Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 1950-1955 Flying Cloud
Old 01-01-2012, 02:10 PM   #1
Ciciolina's Avatar
1952 21' Flying Cloud
Loosdrecht , Noord Holland
Tail lights '52 Flying Cloud
So far i haven't been able to find replacents for the tail lights, the pointy ones. Anyone any suggestions about were to get them?
Also i'm wondering which light does what? the square ones are just light and double as break lights? And the pointy lights are they used as turn signal?
Any tips on were to find the light are appreciated
Ciciolina is offline   Reply With Quote
Old 01-02-2012, 12:28 AM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Hi,
On my 1951 (could be a 52?) it only has the small rectangle lights on the back, which serve as "running lights", "brake lights" and "turn signal lights". The "pointy" ones are on the sides - 2 near front and 2 near back, and were "running lights" only (red in the back, yellow in the front). I've always called them "beehive" lights and mine are real glass (see photo in my images). It'll be very difficult to find replacements - every once in a while they show up on ebay. Maybe there are "replicas" on the web somewhere. I do notice that the usual place I go for this sort of thing (vts) doesn't carry anything that looks like mine.
Good Luck,
MarkR
(oh, and i notice that my images are sort of "gone" . . . (wonder what that means?) . . . anyway, here's a link that should take you to that photo:
http://www.airforums.com/photos/show...&cutoffdate=-1
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 01-02-2012, 06:30 AM   #3
Ciciolina's Avatar
Hi Mark, it looks like the same light. As you can see in this picture my FC does have them on her tail:
As you can see the right one is missing. On the side she has those teardrop shape lights....
I will check ebay, did so yesterday with no luck....
Old 01-02-2012, 07:21 AM   #4
toastie's Avatar
1955 22' Safari
Great Lake State , .
try Exterior Lights
also like these http://www.ebay.com/itm/Two-Rare-Vin...item45ffb6cb29
http://www.ebay.com/itm/Vintage-barg...item3a6e9d7925
toastie is offline   Reply With Quote
Old 01-02-2012, 07:34 AM   #5
Ciciolina's Avatar
Hi Toastie, i found those but they are not the ones i'm looking for. If you check out the link Mark enclosed you will see the lenses i'm looking for, kinda dome shaped, red, round. Never the less thanks for helping out!
Old 01-02-2012, 07:42 AM   #6
toastie's Avatar
1955 22' Safari
http://vintagecampers.com/parts.php?...&sub=Clearance Lights
http://vintagecampers.com/viewpart.php?partID=1569
Old 01-02-2012, 07:47 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Ah Ha! I was looking at the "brake lights" which are like the ones Toastie showed you. By the way...those are rare, especially in Holland area. The ones you are showing are usually on the sides....called side marker lights. Usually the ones in the area at the bottom of the rear are "back up" lights of a clear glass. Over the years previous owners make many modifications...I sus pect that here. Look in the same area that Toastie referenced....there are always side marker lights like you want ....they show up regularly sold by dealers. Send an Email to the dealer...most likely they will have what you need. I would still buy those "brake" lights, restore them as spares for future use,,,even make them LED upgrades for safety.
Old 01-02-2012, 07:50 AM   #8
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I had luck finding tail-light lenses for my '72 at www.taillightking.com. Good luck with your restoration!
tphan is offline   Reply With Quote
Old 01-02-2012, 07:55 AM   #9
toastie's Avatar
1955 22' Safari
VintageCampers.com :: Vintage Campers, Vintage Trailers, Vintage Parts, Vintage Restorations
Old 01-02-2012, 08:51 AM   #10
Ciciolina's Avatar
Thanks for the links! The one for vintagecampers seems a winner
Old 01-02-2012, 09:19 AM   #11
toastie's Avatar
1955 22' Safari
Dan is a good guy..........
flying cloud
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
Front Bedroom Flying Cloud - The Choice for Peeping Toms! Fly at Night Upholstery, Blinds, Walls & Interior Finishes 31 01-09-2012 08:50 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
