reply With Quote
Old 07-16-2017, 09:34 PM   #226
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
Removing the forward curbside panel
Time for the forward panel to come off. Too many holes in in from the PO and their deadbolts. Creases from collisions.
First the number plate--carefully stowed. Then mark the position of the door frame on the floor. It will be loose as soon as the panel will come out.
The same glue is between the panels, but with the heat gun and a little goof off it is taken care of easily enough.
Soon the panel is out. Time for a quick vacuum to clean things up.
Old 07-18-2017, 08:01 AM   #227
Byams55FlyCl's Avatar
Centrally Located , Wish you were here!
We've been rallying with the VACmidwest a couple times a year! I think we are doing more rallies than other regions...hope they catch up when we are rolling again.
Updating the blog is on my to do list. Right now I'm reading yours again. My current task is the couple rebuild, so I'm back to page 2!
:-D
WBCCI & TAC
Goin' Vintage!
Kathy
http://byams55flyingcloud.blogspot.com/
Byams55FlyCl is offline   Reply With Quote
Old 07-24-2017, 07:40 PM   #228
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
Proper running light color
Previously, I purchased amber running lights from another vendor that not named Vintage Trailer Supply. The aluminum backing is flimsy, and I am not enthused about the color or the apparent lack of weather resistance. Fortunately, I got what I paid for, and they weren't very expensive either.
I notice that Vintage Trailer Supply now seems to offer a better quality LED version in both red and amber.
I have never conclusively figured whether the originals (as mine did not have them when purchased) and whether they were amber or red. I seem to remember seeing other threads such that there was some debate. The few photos that I have see of contemporary trailer seem to indicate that the trailer originally came with amber.
I am not so secretly hoping that it is actually red. I think it looks better, and I regard yellow as a bad luck color.
Does it matter? Can I use my 2012 as a guide? Can I just use what I am inclined to?
Old 07-24-2017, 08:40 PM   #229
Central , Mississippi
Dunno why but I've always used yellow on the front and red on the rear, sides and endcaps.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-24-2017, 09:11 PM   #230
1966 22' Safari
Fredericksburg , Texas
I've always placed amber forward and red aft. After reading the DOT trailer light regulations, it's confusing. I've often wondered why some vintage Airstreams have three lights on the high front and center, and some don't. On the federal lighting equipment location requirements, the center marker lights are discussed. Good question, but not sure what is legal or required on a sixty two year old Airstream. I have the side marker lights from VTS but a ways off from installing. Hope to hear more. Thanks
Bubba L is offline   Reply With Quote
Old 07-24-2017, 09:17 PM   #231
The Double Nickel Project - 1955 Flying Cloud
My '63 was wired for the overhead lights but didn't have them. I guess it was an option. I added them 'cause they look cool
Edit. We didn't install them on a '55 whale tail 'cause they didn't look cool.
My opinion, your milage may vary
Old 07-24-2017, 09:29 PM   #232
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
Yes, KDOT is not helping. From the Kansas state patrol website:
OK, this would not seem to be the case based upon what I have seen in practice.
Old 07-24-2017, 09:36 PM   #233
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
Removing a little sap
I purchased this trailer in the Puget Sound area in Washington state. There are plenty evergreen trees that drop sap.
ID:	290385 Click image for larger version
Plenty of sap found the top of this trailer. Goof-Off seems to work best of the litany of solvents and cleaners that I have accumulated.
ID:	290387 Click image for larger version
Old 10-11-2017, 09:23 PM   #234
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
Roof and panel
Trying to catch up again on posting. Work has been slow but steady.
Thought I might clean up the area around the vents in anticipation of installing new ones so they might have a clean place to seal.
Test fitting and attaching the new panel in place. I wanted to ensure everything was lined up and spaced properly. With a little trimming, it went together properly. Learning a lesson, I also left more overlap between the sheets of the body panels where I could. I also anchored the door frame after marking its precise location to ensure it did not move while the panel was out.
Cleaned up the serial number plate and then test fitted the door again, to double check the frame location. Happily, you can also see that the correction to the door curvature and refitting also improved the fit. Where there was a much larger gap and top and bottom on the outside edge of the door compared to the hinge side before, now the curvature matches the trailer and is tight.
Old 10-11-2017, 09:28 PM   #235
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
Front panels and covers
Front panels coming off. Just rough.
Then a bit of clean up and polishing on the vent covers and other accessory elements.
Old 10-12-2017, 05:06 AM   #236
1966 22' Safari
Matt, on your front panel that you replaced, there are two holes on the curb side of the
panel. One is the fresh water fill. I assume the other is for the air jet to pressurize the tank? Thanks, Bubba
Old 10-12-2017, 09:29 AM   #237
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
Bubba, I was unable to determine what that second hole was for. I had thought that the air fixture was inside the trailer. The only element of the interior that my trailer came with was the flush valve for the commode. All of my vintage trailers have been rescue situations keeping them from the scrapper essentially.
Someone with a more original trailer could provide a better answer than I can.
1955, air conditioning, axle, door, flying cloud, frame, holding tanks, polish, restoration, shell off, tank heater, window
