Old 04-15-2019, 05:19 AM   #337
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Something I may have mentioned or maybe not, and it may be to late. When running your wiring at completion, make a very complete photo log of where all your wiring is, so down the road when drilling you will know exactly where every thing is at. BTW looks right to me congrats
goshawks00 is offline   Reply With Quote
Old 04-15-2019, 06:12 AM   #338
1966 22' Safari
Fredericksburg , Texas
Wiring
Thanks. We did make a photo log during the insulation phase. Also, I drew elevation drawings of the front, rear, curb and street where we color coded the wiring. You are right in pointing this out. Having a wiring location log is worth the effort for future owners and modifications.
Bubba L is offline   Reply With Quote
Old 04-15-2019, 07:04 PM   #339
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Stephanie does the sewing, Stephanie does the electrical. It sounds like she is the skill trades on the job.
Great electrical planning, and documentation. I did label the wires radiating from my fuse panel, but I didn't take interior skins down so I don't know where the run inside the trailer.
I have left signage under the trailer to identify the waste water tanks, and a caution "Don't Drill Here". There is only an inch between my tanks and the belly pan.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 04-15-2019, 07:26 PM   #340
1966 22' Safari
David
I did get her a new sewing machine for Christmas and a nice pair of electrical crimpers. Teamwork, thatís part of the fun. She does a great job and enjoys it.
Old 04-15-2019, 07:47 PM   #341
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My wife is going to sew up the cushions for the Overlander gaucho. We have foam and material (vinyl). She did the ones for the Globetrotter dinette. She loves to sew. I think they will turn out okay, hopefully as nice as yours. But other than that, my wife his minimal vintage Airstream skills; except spotting when I back her Limited into a camp spot, or out of a fuel station and doing the interior "prep to tow" checklist.
David
WBCCI #8607
VAC Region 11
Old 04-16-2019, 06:16 AM   #342
1966 22' Safari
Awning
We took the trailer to adjust the brakes and to a weigh station; first time out in 2.5 years. We moved the Reese weight distribution/sway system and it towed very well.
We figured since it was out, we'd test Stephanie's awning.
Old 04-16-2019, 06:25 AM   #343
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Originally Posted by Bubba L View Post
Stephanie does the electric and finally got it charted. We have a Progressive Dynamics 4045 (from bestconverter.com) which includes the converter, charger, AC distribution and DC fuse panel. Here is a diagram of how our AC and DC are configured using the PD4045.
Attachment 338172
We are using Blue Sea fuse block terminals on the battery for protection.
We were able to test the 12v system without a battery by having the PD4045's negative connected to the negative bus bar. Now we have an Interstate AGM GPL-27T 12 Volt, 100 Ampere Hour Deep Cycle battery from bestconverter.com connected.
All our wire was tinned marine wire from tinnedmarinewire.com. We also used their crimp/heat shrink connectors and are very pleased with them.
As you can see, we tend to avoid daisy chaining lines as much as possible so that one item doesn't bring everything connected down. Makes for more wiring, but that's ok.
We tested the fridge on DC today and it did fine.
Still no bath sink or shower pan.
Just a couple of questions on your wire diagram and set up...
No battery kill switch?
No inverter?
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 04-16-2019, 06:49 AM   #344
1966 22' Safari
No inverter?
We still need to add the kill switch. Itís on order. We have yet to boondock, so didnít see the need for an inverter. In the future if we see the need for one, weíll just add it along with another battery. Thanks
Old 04-16-2019, 01:40 PM   #345
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Hope this works .
Got home last night and unloaded . This morning got up and played in the shop .
Cut the .063 3003 to size , did the lay out , cut and punched the louvres, and bent it up . When you get it you might squeeze down end flaps better and rivet it up . Also after it is tight trim the back even . If this meets your approval Iíll mail it off .
Your trailer looks great .
Blue
Joyflea is offline   Reply With Quote
Old 04-16-2019, 02:34 PM   #346
1966 22' Safari
Blue
Attachment 338316
Attachment 338317
Attachment 338318
Attachment 338319
Attachment 338320
Thanks Blue, thatís perfect. I picked up the sockets, LED bulbs and the switch. Iím ready for assembly and install. You canít find that design of vintage fixtures Airstream used. We really appreciate all youíve done. See you in West Texas when the weather is right. Say hello to Joy for us.
Old 04-16-2019, 10:21 PM   #347
CruizinDux's Avatar
Tracktown USA , Oregon
I too would like to thank Bubba and his wife Stephanie for their time and friendship. We were passing thru Frederickburgh on our way to Key West etc (#Florida Hee Haw) when he suggest we get together. What a tour!! Those are two sweet rigs and the love shows.
B & S...Have a great time in Pismo. We're heading to Paso soon for friendship and wine tasting....almost Pismo.
Happy trails until we meet again (in Fredericksburg over that Aldstat
Would like to thank Bubba and his lovely wife for the tour they gave my wife and I of their two projects . WOW , the photos do not show how great of a job they have done . And the polish job his wife did on these two Airstream trailers , well just have to say I need to hire her .
It was great to meet them and have made two new friends.
Thanks , Blue .
CruizinDux is offline   Reply With Quote
Old 04-17-2019, 05:50 AM   #348
1966 22' Safari
Thanks Bob, great to meet you. The northwest is on our bucket list for the next couple of years. Iíll bring the Altstadt. See you down the road.
The tale of the walking door hinge pin Airslide Doors & Locks 4 01-04-2015 08:25 PM
Shocks' tell-tale oil stain arcamedies Shocks 11 08-18-2010 06:57 AM
Another rear separation tale... Silvertwinkie General Repair Forum 41 02-27-2009 07:18 PM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
