01-16-2018, 10:17 AM
#161
1966 22' Safari
Fredericksburg
Rock Guard
It's been awhile since I've posted. Got through the holidays and now back to work; weather allowing. Still working to get it dried in so I can move it outside to pressure test.
The original rock guard had green corrugated fiberglass that I replaced with clear Makrolon. I like the idea of seeing through the trailer while driving and seeing the jalousie window through the rock guard. The original top piano hinge was in 3 - 6inch sections riveted to the drip cap. I replaced the piano hinges with 1 - 36inch hinge (cut down from a 48" VTS hinge) and riveted it to the skin above the window frame instead of to the drip cap.
The original hardware was still operable so I cleaned and reused it. I drilled through the window frame flange and tapped and installed 8/32 stainless steel screws. The other end is attached to the rock guard using aluminum sex bolts.
I've ordered a new, longer 48" drip cap to accommodate the rock guard when opened.
01-16-2018, 10:42 AM
#162
1966 22' Safari
Fredericksburg
Rebuilding Curbside Access Door
01-16-2018, 10:59 AM
#163
1966 22' Safari
Fredericksburg
Rebuilding Curbside Access Door (continued)
01-16-2018, 11:25 AM
#164
1966 22' Safari
Fredericksburg
Door within a Door
To polish the door, I mounted the door on a 2x6, then placed the 2x6 in a big bench vise. I can turn the door upside down or right side up as needed.
I'm using black Caswell bars to cut through the corrosion. Unfortunately, the bottom of the door has some pretty deep, dented scratches, so I may consider replacing that section. On the back of the door, I'll have to strip the black paint and some panels will have to be replaced due to a massive number of large screw holes. I have also ordered new screen material.
I'm cleaning up the door handle and have replaced the H-20 spring.
More work to do here......................
01-16-2018, 12:55 PM
#165
Central
, Mississippi
I made a hatch door and some new window frames from 3003. Since they are separate components, when polished you can't tell the difference between them and alclad. Nice work!
01-17-2018, 07:04 AM
#166
1956 22' Caravanner
Don Pedro Island
If you use your homemade break and a long 2x4 you can put the slight bend into the luggage door panel edge if you want to make it look exactly the same.
I also experimented with a bead roller that I had and accomplished the same thing...only problem is it takes practice and a lot of oh S**t moments...LOL
01-17-2018, 08:18 AM
#167
1966 22' Safari
Fredericksburg
I’ve never used a bead roller. Heard a lot about it, but never seen one used. While it’s cold and the 55 is in the barn, we’re trying to take care of the small miscellaneous items before we move her outside under cover. As soon as there’s room, I can set up the woodworking stuff in the barn for the interior. Nothing but fun. Thanks, Bubba
01-17-2018, 09:10 AM
#168
Central
, Mississippi
An elcheapo bead roller comes in handy when messing around with a '50's trailer. I rolled closed the edges of the hatch/window frames and added that little edge fold detail. Also recreating the offset around the edge of the main door if you reskin it. I can't show the frame going thru the roller because 1) the sun is in the wrong place for a photo and 2) it's 18 degrees here and too cold to clean off all the junk on my work table. (Smile)
01-17-2018, 10:36 AM
#169
1966 22' Safari
Fredericksburg
A bead roller it is. It looks like fun and I haven’t asked for a tool since Christmas. Will look around today. It really finishes out the edge and will receive the gasket a lot better. Thanks for the pics. Bubba
01-18-2018, 06:22 AM
#170
1956 22' Caravanner
Don Pedro Island
I got mine at https://www.eastwood.com
02-02-2018, 05:29 PM
#171
1966 22' Safari
Fredericksburg
Misc
Trying to get the exterior sealed so I can move it outside; I need to be able to access my woodworking tools.
Made a little progress: Drip cap installed over the jalousie, finished and installed the hatch door and installed the tail/license lights. Originally, our hatch door was hinged on the top; I reversed it and placed the hinge on the bottom - just personal preference.
Santa brought me a vintage 1955 trailer license plate; we took it to the courthouse today to make sure there would be no problems using it. I still had the original license light fixture, but had to order the license plate bracket from VTS. I installed the license plate light using rivet nuts. I like rivet nuts better than sheet metal screws because they're aluminum and will hold up to vibration better.
I installed the light cans for the Bargman #9 lens (from VTS) using 6/32 stainless steel screws with nylocks on the back. The back will eventually be sealed with Flex Seal. I inserted rivet nuts for 8/32 stainless steel screws to receive the trim and lens.
The only thing left to get it dried in is the door.....stay tuned!
02-02-2018, 07:19 PM
#172
1968 22' Safari
Buda
Very good work
DFlores
David & Diana
02-02-2018, 08:03 PM
#173
1966 22' Safari
Fredericksburg
Thanks David. That means a lot coming from someone who has accomplished what y’all have on your 68. Bubba
02-02-2018, 09:12 PM
#174
1962 22' Safari
1973 25' Tradewind
1968 30' Sovereign
Salt Lake City
, Utah
Looking amazing! Good work.
Wish I could have done this with my '62 Safari.
Lacking at least some of: time, money, and/or skills . . . it just wasn't going to happen. Still LOVE these vintage trailers, and especially love seeing a full renovation.
02-03-2018, 05:26 AM
#175
1966 22' Safari
Hilltop Lakes
It's looking good. Really, really good!
02-03-2018, 07:01 AM
#176
1966 22' Safari
Fredericksburg
Thanks Jim and Mimi. Being retired, I do have the time. We use a lot of the old aluminum and cardboard to build prototypes so money is not wasted. As far as the skill, I build prototypes until it’s acceptable. None of this stuff is easy. But it sure is fun. Thanks, Bubba
02-23-2018, 06:35 PM
#177
1966 22' Safari
Fredericksburg
LED Tail Lights
I bought the Bargman #9 taillight assembly from VTS, but wanted to change the single incandescent bulb supplied to an LED diode board for better visibility. I couldn't find a board that wasn't contained in a sealed assembly, so I bought a Grand General 76452 Fleet Red 4" Round 18-LED Stop/Turn/Tail Sealed Light assembly from empirechromeshop.com (also available at Amazon and other locations) and proceeded to operate on the fixture with my dremel. My plan was to remove the diode board from the fixture and attach it to the back of the bezel of the Bargman #9 so that it could easily be replaced by removing 4 rivnut screws (I think I mentioned on a previous post that I used rivnuts to attach the bezel to the can/trailer).
I first cut and pried off the red lens. Then I cut around the perimeter of the backside to free the diode board from the outer ring casing. I cut just deep enough to penetrate the casing so as not to damage the diode board. I then cut a 2.5" circle around the electrical plug on the backside and removed the 3 screws that attached the board to the outer ring I was removing. I had to notch the diode board slightly for the screws. This is where I made my first mistake because I notched too deeply and must have severed a perimeter wire. I ended up rectifying this by placing a small piece of aluminum tape inside the notches to restore the continuity. I then cut a slightly larger aluminum ring to use as a compression ring and transferred the location of the bezel/lens screw holes to the aluminum ring. This aluminum ring will fit over four 6/32 screws that hold the lens to the bezel, but I had to get longer (1") 6/32 screws to allow for a locknut.
The diode board called for a straight stop, turn & tail plug. The VTS light can came with a 12v, 2 wire socket. I pulled the wires out and used the holes in the socket to thread the 2 hot wires of the new plug. I drilled a hole through the can to receive an 8/32 screw and locknut to secure the ground wire.
This may have been more work than needed; if anybody has a better idea, please share!
Bubba
02-24-2018, 06:19 AM
#178
1956 22' Caravanner
Don Pedro Island
Bubba
This place looks like they have everything and anything...did you look here??
https://www.superbrightleds.com/cat/...il-brake-turn/
02-25-2018, 12:37 PM
#180
1966 22' Safari
Fredericksburg
Originally Posted by Boxite
I appreciate the information. I would still have to take this one apart. Reason being is we want to use the original Bargman #9 bezel and the original Traillite #6 Lens. I would have to remove their bezel and connector. With their connector, the unit is 1 7/8” wide and the wall thickness is only 1 1/2”. But it may be less work with the unit you mentioned, but it is also twice the price. But thanks again for relaying this info. I will look into it further and see which one makes more sense. Thanks, Bubba
