Old 07-15-2010, 08:12 AM   #239
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Nice work brother. Still jealous!!!!
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-15-2010, 08:22 AM   #240
BarryIowa's Avatar
Polk City , Iowa
Thanks Brad! We also got the entry door moved down and replaced the bad threshold. It looks funny when you walk in because the bench and cabinets above it are still attached to the back wall and you would have to be a giant to use them. I'll get those moved down after I install the interior sheathing which I think will be OSB painted white for added strength over drywall. What do you think?
BarryIowa is offline   Reply With Quote
Old 07-15-2010, 08:25 AM   #241
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
What a creative solution to the problem and it looks great too!
Cutting 3 feet off the bottom of the trailer would have worked also...
Richard
Old 07-15-2010, 08:28 AM   #242
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Originally Posted by BarryIowa View Post
Thanks Brad! What do you think?
I think I'm still jealous!! I thought those cabinets were a bit too tall but having a taller ceiling will allow taller cabinet/storage space. Always seem to need more space because it will always get filled up.
How much space will there be to walk around once the AS gets backed in there? Maybe park it in at an angle?
FF
Old 07-15-2010, 08:32 AM   #243
BarryIowa's Avatar
Polk City , Iowa
The garage is 20' x 30' and the trailer is 22' nose to tail. The angle would help but unfortunately I do own some other stuff that also takes up valuable space like go kart for the kids, mower for the wife (kidding), table saw and various other yard-related things.
Old 07-15-2010, 09:25 AM   #244
tallytwo1994's Avatar
tallahassee , Florida
So it looks like you raised the whole garage instead of just raising the roof. I've seen houses that have had the roof raised but never something like this. This is a very interesting idea and I'll tuck it away for future reference.
Thanks for sharing,
Carol
tallytwo1994 is offline   Reply With Quote
Old 07-15-2010, 09:26 AM   #245
Oh, I meant to ask if you had to do much interior bracing to keep it plumb?
Carol
Old 07-15-2010, 09:42 AM   #246
BarryIowa's Avatar
Polk City , Iowa
Hi Carol,
I originally planned on raising just the roof but it was going to cause a LOT of re-wiring issues. By just lifting it, I only had to add a junction box where the power enters the building and move some boxes down - no big deal. I would have had to re-side it anyway so that wasn't a factor. I'll be able to re-use most of the siding.
There were many 2 x 10s used and lag bolted into the side walls and then cross braced and the jacks went under those. Really not as bad as it sounds and not nearly as difficult as the restoration job ahead of me on the AS!
Old 07-15-2010, 09:52 AM   #247
Don't forget the enormous amount of new tools and toys you'll be purchasing for Airstream renovation, maintenance, and use.
Old 07-22-2010, 09:07 PM   #248
BarryIowa's Avatar
Polk City , Iowa
More Garage Progress
I made some more progress on the garage. The rest of the sheathing was installed and house wrap finished. All of the vinyl corners were installed along with the starter strip and some of the siding. The garage opening was trimmed out and I picked up the new door last night so that will go up next. I also broke down and bought a window air conditioner but I'm going to install it permanently in the north wall. I figured that now was the time to put it in while I was installing the siding. Man caves are meant to be cool!
ID:	107259   Click image for larger version
Old 07-25-2010, 06:51 PM   #249
Guess it's all a matter of comfort. It went from a garage to a man cave mightly fast.
Looks good though, no matter what you call it.
Carol
Old 07-25-2010, 07:55 PM   #250
BarryIowa's Avatar
Polk City , Iowa
Garage Lift
I'm beat. I worked on the garage (man cave) all weekend. I got the siding finished up on the East and West sides and 2/3 of the South wall with the help of my buddy Brad C. Dave stopped up and gave me a hand on getting the garage door in place. I still need to get the tracks on and that is happening on Tuesday. There was quite a bit of work needed to get the inside garage door opening ready for the door. I lag bolted through the old jack studs into the new header for extra strength. Then I had to add some dry wall to the header and trim it out. I also had to lengthen the wires for the garage door opener sensors. Lots of little jobs. Since I'm reusing as much of the siding as I can, it will need to be sprayed with house wash and power washed.
ID:	107452   Click image for larger version
Old 07-29-2010, 01:58 PM   #251
Wisco's Avatar
Los Angeles , California
If any of you hear about a '54-'57. preferably '55 that's wasting away and needs a full restore I would be willing to hand over a finder's fee. Everytime I find one it gets snagged up by a reseller faster than I can put a deposit on it. It's stuck in my brain and I sold my '84 Limited to buy one of these guys and now I'm getting desperate. Found myself almost buying a late '57 and got really close to getting a '51, but my heart is set on a '55 CA FC. Thanks.
Wisco is offline   Reply With Quote
Old 07-29-2010, 02:06 PM   #252
BarryIowa's Avatar
Polk City , Iowa
Good luck! They are nearly impossible to find and getting increasingly expensive. I was told that mine was worth 3 to 4 times what I paid for it. Really the best way to find one is to join a local club, join a vintage club and make friends. Once people realize your interest is for your own personal use and not a quick profit, they will be more likely to pass along any leads that they come across.
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Tricking out 23ft Flying Cloud - Suggestions? scubadog 2009-2015 Flying Cloud 5 09-13-2011 10:36 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
