Old 11-03-2009, 04:04 AM   #211
CrzyCorpsman's Avatar
1975 31' Sovereign
Biloxi , Mississippi
Looking great Steve. I told you that you would pass me up during your restore I'll be hitting mine hot and heavy when I get back to Mississippi in Feb.
Brian Schmock
'75 31ft Airstream Sovereign
Come check out my restoration progress:
http://crazycorpsman-silverbullet.blogspot.com/
CrzyCorpsman is offline   Reply With Quote
Old 11-03-2009, 06:06 AM   #212
soldiermedic's Avatar
Florissant , USA
Originally Posted by goransons View Post
Looks good! How many hours you figure you have into that front window from removal, rebuild and reinstall? Looks like a ton of work.
Scott,
As I was telling Bob all day yesterday....be thankful you don't have these windows. Now keep in mind that this is my first time working on hehr windows, or an Airstream in general. This also doesn't include trips to the specialty stores for glass or sealant needed for certain parts of the rebuild.
Here is the approximate breakdown.
I had two hours in the removal time. That was for drilling out the drip cap and window frame, and cutting through the silicone that was everywhere. I would have had a person helping if I had the chance to do it again.
I had approximately 14 hours to break it down, clean the parts, re screen, new gaskets, new fasteners, get new glass, paint hardware, etc. While these windows look cool, they certainly are a pain to redo. To give you an idea, the stationary glass pane in the front window has 25 components to it alone.
Installation that encompasses everything we did yesterday was about 4 hours, and that was two of us for bucking rivets.
So there you have it. approximately 20 hours, or 24 man hours when you include Bob's time.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 11-03-2009, 06:07 AM   #213
Florissant , USA
Originally Posted by RichHog View Post
So Steve I can't believe your not gonna pull her down here to Texas for the Vintage Rally next Feb.?????
Rich,
If only my trailer would be ready by that point. I don't think there is any way I have this thing camp able by then. I will be attending if I can sell enough tests like I did last year though.
Steve
Old 11-03-2009, 11:12 AM   #214
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Steve, why don't you go with the cheap tank, but get an adapter to take the 5/8" fill down to a 3/8" for the tank?
Marc
Old 11-03-2009, 01:31 PM   #215
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Don't forget
I am first on the list for leak test at the Texas Vintage Rally. Lets get many more folks signed up for the check.
Old 11-03-2009, 10:20 PM   #216
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Git er done
Hey Steve nothing like a deadline to git er done. You do have that other beautiful unit. If not let me know if yo need passage from the airport to Conroe KOA
RichHog is offline   Reply With Quote
Old 11-04-2009, 06:27 AM   #217
BarryIowa's Avatar
Polk City , Iowa
Great work! My windows are a few years newer (1955) and a few less parts but still have many of the same issues as yours and I know this is very time consuming. Keep up the first class job!
BarryIowa is offline   Reply With Quote
Old 11-04-2009, 06:44 AM   #218
Florissant , USA
There were no standards of assembly back in 53 I have discovered, and I have had to rescreen a few times because I assembled the window the same as another only to realize that it wouldn't work after cutting a hole in the screen.
My biggest issue right now is that I do not have the aluminum grommets that hold the screen against the back channel. All of mine broke in removal, and nobody sells them. It's a piece of aluminum with a straight slit punched through it for the operator arm. If anyone has extras, has an idea ot bypass this, or can make some...let me know. Here is a picture.
Bob and I got two more windows and caps installed yesterday, and would have had a thrid if the aforementioned issue with the non standardized layouts have occurred.
Steve
Old 11-04-2009, 08:41 AM   #219
1975 Argosy 26
1963 24' Tradewind
Can you make a new one out of some scrap alumanum skin that you might have lying around? They might be thinner, but I'm sure that may work. OR, make the oval with slit out of plastic, and rivet some aluminum tabs onto the ends to bend into the holes of the skin?
Old 11-04-2009, 12:20 PM   #220
Florissant , USA
Hey Marc,
The old ones seemed to be scrap alclad. I do have a bunch of this left over, and can use it. The hard part is the rectangular hole for the operator. I wouldn't bother bending the tabs in like the original, but would add a pop rivet into the hole to attach the grommet to the back channel. I figured they were made on a machine punch back in the day.
Steve
Old 11-04-2009, 12:32 PM   #221
CaptainJones's Avatar
1951 21' Flying Cloud
Western , Kentucky
If you have access to a drill press you could drill a line of holes and then clean it up with a metal file.
I have started making some of the small pieces i need for my trailer. While they don't look as good as the original at least I have something. You are right, finding some parts is impossible.
Greg Jones
CaptainJones is offline   Reply With Quote
Old 11-04-2009, 02:52 PM   #222
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Steve
Steve,
I think we can make these ... I have a dremel tool and almost know how to use it! (The slots would be oval.)
Xbob2 is offline   Reply With Quote
Old 11-04-2009, 02:57 PM   #223
Florissant , USA
Well Bob...if you can bring that there dremel over next time we can give it a shot. The old ones broke upon removal. I think the oval shape would be okay as long as the operator has a bottom edge to rest on.
Steve
Old 11-04-2009, 05:32 PM   #224
Sugarfoot's Avatar
1960 24' Tradewind
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Just dawned on me . . .
You know, I didn't realize until looking at yours, then looking at my '56s pics, that the screen is sandwiched between the vertical frame bars and the operators.
I think our operators are different (didn't they change in '56 to the crank?) but same basic window design. I can see how rebuild is so time-intensive. This means rescreening if necessary in the future will be a royal PITA, doesn't it?
Looks like you're moving along, Steve. So next time you and Amy come to Chattanooga you'll be parking the Cloud in Mom's yard?
Traveling With Elvis
life with a 1956 Sovereign of the Road
Aluminocentricity
Sugarfoot is offline   Reply With Quote
1953, cloud, flying, restoration, vintage, flying cloud
21' flying cloud 1953 Richey Member Introductions 4 09-04-2008 11:02 AM
1953 Flying Cloud Pics 1953 Flying 1950-1955 Flying Cloud 18 11-24-2007 09:14 AM
1953 21' flying cloud t.gray 1950-1955 Flying Cloud 123 02-14-2007 01:54 PM
1953 Flying Cloud Windows Bobbybl Windows & Screens 0 06-24-2005 01:18 PM
