Old 06-12-2007, 10:54 PM   #15
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
You can view mine on RJ Dial's site, under 1951,
1951FlyingCloud2
. The s/n is 7173. The '52's I've seen in pictures all resemble mine for front and rear windows.
Barry
safari57 is offline   Reply With Quote
Old 06-13-2007, 05:13 AM   #16
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Originally Posted by 47WeeWind
It looks to me to be a late 1953 California built 21' Flying Cloud. I base that on the mid-body height of the side marker lights, which show up on 1953 Flying Clouds. Of the three having them on RJ's web site:
53FC
only one trailer has a serial number listed, 7521, which is a late 1953 model year California serial number. That trailer is listed under 53FC5. The other two, 53FC1 and 53FC4, don't have their serial numbers listed but also have mid-body height side marker lights. So going by the admittedly unreliable sample of one example, I'd say yours is a late 1953 Flying Cloud. Earlier FC's all seem to have the side marker lights very low on the body sides, just above floor level.
Captain Jones, thanks for straightening me out on the VIN series. If I'd have looked at my own photos I'd have gotten it right!
Here is a photo of two '53 Flying Clouds together, both Ohio production, and less then 30 units apart in production. The one on the left is the one T.Gray has restored so beautifully and has a VIN of "3009", note that there is no "O" in front of it. It has the low side marker lights Fred mentioned. It also had square Bargman taillights as original equipment. The one on the right had, I believe, a VIN of "O-3031" or close to that and has the higher side marker lights. Note that neither has a water tank fill neck in the same location as the one shown earlier in this thread.
Roger
Name:	53 Flying clouds.jpg
ID:	39089   Click image for larger version
Name:	serial plate.jpg
Old 06-13-2007, 10:07 AM   #17
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Originally Posted by 85MH325
Here is a photo of two '53 Flying Clouds together, both Ohio production, and less then 30 units apart in production. The one on the left is the one T.Gray has restored so beautifully and has a VIN of "3009", note that there is no "O" in front of it. Roger
Roger:
Thanks for posting the photo of that early Ohio serial number plate for Flying Cloud "3009". Note the only factory address on these early Ohio trailer s/n plates is the Los Angeles factory, which makes me theorize the "O" was quickly added as a serial number preface to denote the Jackson Center, Ohio factory before new serial number plates were made that listed both factories. Once those new s/n plates arrived, the Ohio factory kept the "O" as it was now useful to distinguish the Ohio from Calif. factories that appeared together on the revised s/n plates. Besides, "O"ld habits die hard.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 06-13-2007, 04:17 PM   #18
Anchorage , Alaska
Thanks again everybody. The amount of knowledge you bring to these forums is amazing! Now that I'm sure of what I have I can make some better decisions as to the restoration. We're going to go for a semi-custom rather than all original restore. I plan to start with doing the floor/frame/holding tank combo that many have done. It'll all be with shell on since I don't have a shop and I can use the shell as a shelter during colder months. (Nine out of 12 months could be considered colder in Alaska) I'm sure you'll see me in the other threads.
akas is offline   Reply With Quote
Old 08-16-2007, 05:16 PM   #19
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
haven't been on this thread before. great find akas!
fred, there is no california whale tail on this one which may mean it was ohio built BUT i don't know when they started making the california whale tails. any idea?
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
flying cloud
Boy Oh Boy! my new '56 Flying Cloud! urbanfood 1956 - 1959 Flying Cloud 169 07-18-2012 07:24 AM
Our '53 Flying Cloud and the Ridgeline air19 1950-1955 Flying Cloud 5 08-31-2011 09:18 PM
roof vent size USA 53 FLYING CLOUD wilson russe Roof Vents, Skylights & Fans 0 10-08-2005 11:08 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
