Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 1950-1955 Flying Cloud
Old 07-20-2018, 04:05 PM   #1
1951 21' Flying Cloud
1954 22' Flying Cloud
columbus , Ohio
glass type?
After looking for over a year, I finally found a Hehr standard window that matches the rest of the windows in my 1954 Whale Tail. It came with all the pieces, inside and outside. It was painted white[ugg]. I have stripped the paint and have started the polishing process. The question is what type of glass to use, heat treated? tempered? regular? 1/8 thick?
finn21 is offline   Reply With Quote
Old 07-20-2018, 04:49 PM   #2
Central , Mississippi
Tempered 1/8"
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 07-22-2018, 12:32 PM   #3
columbus , Ohio
Glass ordered, now for the hard part, any shops around ohio that could cut a hole in the bathroom wall and install it, making it look original?
Old 07-22-2018, 02:45 PM   #4
That's a nice looking trailer!
Old 07-22-2018, 04:36 PM   #5
columbus , Ohio
Thanks, mostly original. I don't want to add the window unless it is done right. I'm worried about cutting the hole and warping the skin.
ID:	317783   Click image for larger version
Old 07-22-2018, 04:41 PM   #6
Here is the good part, to rebuild one of those windows the right way, you pretty much need to remove it from the shell. All you are lacking is the hole!
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Installing Glass in '68 type 3 hinge AudioMike Windows & Screens 6 08-22-2009 01:20 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
What type of glass should be used on a 60s AS windows? Andy R Windows & Screens 1 06-19-2002 09:23 AM
