Old 06-11-2007, 04:26 PM   #1
1953 21' Flying Cloud
Anchorage , Alaska
Help confirm that this is a '53 Flying Cloud?
Hi all. Just picked this up a couple days ago. I'm a newbie so am not even positive of what I have and thought that might be the best place to start. Was advertised as a '58, but I think it is a '53 Flying Cloud. I'm not sure the recorded VIN is correct. It is something like CAL721294 on the title, but that doesn't fit the format I've read about. I looked high and low for a data plate but there is none. Numbers on the top of the A-frame are patent numbers. There is a number stamped on the side of the A-frame which is W717. Doesn't seem quite right either.
Can any of the experts out there take a look at the pics and help me identify this? Thanks.
ID:	38979   Click image for larger version
ID:	38981   Click image for larger version
ID:	38983   Click image for larger version
akas is offline   Reply With Quote
Old 06-11-2007, 04:42 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Based on the number you posted, looks to me like it might even be a '52. But the stove is definately not that old...it was probably replaced somewhere along the way. If it were a '58 it wouldn't have 13 panels...the vertical back (opposed to sloped) lead me to believe it's either a '52 or '53 as in '54 the back was sloped and it was 22' instead of 21' long.
What is the stamped number on the plate beneath the stached windows next to the door? That is your real VIN number...looks like a nice find!
From the outside, it looks a lot like this one to me ~
Shari
Old 06-11-2007, 05:05 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Looks like the plate is missing?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-11-2007, 05:08 PM   #4
InsideOut's Avatar
1956 22' Safari
Images: 108
Thumbs up Good eye!
Hmmm...looks like you're right. I didn't blow-up the pic.
Shari
Old 06-11-2007, 05:11 PM   #5
InsideOut's Avatar
1956 22' Safari
Images: 108
Lightbulb Here's another idea!
In my '56, the VIN number is stamped on a hidden face of the cabinet drawers/doors. Almost every piece of woodwork has our VIN number on it somewhere. Not sure when they started this...but you may want to look for a tiny (<1/8") black number on the end of a drawer...mine says 6421, in what looks like a datestamp sort of thing.
Shari
Old 06-11-2007, 06:13 PM   #6
Anchorage , Alaska
That's not the data plate from Airstream. That's a dealer plate, so I know where it was purchased, but there's no VIN stamped in it. I should look closer and see if it's covering the original plate. Thanks for the tip on the cabinets, Shari. I'll do some more looking. BTW, I can't believe you guys replied so quickly. Thanks again!
Old 06-11-2007, 06:37 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
It's easiest to find on drawers...usually on the outside, back of the side panel. Just pull out a drawer & look on all sides. For the doors it's either on the bottom or behind a hinge so you have to take the hinges off. The funny thing is, all our drawers/doors have 6421 except for four of the kitchen drawers which have 6424. This confirms that our friend's '56 Safari 6423 and ours were in the "womb" together. If we ever find 6424 I'd be curious if they have our drawers ~ Pretty funny!
Shari
Old 06-11-2007, 08:55 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
Okay, so I got home & looked through some of the pictures I've taken...here's one that shows the number I am talking about. This was taken during stripping so that's what all the orange "goo" is...
Shari
Old 06-12-2007, 04:20 PM   #9
Anchorage , Alaska
I looked high and low and none of the drawers have a number. The cabinetry does look like it was build for this Airstream and around the same period but lots of different materials were used, especially in the drawer construction so who knows how much of it is actually original. It's easy for things to look 'vintage' over a 50 year time span. I think I'll settle on a '53 and get on with the restoration. The VIN on the title is CAL129704. Maybe someone can decifer that.
Old 06-12-2007, 04:29 PM   #10
47WeeWind's Avatar
1948 16' Wee Wind
Denver , Colorado
Images: 20
...The VIN on the title is CAL129704. Maybe someone can decifer that.
That title VIN looks like an arbitrary VIN that was assigned to the trailer by the CAL DMV because the trailer's real VIN was unknown, perhaps due to a missing data plate. The VIN's first three letters, CAL, lead me to that conclusion.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 06-12-2007, 05:14 PM   #11
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I concur with the California-issued VIN thought.
It's definately a '52 or '53 Flying Cloud... there really wasn't much difference between the two. In '53 they began to differentiate the Ohio-built FCs by prefacing the VIN with an "O", and I believe that the Ohio VINs were in the 7,000 series and the Sante Fe Springs VINs in the 5,000 series. (Please correct me if I'm wrong, Fred!) Of course, absent other info on yours, you'll never know, without the original VIN, which plant it was built in!
Roger
Old 06-12-2007, 06:58 PM   #12
CaptainJones's Avatar
1951 21' Flying Cloud
Western , Kentucky
California Clouds began in 1950 with a starting vin of 7001 and went up to 84?? in late 1958 when they changed the numbering system.
Ohio clouds began in 1953 with a starting vin of 3001 and went to about 3500 before changing in 1959.
I have heard the Vin was also stamped on the frame tongue, but I have never looked for mine as my original plate was still there.
Greg Jones
CaptainJones is offline   Reply With Quote
Old 06-12-2007, 07:29 PM   #13
47WeeWind's Avatar
1948 16' Wee Wind
Denver , Colorado
Images: 20
Late 1953 Flying Cloud
It looks to me to be a late 1953 California built 21' Flying Cloud. I base that on the mid-body height of the side marker lights, which show up on 1953 Flying Clouds. Of the three having them on RJ's web site:
53FC
only one trailer has a serial number listed, 7521, which is a late 1953 model year California serial number. That trailer is listed under 53FC5. The other two, 53FC1 and 53FC4, don't have their serial numbers listed but also have mid-body height side marker lights. So going by the admittedly unreliable sample of one example, I'd say yours is a late 1953 Flying Cloud. Earlier FC's all seem to have the side marker lights very low on the body sides, just above floor level.
Airstream Life
"From the Archives"
Old 06-12-2007, 10:50 PM   #14
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
My 51 and my buddies 51 registerd as a 52 both had rectanglular tail lights (since replaced in the past with Bargman 99's) but you can still see where that was done. My buddies, S/n is 30 away from mine, has lower but not quite at the bottom marker lights only, mine has bottom and top. Also, the front window is different. Ours have the two panes of glass, so I believe yours is a 1953. Good find, congratulations. It looks in reasonable shape. Oh yeah, one other thing, my cupboards are similar to yours where the other one is quite ornate (I'm so jealous and I have kindly offered to trade him cupboards/counters but he has so far declined - but I'm working on him).
Barry
safari57 is offline   Reply With Quote
flying cloud
Boy Oh Boy! my new '56 Flying Cloud! urbanfood 1956 - 1959 Flying Cloud 169 07-18-2012 07:24 AM
Our '53 Flying Cloud and the Ridgeline air19 1950-1955 Flying Cloud 5 08-31-2011 09:18 PM
roof vent size USA 53 FLYING CLOUD wilson russe Roof Vents, Skylights & Fans 0 10-08-2005 11:08 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
