After looking for over a year, I finally found a Hehr standard window that matches the rest of the windows in my 1954 Whale Tail. It came with all the pieces, inside and outside. It was painted white[ugg]. I have stripped the paint and have started the polishing process. The question is what type of glass to use, heat treated? tempered? regular? 1/8 thick?
Here is the good part, to rebuild one of those windows the right way, you pretty much need to remove it from the shell. All you are lacking is the hole!
