Old 01-16-2016, 09:19 PM   #1
1953 21' Flying Cloud
Atlanta , Georgia
Complete 1953 Flying Cloud Redo (honest...everything)
Hi All
We have been completely restoring/rehabing/renovating/repairing our 1953 Flying Cloud for the past 2 years. We've been documenting it on our instagram but thought I would go more in depth here.
I'll start from the beginning and eventually will reach present day where I'll continue to update.
handrew is offline   Reply With Quote
Old 01-16-2016, 10:13 PM   #2
Atlanta , Georgia
Specs and Basics
Purchased October 2013 from NJtoNC, great people, the best.
Year: 1953
Length: 21' with tongue, 18' without
Width: 7' inside
Height: 6'3" inside
Weight: unknown (for right now)
Built in Los Angeles, CA
1755 North Main St.
Serial number: 05093
Original state: had been used as a chicken coop when we purchased it. Small bed in the back with a 70s era bathroom and galley, and the rest was chicken coops.
Plans: Complete rebuild to fit our future full-time lifestyle
Old 01-18-2016, 01:15 AM   #3
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Looks like you're doing everything "right", giving it a chance at another 60 years on the planet.
Can't quite figure out your serial number though. I'm going to guess it's maybe an Ohio built trailer as they had an "O" at the beginning of the number. However I can't find any O 5XXX Models - Flying Clouds were either O3XXX (Ohio Built) or 7XXX (California Built).
Vintage Airstream Photo Archives - Vintage Airstream
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 01-19-2016, 10:04 AM   #4
Atlanta , Georgia
Exterior: When we got it
We were lucky that the exterior was in pretty good shape. Some previous damage on the top driver side of the front end cap. Looked like it had been repaired from the interior previously.
The front panel had multiple dents and dings and had a couple aftermarket outlets installed. We ended up replacing it, see future posts for photos.
Old 01-19-2016, 12:27 PM   #5
Atlanta , Georgia
Interior: When we got it
The original interior had been removed and replaced with a small bed in the rear, a gopher hole style bathroom and small kitchen counter with sink. The rest of the space had been built out with 2 levels of chicken coops. I didn't get a ton of photos of the interior before we started ripping stuff out, but you can see the frame of the bed in these. In the last photo you can see the chicken coops behind the dog.
You can also see the front window was in bad shape, we ended up replacing that with one from another '53.
Old 01-21-2016, 02:39 PM   #6
1965 30' Sovereign
1969 23' Safari
Redgranite , Wisconsin
Big project. Nice! I'll tag along.
Lots to do. Getting there.
65Streamer is offline   Reply With Quote
Old 10-26-2016, 01:08 PM   #7
Atlanta , Georgia
Floor removed, tackling the frame
I think we got so excited about demoing we forgot to take pictures. But to put it simply, we ripped up the old floor, finding 2 layers of old linoleum and 2 subfloors.
We then got down to the frame and realized is needed some major love.
We angled grinded? angle ground? with a wire brush attachment to get the decades of rust off.
We found some places where the steel had disintegrated and needed to re-weld some spots and weld some new metal on to reenforce it.
Once all the rust was off, we sprayed the whole frame down with rust proofing to help preserve it for the next couple decades.
Since we were newbies, we also didn't understand how much of a nightmare the bellypan was to remake, so we just cut it up into pieces as we went along the frame (DONT DO THIS! )
Name:	2013-11-17 09.27.08.jpg
ID:	274263   Click image for larger version
Name:	2013-11-29 22.12.03.jpg
Name:	2014-01-11 16.43.18.jpg
ID:	274265   Click image for larger version
Name:	2014-01-11 16.46.52.jpg
Old 10-27-2016, 04:29 PM   #8
Atlanta , Georgia
frame work pics
more pics of the frame and the reweld we did in a few weak spots
Andrew working on the frame
some patches in weak spots
we realized these were really bulky and ground them down
added an angle iron at the entrance to make it stronger
interesting to see the outrigger support on the front of the frame
Old 10-27-2016, 05:02 PM   #9
Atlanta , Georgia
Installing grey tanks in frame
the older frame is very shallow, only 3 inches, and we didn't want to invest in having a custom tank built so we went with the 4" grey water tank from vintage trailer supply. To accommodate for the extra height of the tank we welded a 3 "cradle" bars underneath. We then zip tied some neoprene to the bars to avoid the bars from cutting the plastic of the tank.
We installed 2 tanks, one in the rear of the frame for the shower and one in the middle of the frame for the kitchen sink.
Old 10-27-2016, 06:32 PM   #10
Atlanta , Georgia
Shocks and leaf springs
We looked everywhere for shocks the same size as the original with no luck. The originals were actually in good shape so we just wire brushed them, replaced the bushings, and reinstalled.
The leaf spring didn't seem to be in too bad of shape, so we just replaced the bolts holding it to the frame. We plan on refurbishing/replacing them eventually.
Old 10-27-2016, 06:36 PM   #11
Atlanta , Georgia
New subfloor
We hired some local carpenters to install a new subfloor.
They used 3/4" marine grade plywood. Attached with elevator bolts and screws.
They created a template using foam insulation.
Old 10-27-2016, 07:10 PM   #12
Atlanta , Georgia
New lower front exterior panel
The front lower panel was full of holes, after market outlets, dents and scratches. We ended up purchasing a new aluminum panel from Airpart Inc.
We easily removed the original panel by drilling out the rivets and coaxing it out.
We used the old panel as a template to cut the new one. We used pneumatic clippers to cut the metal. We then slide it up under the end cap and used the original rivet holes as a template and drilled a few holes to put clecos in to hold the panel while we positioned and riveted.
There was a "reenforcement" panel on the front that we left to keep the front rigid.
Even though we had access to the back of the panel (we removed the lower interior panel to remove the floor) we used olympic rivets because we didn't have a buck rivet gun yet.
To "water proof" the rivets we smushed a small bit of TremPro into the hole then riveted the rivet in.
We then used a rivet shaver to shave off the little nubs that are left when you clip off the stems of the olympic rivets.
We also wrote our names, year, and location on the back of the new panel when. Maybe in another hundred years the new owners may renovate and see it
Old 10-27-2016, 07:28 PM   #13
Atlanta , Georgia
Removing interior panels and insulation
The original interior panels were disintegrated on the bottom in parts and has tons of holes from original fixtures and outlets.
The original insulation was pretty good in some spots but falling apart in others where animals and water had gotten to it.
We ended up removing and replacing both (see future posts for each).
While removing these we found some interesting artifacts in the wall, including a curved wooden support that looks like it was installed to repair damage on the front driver side end cap. And a tension bar holding some ribs together. You can see the original builders used tar to glue the insulation to the walls as well as waterproof the seams. We also found some tools used to form the original skin.
Old 10-27-2016, 07:40 PM   #14
Atlanta , Georgia
C-channel repair
The c-channel was non existent in some places, and needed some reenforcement in others.
For the places that needed new pieces we used a piece of angle aluminum screwed into the floor and riveted to the exterior skin.
For the places that needed reenforcement we screwed flat pieces of aluminum across the whole part that needed help.
Flying Cloud "Diamond Girl" :: 1953 Airstream Flying Cloud gb2862gb Airstream Registry Discussions 0 04-29-2014 07:34 AM
Vintage 61 Covered Wagon Bon-Aire.18ft. Complete Exterior Redo.Airstream Hubcaps eBay Watch Airstreams on eBay 0 09-05-2013 11:50 AM
Complete neophyte to everything tamerlane Hitches, Couplers & Balls 5 06-06-2013 12:11 PM
Complete Redo - 25' Tradewind mdhofmann General Interior Topics 33 12-06-2010 08:17 PM
