Old 07-13-2015, 01:33 PM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Roof A/C
Reluctantly considering adding a roof A/C unit. I hate the way they look on vintage trailers but am beginning to think it may be the best solution. Anyone else done this?
What is the lowest profile unit currently available?
Will it fit in my existing vent opening?
I am guessing it is not pre-wired for AC power...
How do I handle the considensate?
Thanks in advance!
BambiTex is offline   Reply With Quote
Old 10-13-2015, 01:09 PM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Better option
Went a totally different direction and ended up with a very good solution. I purchased a 12,000 BTU Pioneer "DC inverter type" split system AC/heat pump and mounted the outdoor unit on the tongue and the indoor unit in the end cap.
I had to re-orient the tongue jack, remove one LP tank, and build a mounting platform for the remaining tank and AC compressor.
I used brackets to mount the indoor unit to the wall/ceiling and had to cut the refrigerant lines to length and run them through the shell. Vacuumed out the lines and tightened up the connections to eliminate leaks, then released the refrigerant.
After a ten day trip I am very pleased with the unit performance. It is extremely quiet and draws 8 amps max. Remote control thermostat can be placed by the bed at night and adjusted as needed.
ID:	250385   Click image for larger version
Old 10-14-2015, 01:33 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Slick!
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 10-10-2016, 11:35 AM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Update
After a year of use this A/C is still going strong. Super quiet, low power consumption (easily runs on a Honda 2000), and best of all no "roof blister". We have reluctantly decided to sell this trailer to move up to something larger - ad is in the Classified section.
Old 10-10-2016, 11:49 AM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Other threads address wiring. Some shops already experienced with AS.
Coleman Mach 8. See threads. Posts by Lewster
1990 35' Silver Streak
2004 555 Cummins
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
