03-02-2017, 07:05 PM
#181
On adventure with H&G
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Measuring the new panel
03-02-2017, 08:42 PM
#182
1966 22' Safari
Fredericksburg
MattB, thanks for the insight and heads up. I'll be test fitting the shell on the chassis next week. I know I have a long way to go, but it sure helps to have someone well ahead of me to get tips from. Keep up the good work.
03-03-2017, 05:02 PM
#183
Central
, Mississippi
The Double Nickel Project - 1955 Flying Cloud
A heat gun peels off the black goop in the seams. Mineral spirits clean off the residue. I drilled thru the new skin and into the plywood table, then inserted clecos since I don't have clamping ones. Great looking work!!!
On edit, I wasn't drilling on the floor, I setup an outside work table.
03-03-2017, 09:05 PM
#184
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Test fitting the panel
03-03-2017, 09:08 PM
#185
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
A bit of a head smack, should have thought of the heat gun sooner. Fortunately, not too tough to remove. Thanks!
03-03-2017, 09:26 PM
#186
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
The new and latest distraction
03-04-2017, 09:08 PM
#187
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
All three together
The previous owner had braced the interior well with wood, but the shell was off the frame for the 1966. Picked up the frame and wanted to get everything situated for all three trailers.
The frame will need to be almost completely rebuilt. For now the shell will rest on top.
First on the floor:
Then the hoist:
Off the ground and on the frame:
All three trailers together in the workshop:
04-11-2017, 09:13 PM
#188
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Finishing the curbside and two windows
Fitting and drilling the panel is only the first step. Once drilled, I first took the Clecos out of the top half, wiped off the metal shavings, and sealed with Trempro along the seams and the vertical supports. I wanted to find a way also put in some kind of thermal barrier between the two layers of metal.
And of course, when trying to get everything aligned, I remain my typical clumsy handed self and cut my knuckle in such a way it would not close. And also of course, the handyman’s secret weapon and a cotton ball solve the problem.
With the help of my younger son, we got the panel riveted over several hours.
Then went to work on the windows. It is a tough balance to ensure they are sealed and securely seated for the gaskets, with proper alignment. Then once in place, drilling through takes a while to get the hole properly sized and shaped for the rivet to go through. I also discovered that my son is better with the bucking bar than SWMBO, but keeping it to myself.
I used frosted glass for the shower window, which is where the original wet bath shower was in the original floorplan.
I left the last few rivets toward the front of the trailer with just Cleco fasteners until I can get the corner panels into place.
I also found this picture which has told me a lot about how the shell goes together, including the black sealing strip at the front and rear of the side panels where the fasten to the ends.
04-26-2017, 08:46 PM
#189
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
The door…again.
I was not happy with the way three things on the door:
1) The curvature on the non-hinge side was not right, having been slammed by a previous owner or whomever. It left a small gap at the top and bottom on that side. It did not match the hinge side, which did still seal properly. Further, there was a crack in the frame of the door just above and below the latch mechanism from being slammed.
2) The deadbolt did not fit as I wanted it to. I looked neat from the outside, but I had to butcher the bolt itself to make it fit. It wasn’t going to last.
3) The door handle had been pushed in so much from being slammed that the front panel was warped, and looked rough.
I took the panels off the front and back. The bottom inside piece needed to be fabricated as well.
Test fitting the hole cut for the door handle. This was obviously done by hand at the factory. Or it looked to me like it had been gnawed or something to shape. I experimented by drilling holes at the top and bottom, and then used my nibbler attachment for the drill to gnaw it myself generally to shape and then used the dremel to smooth it to shape. I’ve probably got this all out of order, so more on this probably later.
05-04-2017, 07:31 PM
#190
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
The door…new panel and screen.
05-04-2017, 07:34 PM
#191
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
… and the screen trimmed into place.
05-04-2017, 07:58 PM
#192
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Fixing the door curvature…
The door frame was cracked just above and below the door latch, and needed to be reinforced and bent back to shape.
Clamped the new outside panel into place with the spring clamp. Laid over a board and carefully measured and aligned. Then gingerly bent it back to be even curve on both sides.
Once back into shape, I riveted the new outside piece into place to help reinforce the curve. I also cut a curved piece of sheet aluminum to match the curve of the door, and riveted it into the inside of the door frame. I did need to cut a small part out for the latch itself.
05-04-2017, 08:04 PM
#193
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
The rest of the door comes back together
05-25-2017, 09:06 PM
#194
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Retention tabs
05-26-2017, 08:39 AM
#195
1951 21' Flying Cloud
Sacramento
Nice, dude. For all the things I've done on my rig (subfloor, plumbing, etc.) I've dreaded, and put off, the door in a door the most.
05-26-2017, 11:07 PM
#196
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Thanks, but take heart. The door within a door was easier to align than the door itself. However, I feel the same way about the tail lights...which I have been putting off and may get to this weekend.
05-27-2017, 09:22 PM
#197
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
One last picture of the door
With the interior pieces all in place.
05-27-2017, 09:54 PM
#198
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Lining the spare tire well
06-01-2017, 10:08 PM
#199
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Finishing the wheel well
06-02-2017, 09:38 PM
#200
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Preliminary roof cleanup
Some cleanup on the roof after taking the vents off. The old butyl tape was stuck in place like no one's business. I also wanted to remove the vent covers for the fridge and the holding tanks.
I scraped the large pieces of the butyl tape off as much as possible. The rest would need to come off with some chemical assistance.
The vent covers had to come off for clean up and a proper seal. It was clear from the water marks on the inside that the original screws had leaked significantly.
I wanted to keep the original vent covers because I like them much better than alternatives available. The low profile look is just better.
I also took the chance to scrub out 50+ years of grease and debris from the stove vent, though I think I forgot to take a picture of the polished vent cover.
1955, air conditioning, axle, door, flying cloud, frame, holding tanks, polish, restoration, shell off, tank heater, window |
