Old 03-07-2019, 04:27 AM   #281
1956 22' Safari
Williston , Vermont
The Head Lockers look great. I have similar in my Safari, but with the perforated board for the doors. I like the finished wood look very much. I think I will spray the perforated doors when I paint, but also make all new solid doors finished with shellac and poly. Just another task added to the list.
Mark
Our restoration Blog
steinVT is offline   Reply With Quote
Old 03-07-2019, 05:38 AM   #282
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Light
Originally Posted by Bubba L View Post
The front sconce lights were original, so we rewired painted the bases and converted them to DC.
Attachment 335090Attachment 335091Attachment 335092
The circular light was also original; we had it chromed and converted it to use a DC circular LED light we got from m4LED.com.
Attachment 335093
The PO had torn out the bath, so we never had a light fixture there. We believe there was a small sconce similar to the ones in front, but couldn't find one. Alternately, we did find a small porcelain 50's sconce that fit perfectly. We had to rewire and convert it to DC.
Attachment 335094
Here is where I put the small DC switch under the medicine cabinet to operate the original reading light over the bed.
Attachment 335095
We never had the kitchen light which was mounted under the headlockers. I've seen one in photos, but they are pretty vague. If anybody has a good, close photo of a mid 50's kitchen light, we'd appreciate seeing it. Better yet, if anybody has one laying around, let me know.
Here are the headlockers I just finished above the kitchen counter.
Attachment 335096
All is not rosy. I am still trying to figure out what to do about a shower pan. I also am having a hard time with the original kitchen sink faucet. The stems are so rusted that I cannot take them apart to rebuild. And tomorrow I start buttoning up the belly pan.
Hi Bubba,
Not the greatest photo, but this is the original light in my 55 FC.
BambiTex is offline   Reply With Quote
Old 03-07-2019, 12:09 PM   #283
1966 22' Safari
Fredericksburg , Texas
Originally Posted by Jeremy9107 View Post
Bubba. Very clean and bright look in the front. The fixtures are a great accent.
Let me know what you come up with for the shower pan. I have built 2 so far from fiberglass, but don't like either one. I figure third time is a charm but am welcoming any ideas on how to build a fiberglass pan.
Jeremy, I think the shower pan is the largest problem yet to solve. But Iíll keep you posted on what we come up with. The other two issues weíve yet to resolve is the bath sink (one small enough to fit) and rebuilding the original kitchen faucet. The faucet is an old Pfister but the stems are frozen and will not come apart to rebuild. Not surprising.
Bubba L is offline   Reply With Quote
Old 03-07-2019, 12:14 PM   #284
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
It's beautiful!!!
Airstreamin' dreamin'.
Follow our blog! http://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 03-07-2019, 01:45 PM   #285
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Sink
I installed this corner sink from VTS
Old 03-07-2019, 02:01 PM   #286
1966 22' Safari
Thanks Chris. Our location is the straight curbside wall between the shower and toilet. A corner sink may not work there. Thatís a perfect size. I may wind up lengthening the shower footprint and installing the corner sink in the shower. I looked for a vintage Pullman flip up sink, but none available.
Old 03-07-2019, 02:11 PM   #287
1966 22' Safari
Originally Posted by lonewolf1977 View Post
It's beautiful!!!
Thank you for the kind words. Now if we can just finish I would have time to enjoy it. Some day soon, I hope.
Old 03-07-2019, 02:31 PM   #288
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Love the Pullman idea
That would be sweet!
VTS makes the same sink in a straight wall mount:
https://www.vintagetrailersupply.com...-p/vts-072.htm
Old 03-08-2019, 09:55 AM   #289
1965 26' Overlander
College Station , Texas
Bubba, everything looks fantastic as I knew it would. Canít wait to see it in person.
hajash is offline   Reply With Quote
Old 03-08-2019, 12:30 PM   #290
1966 22' Safari
Thanks Andy. I only get half the credit, Stephanie gets the other half. Things are going well. Nothing left but to finish. Hopefully the next time we see yíall itíll be complete.
Old 03-18-2019, 06:20 AM   #291
1966 22' Safari
Polishing
When we polished the '66 trailer, we used Nuvite. Thanks to many Forums recommendations, we have since found the Caswell bars to be easier and more effective. That being said, we had some water spots appear on the skin that would not come out no matter what we used.
Caswell customer support suggested acid. Normally I would never consider acid, but after polishing a whole day without luck, we decided to try it. I got some Aluminum Brightener from the auto supply store. Instead of spraying it on, we sprayed a rag and wiped it on in order to control where it went and how much. After letting it sit for 20 seconds, we wiped it off with a rag soaked in baking soda and water to remove and neutralize the acid. The acid dulls the finish quite a bit, but it could easily be brought back with the Caswell brown/white bars.
Everybody has to establish their own polishing technique, but here are some things we found helpful:
  • We were told by Caswell customer support to never clean with mineral spirits; it's too oily. Use lacquer thinner instead.
  • Caswell CS also told us not to clean with thinner so often. After a pass, wipe off excess polish with a clean, dry rag. We only clean with lacquer thinner before and after the white bar polish.
  • We have more luck with the Caswell sewn pads; we didn't have much luck with the vented wheels and the sisal wheel scratched too much.
  • To prevent the white (rain?) spots from returning, we are applying the NuFinish no wax car polish at the end. It's easy and seems to keep the spots off.
  • In tight spots where we cannot get the polishing wheel, we use Diamond Brite Truck Box Polish.
Note the 1955 vintage TX trailer license plate I got from Santa a couple of years ago. It was an easy process to register at the courthouse and is finally in use.
Now that the back is polished, I will start adding a bumper trunk.
Old 03-21-2019, 06:30 AM   #292
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
What I find interesting is the little differences between years and models of the same vintage.
Your Airstream blue plate on the back is below the license plate. On mine the Logo plate is below the escape window
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 03-21-2019, 07:16 AM   #293
1966 22' Safari
Maybe it was an Ohio versus California thing. Looking through pictures trying to rebuild our 55 close to original was a challenge. They were all basically the same, but as you said, with oddities. Maybe they got to work that morning looking forward to the $.75 per hour and said, letís put the logo here today.
Old 03-21-2019, 10:07 PM   #294
1970 25' Caravanner
Incline Village , Nevada
Polish advice
Going to save this thread to refer to when it comes time to cleaning up my skins. Great advice.
Jeremy9107 is offline   Reply With Quote
Old 03-22-2019, 02:42 PM   #295
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Tale of a '55 FC Whale Reno
Hi guys been a while since I have posted. I have done a complete rebuild of our 54 Globetrotter along with building a 49 Trotwood. I am looking forward to getting back to silver spoon this spring after a winter of work and camping in Fla. Having polished a few airstreams I would like to have you consider using acetone for any and all clean up between polish sections. Take a hard look at what lacquer thinner is made out of. Just my .02
Barry
goshawks00 is offline   Reply With Quote
Old 03-22-2019, 03:20 PM   #296
1966 22' Safari
Barry
Barry, please enlighten me. I thought acetone was the key component in lacquer thinner and a lot more evaporative by itself. Is lacquer thinner more toxic? Thanks for the heads up.
Old 03-22-2019, 08:16 PM   #297
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Acetone does not contain anything that prevents rapid evaporation. Lacquer thinner has waxes that slow down evaporation to allow it more active cleaning for breaking down lacquer, at the expense of leaving a wax film. There is another chemical which I canít remember right now that is highly toxic. Educate yourself , find out the chemicals you are handling
Old 03-22-2019, 10:06 PM   #298
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Should have read there is another active ingredient in Lacquer thinner that is highly toxic but canít remember itís name right now
Old 03-23-2019, 12:42 AM   #299
2007 22' International CCD
Methyl Ethel Keytone (sp). Also known as MEK. Really nasty stuff, flammable as hell and very toxic. Not something you even want to be around the vapors from it.
Old 03-23-2019, 05:17 AM   #300
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Third ingredient is methanol- it will kill you- even vapors are highly toxic.
The tale of the walking door hinge pin Airslide Doors & Locks 4 01-04-2015 08:25 PM
Shocks' tell-tale oil stain arcamedies Shocks 11 08-18-2010 06:57 AM
Another rear separation tale... Silvertwinkie General Repair Forum 41 02-27-2009 07:18 PM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
