Old 04-20-2019, 07:22 PM   #351
1966 22' Safari
Fredericksburg , Texas
Blue Jay's Light Fixture!
We received the light fixture fabricated by Blue Jay (joyflea) and got it installed without delay today.
We wired it using 2 candelabra sockets from Ace Hardware, but regular sized sockets would work as well. It really illuminates the work surface around the sink. We modified the base so that it would sit far enough away from the metal for a bulb and riveted it to the top center of the fixture.
Instead of a twist style switch, we used a push button switch (Latching Push Button Switch, URTONE UR193 from Amazon).
ID:	338673Click image for larger version
ID:	338676Click image for larger version
The photos show the fixture with a small 1watt 12volt LED Bulb (same we used on the Humphrey light) which is fine, but we have ordered brighter candelabra style 12v bulbs for comparison. The sockets were laid out in the fixture to accommodate both sizes.
I wish we knew more history of this fixture. Blue Jay's fixture is a great replica of the original and we really appreciate the effort and workmanship. It's perfect. If you're interested in a vintage replica, contact joyflea!
Bubba L is online now   Reply With Quote
Old 04-21-2019, 07:31 PM   #352
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Wow, that fixture sure adds an interesting detail to your 55. joyflea will likely get more orders for them. I like it.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 04-21-2019, 08:34 PM   #353
1966 22' Safari
Light Fixture
David
Thanks David. Iím not a true perfectionist, but Blue sure is when it comes to metal work.
Old 04-22-2019, 06:04 AM   #354
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
So you didnít say- what was the trailers weight- before and after? BTW nice job on the light
goshawks00 is offline   Reply With Quote
Old 04-22-2019, 06:32 AM   #355
1966 22' Safari
Weight
Barry, the 1955 brochure listed the weight at 2710 lbs. the PO had added some 3/4Ē plywood and other things that increased the weight, but didnít weigh it. Our current weight is right at 3540 lbs. which is 530 lbs more than original. More than I wanted, but we beefed up the frame a bit and added all the modern items.
By the way, the advice on polishing you gave Stephanie seems to be working well. Now she wants to re-polish the entire trailer. Youíve created a monster. Thanks
Old 04-23-2019, 04:40 AM   #356
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Wow I am surprised! I wouldnít have thought that either. Thatís what 20+% over original. Did you get a tongue weight?
We go camping Thurs for 4 days, and will be going by our local elevator , if I remember I plan on weighing our 54 Globetrotter now that itís done, it will be loaded so that will be interesting.
Tell Stephanie, go slow and keep it clean. And no I didnít create the monster, I just nudged her on Ďhow to tame the dragoní🤙
Old 04-27-2019, 07:39 AM   #357
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Got them , they are great , have a good time this weekend. Thanks , Blue
Joyflea is online now   Reply With Quote
Old 04-27-2019, 08:12 AM   #358
1966 22' Safari
Door
You are more than welcome. All Iíve ever heard those things called is ďdoor thingys ď. Take care.
Old 04-27-2019, 06:49 PM   #359
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
That's all joyflea needs is a bunch of "door thingys" to distract him from the job at hand.
David
WBCCI #8607
VAC Region 11
Old 04-28-2019, 11:51 AM   #360
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Just a side note- weighed the 54 Globetrotter on the way camping- fully loaded including water 2640 lbs. So glad still a little weight👍
Old 04-30-2019, 07:27 PM   #361
1966 22' Safari
Inaugural Trip & Thingy
We took a quick 2 night trip to a local TX State Park to test the integrated systems. We found a few minor bugs that will be addressed and had a great time finally relaxing.
ID:	339471 Click image for larger version
ID:	339472 Click image for larger version
Regarding the "Thingy", in post #228 I discussed how others have made gadgets to ensure their suicide doors stayed closed en route and showed different versions I made for our '66 and '55. Once I got the gasket on our '55 door, I had to modify the design as follows:
ID:	339474 Click image for larger version
Old 04-30-2019, 08:00 PM   #362
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
What a beautiful looking vintage Airstream, both inside and out. Your baby is worth big bucks in my view. Happy you got to spend a couple of nights in it to see how it all worked out.
Ahhh, the door thingy. Now I know what it is. Thanks. We should have a contest to see how many different designs Airstreamers have come up with to prevent a door flying open on the highway. It happened to me in the Limited as I forget to lock the deadbolt. My Overlander has a little aluminum stop on the drip rail toward the top of the door. You just twist it down to prevent the door from opening. My son uses a bungee cord. Well, to each his own. I installed a deadbolt lock on his trailer to eliminate the bungee cord.
Joyflea will be infatuated with his new door thingy.
David
WBCCI #8607
VAC Region 11
Old 04-30-2019, 08:44 PM   #363
1966 22' Safari
First Outing
David
Thanks David. I think a short trial run was important. Found some simple issues that need correcting. As far as the thingy, whatever it takes to keep the door from blowing open and causing damage. I think itís a great idea for those who have customized thingies that work share the information and their design. Thereís never been a mousetrap that wasnít made better.
Old 04-30-2019, 09:16 PM   #364
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Incredible work!! I love the reproduction light. You should put those into production! Your version of the door safety latch too! Congrats on the inaugural trip and a beautiful build!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
The tale of the walking door hinge pin Airslide Doors & Locks 4 01-04-2015 08:25 PM
Shocks' tell-tale oil stain arcamedies Shocks 11 08-18-2010 06:57 AM
Another rear separation tale... Silvertwinkie General Repair Forum 41 02-27-2009 07:18 PM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
