01-01-2017, 08:48 PM
#113
1966 22' Safari
1954 22' Flying Cloud
Saline
, Michigan
Installed
01-03-2017, 11:39 AM
#114
1966 22' Safari
Saline
, Michigan
Finally have the insulation all done. Two layers of Prodex spaced between two layers of offsets.
Wiring is next up and should take awhile as we haven't finalized layout/ electric circuits/plugs / 110v and 12v. Along with rough plumbing.
01-12-2017, 02:55 PM
#115
1966 22' Safari
Saline
, Michigan
Not much done, but I did get the outside running lights wired and hooked up. Getting the plug to converter wire tonight. Also polished where running lights , shore power inlet, water inlet, license plate light will go, so I can finish hooking those up.
01-14-2017, 05:03 PM
#116
1966 22' Safari
Saline
, Michigan
A Cloud named 'Spoon'
Got all the side running lights hooked up,but in the process I dropped one of the lens, yep destroyed it, I found a replacement glass one on eBay, should be here Tuesday. Made a license plate bracket, wired the light for it up and installed it , along with the new Furrion 30 amp power plug. I also have the fresh water fill inlet completed on the outside.
01-17-2017, 01:21 PM
#117
1951 21' Flying Cloud
Sacramento
Looks great! If it makes you feel better after installing my vintage Nite Owl license plate light I dropped the lens and it shattered on the bumper. God bless eBay!
01-18-2017, 04:44 PM
#118
1966 22' Safari
Saline
, Michigan
Ok which one of these is not like the other?
01-25-2017, 04:53 PM
#119
1966 22' Safari
Saline
, Michigan
Decided to convert to original H-20-2 door handle with a twist it will be flush mounted-no turning back now
01-25-2017, 04:57 PM
#120
1966 22' Safari
Saline
, Michigan
Sorry for double post
01-26-2017, 04:54 PM
#121
1966 22' Safari
Saline
, Michigan
Almost done, them to polish
01-28-2017, 07:18 PM
#122
1966 22' Safari
Saline
, Michigan
Rebuilt the H-20-2 door handle and built a new threshold. Need to install screen on the door , polish hinges and try to install door.
01-29-2017, 07:46 PM
#123
1966 22' Safari
Saline
, Michigan
Originally Posted by goshawks00
Thanks Tim... when I took the wheel wells in to the HVAC guy we went over the profile of them and I made sure he knew about there was was a width difference. I moved the frame up closer to the house and onto the pavement... wow was that full use of the 'art' of hillbilly engineering! Starting to box the frame and will be talking to Colin today about a new axle.. Will be going with a torsion , but try to maintain the original height. Other important mods will be a 'Natures Head' comode, and a bigger grey tank now that there will be more room. Where are you at with your FC ?
Barry
You
03-01-2017, 06:13 AM
#124
1966 22' Safari
Saline
, Michigan
You
After a month off while in Florida, I'm finally back working on Spoon. Picked up the new panel from my local metal guy and have cleoed it in place. The old panel had holes where the PO had hung something from it so needed replacing. I made the panel but didn't have the ability to put the rolled edge on it. Looks great now just needs bucking on. I also got the door in a door installed with the new hinges. Will add pics today.
03-24-2017, 09:36 AM
#125
1966 22' Safari
Saline
, Michigan
Finally back on Spoon , after to much time away the new front panel is bucked in
03-25-2017, 08:59 AM
#126
On adventure with H&G
2012 30' Flying Cloud
1966 28' Ambassador
Lansing
, Kansas
Nice! I am doing that panel and the other curbside panels the next couple weeks. Love to see the progress.
