Old 07-20-2017, 06:59 PM   #99
Central , Mississippi
That is beautiful work.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-20-2017, 08:28 PM   #100
1966 22' Safari
Fredericksburg , Texas
HiHoAgRv, I appreciate the compliment. Our attempt at this project would not have been considered if not for you and others on the forums that have logged their experiences on their projects and offered suggestions to others. Thanks, Bubba
Bubba L is offline   Reply With Quote
Old 07-21-2017, 06:58 AM   #101
jjmtb's Avatar
1965 26' Overlander
appleton , Wisconsin
You have taken this to another level. Great job.
1957 Caravanner Full Monty
jjmtb is offline   Reply With Quote
Old 08-23-2017, 06:53 PM   #102
1966 22' Safari
We're continuing to work on the exterior skin. We've completely replaced all lower panels. They were either corroded, badly dented and/or had holes created by a creative previous owner. The last panels we want to replace are midway up on the curb and street sides. We had not intended to replace these originally; however, given the condition of the panels and the ease of replacing them, we didn't want to be sorry for not taking the extra time and effort to do it now.
Name:	done front.jpg
ID:	293097 Click image for larger version
While replacing the exterior panels, it bothers me that the horizontal stringers are not attached to the vertical ribs. I am not sure if there was a reason for this. I have attached them using L brackets and it has given more rigidity, but I am not sure this is the right thing to do. Comments anyone?
Name:	done inside.jpg
As we work on the skin, we're trying to research how to best conceal an air conditioner. We like the idea of a ducted mini split unit for its efficiency and ultra quiet operation. We don't have room on the original tongue for the compressor, so it will have to go inside and vent through the skin/belly. We've seen lots of threads, but nothing with a concealed mini split. Would like to hear any ideas.
Old 08-23-2017, 07:44 PM   #103
DFlores's Avatar
1968 22' Safari
Buda , Texas
Absolutely Beautiful!!!!!!
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 08-23-2017, 08:43 PM   #104
1966 22' Safari
Thanks David. Having been in your 68 you spectacularly renovated, that's a great compliment.
Old 08-23-2017, 09:43 PM   #105
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Doing great work! Does your front jalousie window have 3" or 4" glass? Wondering if yours is the Hehr or non-hehr window. Also on your other standard windows, did you bench polish them or do something else in place? I want mine to look clean but not mirror.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Old 08-24-2017, 06:56 AM   #106
1966 22' Safari
Goransons, our jalousie is the 3" non-hehr. Other than replacing some steel screws that holds the frame together with stainless screws, it's in fairly good shape. I have to order some of the steel retainer springs that holds the panes in place. I'll be getting those from Blaine Window Hardware (part 0085-050). The clip dimensions seem to match mine. As far as the window frames, I will clean up with a bench grinder using Caswell bars. The PO had drilled holes in some of the frames and screwed them shut. I will buck flush rivets in those holes and file the stem down a bit. I ordered a couple sheets of 3003 H14 and will attempt to make a couple of the frames that are just too bent up to straighten. You may want to contact Blaine to see what they have that you may need. Good luck
Old 08-24-2017, 07:30 AM   #107
goransons's Avatar
1963 22' Safari
Cool. I'm making a few for glass too. They seem to bend up ok. How's your top and bottom weatherstrip? I'm working on a replacement with vintage trailer shop. I'll let you know what I find out. He's sending me some to test out. Thanks for the part number I need to order some as well.
Scott & Megan
Old 08-24-2017, 08:43 AM   #108
1966 22' Safari
The top and bottom jealousie weatherstripping is there, but brittle. Mine are 3" short. Don't know if that was intentional or it fell apart. And yes, I would be interested to see if VTS can successfully replicate these. Thanks, Bubba
Old 08-24-2017, 09:36 AM   #109
goransons's Avatar
1963 22' Safari
It must have shrunk. Here's the profile. I'll update you as soon as I get it. Click image for larger version
ID:	293147Click image for larger version
ID:	293148Click image for larger version
Scott & Megan
Old 08-24-2017, 09:37 AM   #110
goransons's Avatar
1963 22' Safari
Scott & Megan
Old 08-26-2017, 08:32 PM   #111
goransons's Avatar
1963 22' Safari
Robert from Vintage Trailer Shop sent me samples of what he has in stock. Of the samples he sent me, two fit very well. The spline isn't triangular but slides in snug.
Option 1 is the same wiper style (it happens to be clear).
ID:	293311Click image for larger version
ID:	293312 Click image for larger version
I think that one fits closest
There is a different profile in gray that also fits. And is slightly stiffer. Click image for larger version
ID:	293314Click image for larger version
ID:	293316Click image for larger version
I'm going to order the clear for mine so I can get things buttoned up soon.
Hope this helps. I'm going to send him a sample of the original gasket and see if he wants to copy it exactly but the lead time will be awhile and from the looks of it you'd only be able to install it by drilling out the whole window and sliding it out from the end of the extrusion. The new clear gasket I was able to slide in from the end but with a little work I was also able to push it in with a putty knife which means it could go in with some work without a total tear down
Scott & Megan
Old 08-26-2017, 08:43 PM   #112
1966 22' Safari
Goransons, thanks for the update. I would like to contact Robert next week and see if I can order the same type you're using.
Also on a different note. I'm replacing quite a bit of the exterior skin due to damage and PO modifications. Concerning the horizontal stringers and ribs, would you connect those? Originally, the stringers were not connected to the ribs and just floated. I don't want to build in too much rigidity, but want a structurally sound shell. Thanks
The tale of the walking door hinge pin Airslide Doors & Locks 4 01-04-2015 08:25 PM
Shocks' tell-tale oil stain arcamedies Shocks 11 08-18-2010 06:57 AM
Another rear separation tale... Silvertwinkie General Repair Forum 41 02-27-2009 07:18 PM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
