Old 02-28-2010, 04:16 AM   #295
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
What others may not be able to see is that the black tank itself is black ABS plastic and then the shell that comprises the top of the tank and the shower pan is PVC. On mine the two are welded to one another at the toilet flange and where they welded the vent fitting in. Otherwise, they are independent of one another.
There is always more than one way to skin the proverbial cat, but I'd use the universal glue, in the top corner. The side approach adds to complexity and especially adds space issues. Use blue tape to limit the sqeezeout around the white collar and the pan. Wipe off excess before it dries and remove the tape. After it dries then apply new tape and caulk with ProflexRV white. Make a cove with the tip of your finger and remove the tape. The caulk stays bright white and doesn't yellow or get brittle.
dieseleagle is offline   Reply With Quote
Old 02-28-2010, 07:08 AM   #296
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
FC7039, I'm working on the back"trunk" door on my 55 FC. I have the door but I don't know how the door was originally mounted. Could you take some pictures of the door on the back of your trailer with mounting detail?
http://www.airforums.com/forums/f36/...wax-25692.html
If you would place them on my thread I'd appreciate it.
Thanks Don
Also do you have a layout of your plumbing?
NorCal Bambi is offline   Reply With Quote
Old 02-28-2010, 07:25 AM   #297
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by soldiermedic View Post
I think I will mount the fitting on the side of the tank, and use a 90 degree elbow to point it towards the ceiling.
Your nose (and your wife) will not be happy if you do this.
If your tank is ABS it must have been painted to result in the white/cream exterior. Will you be painting any other fixtures in the bath? If so, you can order a can of Mr Tubby and paint this fitting after it is installed... but do not do any caulking until after you paint.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 02-28-2010, 09:03 AM   #298
soldiermedic's Avatar
Florissant , USA
Here is the picture again to freshen everyone's memory.
There is a 3/4 inch piece of foam between the top of the ABS black tank, and the white shower pan. The Pelland site says their pans are either ABS or Fiberglass. No mention of PVC anywhere. I suppose I could mount the abs flange with the universal, and use heavy duty caulking where the pvc fitting comes through the pan. There is really no place to put a glue since there isn't a flange for the PVC.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-01-2010, 08:43 AM   #299
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Steve
Looks cool, man. I might do something similar on my Liner.
JP
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 03-03-2010, 07:53 PM   #300
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Are these the same thing (parden me if I didn't see something earlier back on the thread)...
VINTAGE TRAILER AIRSTREAM GLASS MARKER LIGHTS DIETZ #52 : eBay Motors (item 140387567999 end time Mar-11-10 19:13:23 PST)
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-03-2010, 07:56 PM   #301
Florissant , USA
Scott,
These are actually larger than the Yankee lenses I am looking for. Did you see his buy it now price? Yikes.
Steve
Old 03-03-2010, 08:29 PM   #302
goransons's Avatar
1963 22' Safari
too rich for my blood, but sometimes if its the right part it ends up being the right price.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 03-04-2010, 03:31 PM   #303
Florissant , USA
Found one...WAHOOO!
I was doing some views on Ebay today, and happened across one of the Yankee 70 fixtures with lens. Buy it now for $1.25 and $5.99 shipping. Less than $8.00 for the complete lens and fixture is amazing. Now I have an additional fixture incase VTS wants to have them made.
WAHOO!!!!
Please wait
Image not available
Please wait
Image not available
Old 03-04-2010, 05:19 PM   #304
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
good score! I didn't see that one (and I've been keeping an eye out for ya!) My Liner has plastic lenses that look a little different. I don't think any 2 were alike.
JP
Old 03-04-2010, 06:36 PM   #305
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Congratulations!!!
I thought you would be looking for a long time.
Vaughan
Old 03-04-2010, 06:49 PM   #306
Florissant , USA
I was planning to replace the entire rear panel on the trailer this weekend, but both of my helpers fell through. I will drill out some rivets, but leave the sheet up with a few clecos until I can get a bucking assistant. Too bad as the weather looks to be pretty good for the next three days which I am off.
Steve
Steve
Old 03-05-2010, 07:29 AM   #307
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
You must be living right to find that lens and fixture
RichHog is offline   Reply With Quote
Old 03-05-2010, 07:35 AM   #308
Florissant , USA
It's all luck Rich....luck indeed!
1953, cloud, flying, restoration, vintage, flying cloud
21' flying cloud 1953 Richey Member Introductions 4 09-04-2008 11:02 AM
1953 Flying Cloud Pics 1953 Flying 1950-1955 Flying Cloud 18 11-24-2007 09:14 AM
1953 21' flying cloud t.gray 1950-1955 Flying Cloud 123 02-14-2007 01:54 PM
1953 Flying Cloud Windows Bobbybl Windows & Screens 0 06-24-2005 01:18 PM
