Old 11-17-2009, 06:03 PM   #239
soldiermedic's Avatar
Florissant , USA
For months I have been looking for a local company that does soda blasting, but have had little luck. The lone prospect wanted $100 per hour, $50 a bag of blasting soda, and $0.58 cents a mile to my house for gas. I was born at night, but not last night!
So last Friday I was perusing the website of everybody's favorite place to hate on. The place where cheap and poorly made Chinese tools live...Harbor Freight. They had a portable soda blaster that held 10 pounds of media on sale for $79.00. I figured at this price it was worth it even if I had to bring the tool back. I picked up the blaster, set of funnels, and a 50 pound bag of blasting soda for $145.00.
Harbor Freight's 10 lb soda blasting rig
Assembly at home took 10 minutes, and was pretty straight forward. I took it outside and set my sights on cleaning off my front and rear trim caps. The caps were covered in paint and bondo from a previous panel accident. It took a few minutes to get the adjustments right, but the blaster worked incredibly well. Last week I had applied paint stripper and took several coats of paint off, but most of it wouldn't budge. The results of soda blasting are quite amazing.
56 years of paint and bondo
After a couple minutes of blasting with medium grit blast media
Clean with minimal effort
Soda blasting causes no damage to the metal surface
Completely done stripping the paint and bondo.
With the trim cap completely stripped, we installed it using round headed stainless steel screws. The cap doesn't fit perfectly, and I suppose it never fit perfectly on the original skin either. Strategically placed sealant will clean the edge up where the cap doesn't fully mesh against the front panel.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 11-17-2009, 07:37 PM   #240
Looks great Steve!
Do you have any more blasting to do? I'm interested in how well the tool holds up over time. If it lasts through several jobs then I'd say it is well worth the money and effort.
Keep up the good work!
Old 11-17-2009, 07:39 PM   #241
Florissant , USA
Included in the price was a 27 month service plan that replaces the tool if it stops working for any reason.
I do plan to blast the stubborn paint off a few interior panels along with the wall paper on some pieces in prep for zolatone on the interior.
Steve
Old 11-17-2009, 08:34 PM   #242
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Looks good to me. BTW..no leaks this weekend while in Illinois and 3 inches of precip to wade through. Looks like the Captain Tolleys did a good job on my rig. We are off to DC for a week and then headed back down south to Mississippi.
Living life on the Road
deauxrite is offline   Reply With Quote
Old 11-18-2009, 06:54 AM   #243
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
I too, am a Harbor Freight fan... I gotta look into the soda blaster set up next time I'm over there.
You're really making some progress now, man. Way to go!
JP
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 11-18-2009, 08:33 AM   #244
Florissant , USA
Hey Deauxrite...did you use Cap'n Trolly's on all the leaks we located or just on the small ones?
The weather here has been raining like crazy since last weekend. I have had no chance to get outside and work on buttoning up the rear of the trailer for winter. I am hoping for a break in the weather to accomplish this, and rivet everything back. I have noticed a alot of condensation on the interior (Not leaks), and a few leak points that need to be sealed on the front window.
Please stop raining and let the sun come out for this weekend...please!
Old 11-18-2009, 04:02 PM   #245
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
How much media did it take for the trim caps? What is the clean up effort afterwords? Can this be used in the trailer or only outside?
Thanks.
FC7039 is offline   Reply With Quote
Old 11-18-2009, 05:16 PM   #246
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Thanks.
As Soldiermedic's assistant allow me to reply ... He used about half of a 50lb. bag ($37). This is for both the front and back beauty strips. S. started blasting on the interior endcap that he wanted to polish and it left a cloudy finish ... not good! WE stopped in case we were doing permanent damage. OK if zolotone was the end product. Soda blaster websites say it dose not etch the metal ... we will see!
BOB
Xbob2 is offline   Reply With Quote
Old 11-18-2009, 05:33 PM   #247
Florissant , USA
I also test blasted other items. We blasted a rusty outrigger that was removed, and I started removing paint off an old interior panel before moving onto the trim caps.
The trim caps took lots of media since they had thick layers of bondo.
Being a green product. I hosed off the driveway and the recent rains have taken care of the rest of the dust. Brooming could do the same job.
I plan to use this inside the trailer on a few areas that have spots that need cleaning. Just vacuum it up when done.
Old 11-18-2009, 06:08 PM   #248
1962 28' Ambassador
1962 30' Sovereign
Soda blasting is cool, Soda blasting is good hope to buy a commercial unit to do my trailer and many others ...
Keep posted!
Old 11-18-2009, 07:07 PM   #249
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Nice concept, so here's a question, how much media would you guestimate you go through per square foot? How is the mess?
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-18-2009, 08:07 PM   #250
Florissant , USA
The mess sweeps, blows with a leaf blower, or flows away with a hose.
It is impossible to guesstimate since it all depends on what you are taking off. A single layer of paint will come off alot quicker than multiple layers. For my panels, I only want to take enough off that I can get the stripper to work well, or the acid etching primer for the new zolatone to bond to.
Old 11-19-2009, 10:59 AM   #251
FC7039's Avatar
Allen , Texas
Air needs
How big of air compressor do you have? Will this work with a small take compressor or is a large air flow needed?
Old 11-19-2009, 11:54 AM   #252
Florissant , USA
I have a 33 gallon 6.5 HP upright compresson by craftsman. Blasting does take a great deal of air, and a small tank will not keep up with requirements to do the blasting.
1953, cloud, flying, restoration, vintage, flying cloud
21' flying cloud 1953 Richey Member Introductions 4 09-04-2008 11:02 AM
1953 Flying Cloud Pics 1953 Flying 1950-1955 Flying Cloud 18 11-24-2007 09:14 AM
1953 21' flying cloud t.gray 1950-1955 Flying Cloud 123 02-14-2007 01:54 PM
1953 Flying Cloud Windows Bobbybl Windows & Screens 0 06-24-2005 01:18 PM
