Old 01-11-2010, 04:59 AM   #29
Baltimore , Maryland
Buy one of these tools. Not doing any advertising, it is just the best thing since the invention of the Airstream. Your rivet removal will be very fast....
Old 01-11-2010, 05:04 AM   #30
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
With what are you goign to replace the removed insulation?
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 01-11-2010, 06:33 AM   #31
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
Crying in my Beer
Shari,
I would like to do a shell on, started down that road but when I found 3 rotted frame members and the very rusty frame I figured off is going to work better for me. There is a couple of reasons, I can take the frame to my welder and then to the body shop to be sand blasted and painted in the cold weather, also when I have the welder fix/replace the frame I can have the supports welded in place to hold the tanks. Also the belly pan needs replaced it is shot. Now the key to this is to see if the shell will fit through my garage door, if not I plan on setting it in the drive where the trailer now sits and I will use sandbags to hold it down in the wind.(I think that will work) The part that has me freaked is when I removed the old floor along the curb side we got a 14 inch snow and that weight shifted the skin on to the frame, so its sitting crooked. I need to jack that side up from the inside so that I can get some 3/4 between the inside supports and the frame, then I can build the supports for the shell when I remove it. Looking at those threads last night also has me a bit freaked, I think I know what to do and how to brace it but I'm still not real comfortable with the whole thing. From what I see I need to go from support to support front to back and side to side before I pull the rest of the bolts and screws from the floor. I guess these supports are held to the inside frame with metal screws through the rails into the 2X4 ect. Oh well there has go to be a first time for everything!
As far as the cold, a good pair of boots and socks, a heavy Carhart jacket, lined jeans and snow pants and I'll be yelling "hey guys wait up" when I fall and lay in the snow like a slug! Heck we ice fish here at 20 below!
Still not looking forward to this..........
Frank,
Thanks for the link to the tool that will get ordered today!
Aircooled4
You have been there and done this, I enjoyed looking over your posts last night, now if you have the urge to visit you would be more than welcome! Also I will use the same materials to insulate as Shari did in Its a Girl.
Airslide,
Crazy, just crazy............
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Ed Emerick is offline   Reply With Quote
Old 01-11-2010, 08:48 AM   #32
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by Ed Emerick View Post
Shari,
<snip>
Bummer..
As far as the rivet removal tool - we have one too. Although I felt it was easier and more accurate to drill them out without it. IMO, save your money - or better yet, do you want ours? Let me know ~
Shari
Old 01-11-2010, 03:07 PM   #33
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
Oh Ya
Anyone needing any Git Rot I have two large cans I can sell now, no need with a new floor My cost plus shipping.............................
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Old 01-11-2010, 05:04 PM   #34
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Ed,
Here is my favorite description of the remaining airstream that was flooded in Georgia.
The ebay seller quotes "DAMAGED BY WATER IN ATLANTA FLOOD OF LATE 2009---THE INSURANCE COMPANY HAD IT CLEANED =COST OVER SIXTY THOUSAND NEW ===I DON 'T KNOW WHAT WORKS OR DOES NOT WORK UNTIL I GET IT IN NEXT WEEK--MY EXPERIENCE IN REPAIRING FLOOD DAMAGED AIRSTREAMS USUALLY MEANS THAT EVERYTHING WILL WORK AFTER THOROUGH CLEANUP EXCEPT THE INVERTER---I AM TOLD THAT AIRSTREAM USES EXTERIOR TYPE PLYWOOD IN THE FLOORS THAT WILL NOT ABSORB WATER-- "
So good news! You wont need Git Rot anymore!
If only your airstream used this very special non absorbing plywood!
Ok ok... at your current burn rate you should have the frame repaired, painted and new flooring in place by Thursday...
we'll stay posted..
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-11-2010, 06:06 PM   #35
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Best tool ever Frank!! Wally introduced me to it, saved hours and much more precise!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-11-2010, 06:39 PM   #36
I slipped drilling a rivet out the other day on a clients trailer. I got very lucky that the huge scratch is going to be covered by a patch. It can happen so quickly. I chuck the rivet remover in an air drill and crank the pressure up to 120 psi. The tool drills the rivet out in about .75 seconds. I really think it paid for itself in the first use. Just my opinion, the tool might not work for every one's needs.
Ed, take Shari up on her offer..
Old 01-11-2010, 08:47 PM   #37
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Any suggestions warnings, inspiration is appreciated!....
Ed, youíre our inspiration. My dinette conversion seems like small potatoes compared to your undertaking.
Front end furniture pulled on New Yearís weekend, front interior skins off and dents popped out last weekend. New insulation and wiring next.
Working between blizzards and Arctic cold spells is annoying but Iím getting more upbeat the more I do.
Thanks for the updates,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-12-2010, 05:43 AM   #38
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
Renovation
Tom,
Sounds like you are making great progress, got any photos? I have to rework the front end, the original owner changed the dinette and I have to replace that. Just looking for ideas, and a way to refocus!
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Old 01-24-2010, 05:10 PM   #39
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
Another Day and More Floor Removed
Well I made the run to the lumber yard and framed up the FC this weekend. Now I am slowly removing the floor out of the elements. Today it rained, snowed froze, rained, froze snowed...........
These are the photos of where I am at this point. I hope to have the rest of the floor out by next weekend and move on to drilling out the rivets. As a side note, more frame rot was found and I'm now glad I pulling the shell and reworking the frame.
I have all kinds of things running through my mind including a visit to the scrap yard! I think aluminum prices are up............
ID:	94707   Click image for larger version
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Old 01-24-2010, 05:41 PM   #40
tallytwo1994's Avatar
tallahassee , Florida
Wow, that looks well braced: souldn't be any movement there. Hope you made templates though.
Carol
tallytwo1994 is offline   Reply With Quote
Old 01-24-2010, 06:00 PM   #41
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
Huh?
Templates? I need templates of what??????
The floor? Now I'm in trouble!
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Old 01-24-2010, 07:02 PM   #42
moderator
Airslide's Avatar
Wilton , California
Images: 50
Ed,
Looks great!
Vin
1954, flying cloud
