Old 05-05-2010, 08:32 AM   #225
BarryIowa's Avatar
Polk City , Iowa
The '55 is in my neighbor's garage right now and it fit easily with his 9' door. I do not plan on installing a roof air conditioning unit so at least for this model of trailer, I should be in good shape. Good advise though about measuring everything carefully. You are right, I don't want to go to all of that work and be too short by a few inches!!!! The opener and track would be above the door track height so that won't be an issue.
BarryIowa is offline   Reply With Quote
Old 07-09-2010, 07:29 AM   #226
BarryIowa's Avatar
Polk City , Iowa
Garage Lift
I'm sorry for the lack of progress and/or communication. All is well in Iowa and as they say "a picture is worth a 1000 words." The 55 will now fit in my back 20' x 30' garage. The interior ceiling height was 8'. Now it is 11' and I'll be installing a 9' overhead door as soon as it comes in. This was no easy task but it is done! Now comes the much easier task of installing the exterior sheathing, house wrap and re-siding. Yeah! Now I'll be able to work on the AS any time of year in any weather and more importantly, have a place to keep in out of the weather once restored.
A special thanks to Kenny, Dad, Bob, Zac, Matthew, Bruce and Brad.
Old 07-09-2010, 07:31 AM   #227
BarryIowa's Avatar
Polk City , Iowa
Garage Lift
Here is the picture.
Old 07-09-2010, 07:34 AM   #228
nmbosa's Avatar
Nowhere , Washington
Looks great. Sure will be nice to have such a convenient indoor work space.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 07-09-2010, 08:59 AM   #229
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Okay, now I'm jealous!
Shari
Old 07-09-2010, 09:36 AM   #230
That's fantastic, Barry. I'd been wondering how things were going for you.
And I, too, am jealous.
Old 07-09-2010, 10:12 AM   #231
BarryIowa's Avatar
Polk City , Iowa
Marcus and Shari, no need to be jealous, I've seen you're trailers!!! I am the one that should be jealous!
Old 07-09-2010, 10:40 AM   #232
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
WOW!! That looks great. How much of a bear was this process? Also, jealous here too.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-10-2010, 10:00 PM   #233
Byams55FlyCl's Avatar
Centrally Located , Wish you were here!
Amazing!!!!!!!
Wowee!
Barry you are amazing and passionate - to raise the roof for vintage Airstream.
Can't wait to see your progress on '55 now that you will have a warm, dry place to work.
WBCCI & TAC
Goin' Vintage!
Kathy
http://byams55flyingcloud.blogspot.com/
Byams55FlyCl is offline   Reply With Quote
Old 07-12-2010, 08:42 AM   #234
BarryIowa's Avatar
Polk City , Iowa
You know it was a tough process but as with most things, the preparation was 90% of the work. Once all of the bracing and blocks were in place, the actual lifting only took an hour and a half or so. All of the lifting was done with six 8 ton bottle jacks. We would go up 4" and slide in another block and then lower it onto the block and place another block under the jack and keep repeating the process. There was no wind but the building was still moving a bit at that height before we got the 3' walls in place. I have some new photos of the progress over the last couple of days that I'll post tonight when I get home from work!
Old 07-12-2010, 09:00 AM   #235
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Very cool garage lift. How tall is the top of the garage door, 9 ft?
SilverHoot is offline   Reply With Quote
Old 07-12-2010, 09:02 AM   #236
BarryIowa's Avatar
Polk City , Iowa
Inside ceiling height is 11' and the overhead door opening is 9'. You never know, I could still put in a 10' door sometime down the road. My wife is very supportive and I don't want to find out where that blurry line is........
Old 07-13-2010, 12:19 PM   #237
BarryIowa's Avatar
Polk City , Iowa
From the floor to the top of the open right now it is 10' 5" or so but I am going to put in a filler/header so the opening is a standard size of 9' which will look a bit more "residential." The 9' insulated door is ordered and will be here either this Friday or next.
Old 07-15-2010, 07:41 AM   #238
BarryIowa's Avatar
Polk City , Iowa
More Garage Progress
Here are a couple more pictures of the garage lifting progress. The sheathing and house wrap have been installed and my dad moved the light switches down so I don't have to jump up to reach them. He also moved 4 of the outlets down 3' so they are in the same position as before the lift. I hope to get a bunch of the siding on over the weekend to keep the neighbors happy.
ID:	106836   Click image for larger version
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
Tricking out 23ft Flying Cloud - Suggestions? scubadog 2009-2015 Flying Cloud 5 09-13-2011 10:36 PM
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
